Question about Frigidaire Affinity ATF7000E Front Load Washer
My washer erorrs E20 and stops and does not drain. It will drain slowly if it is on spin cycle without the clothes in it. how can i fix it/
  • 1,531 Answers
You need to check the drain pump once you have removed all the water. remove all the hoses that go to and from the pump and look for any obstructions.make sure to take the hose off the bottom of the tub and check the coin trap.
Posted on Nov 14, 2010
My Frigidaire Affinity front loading washing machine is reading an E20 error code when in the spin cycle. It stops the cycle and I have to push cancel and put it in a spin only cycle to get it to spin,...
Hi - Im not familiar with your particular washer but will try & help you as best as I could, am a Miele - F&Paykel - Electrolux specialist..
Based on your observations I would first have a look at the drain pump for any restrictions, a lot of the front loaders have an acess panel where you could open up to remove coins,pins and others that find its way to the pump. Failing this the side panels are removeable to gain .. pumps etc.
E20 could be the fact the sensors recognize that water is still in the machine prior to going into the extract/spin cycle.
I hope this may help you in some way..
JUST MAKE SURE YOU DISCONNECT THE POWER FROM WALL BEFORE YOU HAVE A LOOK.....
Good luck
Jul 07, 2011 | Frigidaire Washing Machines
Frigidaire front load washer (LTF600ES1) Error E20
this is an error that indicates the tub is clogged or draining slowly
to fix this you have to go under the washer and pull the tub hose off and clean all obstructing stuff in the hose and thru the hole on the tub
Oct 18, 2008 | Frigidaire ATF6000ES Front Load Washer
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire gallery front load won't spin
Does the washer spin after the wash cycle? It sounds like the door switch. This is a common problem with frigidaires. 90% of the time a door switch fixes it.
Jul 01, 2009 | Frigidaire Washing Machines
Code E20
my cloths will wash but will not spin out the drum stop turning when it comes to the spin cycle makes a humming noise
Mar 30, 2009 | Frigidaire GLTF2940ES Front Load Washer
Does not drain error code f2
There is a block in your pump, you have to locate it, dismantle it & remove the block. Plug off the wall first.
Mar 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
E20 code on washer : will not empty water on spin cycle?
something is stopping the water from drainning...check for kinked hose,,,check waste pipe,,,check units sump...onthejob
Dec 18, 2008 | Frigidaire Affinity ATF7000E Front Load...
Your washer is not draining properly. You need to check if the drain hose is kinked and also whether the household drain is running smoothly.
Aug 02, 2008 | Frigidaire GLTF2940ES Front Load Washer
Error 20 AEG washer dryer
On 40c wash hit E20 error so moved programme onto long spin and all ok!
Jan 09, 2008 | AEG Lavamat 16810 Front Load Washer/Dryer
Frigidaire Affinity ATF7000E Front Load Washer Logo
103 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
