Question about Kenwood XD-A75 CD Shelf System
The disc drawer most of the time will not open . If it does open the changer stops on the disc and starts to spin , then stops and error comes up on the screen. then the drawer wont open to remove the disk. If i unplug it , then it will rotate and open somtimes. I also wonder if this model is still available
  • rccrash4 Nov 20, 2010
    thank you very much i probably could replace the lens if i take my time ,but i think i will try to find a company that works on kenwood systems in the dayton ohio area . If you can suggest any one i would appreciate it . Thanks again.
    President:
  • 1,961 Answers
The problem on hard to open disk tray is cause by lens reading failure.Once the cd tray is close the lens reading initializes if initialization fails the system will hang no command on CD function will be accepted because the Lens is not park on it's standby position therefore no second function is recognize replacing the lens will clear the problem...The lens are still available in an electonics spareparts store.you need to open the cover of the component and get the part no.
I t would be better to bring your unit to a qualified service personnel because this kind of unit is hard to dis assemble specially the loading system of the disk there are timing gears in it be very careful when disassembling it.You can try it anyway goodluck and godbless!
Please post back if you have questions or klick the thumbs up button if this solution is helpfull to you.
Posted on Nov 17, 2010
How to fix a Sony 5-disc player that will continue to spin and not stop at any disc slot
There are opto's around the edge of the carousel so the machine can count it's position, maybe these are at fault
Sep 30, 2014 | Sony CDP-CE375 5-Disc CD Changer
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
FL 8350 CD Player. Disc drawer will not open. Getting error message
Most likely a belt has stretched and will not now move the tray. This happens of units more than 2 years old usually.
Dec 26, 2012 | Harman Kardon FL8350 5-Disc CD Changer
CD function in 5 disc stereo constantly flashing "CHANGE"
Open the drawer and check to verify the disc was put in the disc 1 position. Sometimes the changer gets confused if disc 1 is not in the disc 1 cavity. Also, 5 disc changers are very prone to failure
Nov 17, 2012 | Audio Players & Recorders
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
Five discs keep spinning; will not stop. Cannot open drawer
they button maybe stuck or the switch that open the cd player sticking try to push button to open then pull on drawer not to hard u brack then see if u can clean swith
Mar 22, 2009 | Sony CDP-C445 5-Disc CD Changer
CANNOT OPEN PLAYER
To open the drawer, unplug the unit while the power is on (so that the drawer doesn't try to open on its own). Keeping the unit flat on a table, look underneath and find the small hole where you can turn the loading gear. Rotate it until the unit opens, using a standard flat screwdriver. The loading gear is a white plastic part with a slot in it. You should be able to see it rotate if you move the drawer by hand.
After manually removing the disc, turn the gear with your screwdriver until the drawer is all the way in, The gear should be able to be turned for three or four more turns when the drawer stops loading. If it doesn't, turn it a bit further unit it "pops" past one more gear notch. It should then turn freely for a few more turns, at this point you should stop. Do not force it once it stops the second time. This is the "Disc Loaded" position.
Power the unit back up and see if it loads a disc and plays correctly.
Dec 18, 2008 | Sony CDP-C445 5-Disc CD Changer
Cd changer drawer won't open
the common problem for this would be some of the disc/discs are out of place . just opening the shell
and removing the discs can resolve the problem.
Feb 23, 2008 | Technics SL-PD5 5-Disc CD Changer
Kenwood XD-A75 CD Shelf System Logo
151 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
da surgen
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
