Question about ASUS P5GD1 Motherboard
Write delay slows computer and then stops
Is my motherboard failing, it reports errors of write delay, then starts to slow down, then stops waiting to write. Just keeps on reporting write errors.
    President:
  • 2,351 Answers
Please find the name of the hard disk drive, found on the white label on the hard drive. Ex: Seagate, Western Digital, Samsung ECT. Got to their web site & download their tools or drive setup utilities & create a bootable floppy disk or bootable CD disk.
Their dos like software will test & repair most hard disk problems. Back up you're personal data, picture, and address book ECT. & burn to CD before running software.
If it finds problems it will erase you're data to repair the drive. You'll find other settings you can turn on or off that may increase the drive speed. The slowness is all about the hard drive & not you're system. If you're lucky all you'll have to do is a fresh install of windows.
Good Luck!
Mike
Posted on Jun 19, 2008
  • Mike Peluso
    Mike Peluso Jun 19, 2008
    More to the point, It's not you're motherboard that is failng. It's you're hard disk drive that's failing. Normally running the Mfg's software on the drive can breath new life to the drive. Slow write & or slow read are casued by data corruption, windows registry corruption & the drive's file allocation table corruption. Bad sectors on the drive is another reason for slow write speed & lockups. It's all about the drive in you're case.
    M
Dell 8100 dimension keeps freezing running fedora 17
Check that all appropriate linux drivers are installed your hardware. Especially your hard drives, motherboard chipset, and peripherals.
I'd also need to see a general report of what is happening (the Fedora error reports) to help you beyond that. The logs are stored /var/log
Oct 16, 2013 | Dell Computers & Internet
Installed hallmark card studio 2011 upon launch keep recieving send error message to microsoft.
The installation must have gone wrong somewhere, Uninstall and install again.
If the program works anyway. Just disable the "Send Error Report" message:
To access the settings for the reporting feature:
  • Click Start.
  • Right-click My Computer, then click Properties.
  • Click the Advanced tab.
  • Click Error Reporting.
To configure the error reporting feature:
  • By default, error reporting is enabled. To disable it, click Disable error reporting. To continue to be notified when errors occur without being prompted to report the errors, click to select the But notify me when critical errors occur check box.
  • Specify whether you want to use error reporting for the Windows operating system, for programs, or for both Windows and programs.
  • To report errors only for selected programs, click Choose Programs, click All programs in this list, and then click the programs that you do not want to include.
  • To add a program that is not listed, click Add, type the name of the program, or click Browse to find the program on your computer.
Mar 01, 2011 | Computers & Internet
My web cam stop working it say the following error in device manager. Windows has stopped this device because it has reported problems. (Code 43)
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
right click to reinstall drivers or
update driver
hope this helps
Feb 16, 2011 | Computers & Internet
My Dell Dimension 9150 is unstable. The Dell Diagnostic indicates memory failure in DIMM socket 3. I reversed the modules in the DIMM sockets and Dimm socket 3 failed again. Motherboard?? My motherboard...
Yes you can. Your best is to use the largest and best ram in the number one slot. I would remove ALL the ram and start with the 2 gig in the first slot - then add others until you get the error message - remove that one and keep the rest.
Mar 31, 2010 | Dell Dimension 9150 (DIM915MIN) PC Desktop
MAC PRO dual2.3- freezes, gray screen crash, freeze with hi fan mode,kernel panic reports, all require start button shut down. Some forums suggest ATI card failure. I'm lost.
All computers will shut them selves off or crash when fans are failing, or have failed. Cooling fans are plugged into the motherboard, and firmware on the MB keeps track of the system fans, along with everything else. If a system fan is failing, or has failed, the signal is sent to shut down. Some PC's will shut down cleanly, others give error messages, and some just freeze up. Of course, Bad RAM, video cards, and hard drives with bad sectors, can also cause problems like you have discribed.
I would write down any error messages, and beep codes, and then look them up online for a place to start.
Oct 22, 2009 | Apple Power Mac G5 Desktop
Dll driving me nuts
Hello EricS777
The part where it looks like your xp stuff and vista stuff switch drives is normal. Only the Operating System associates the hard drives by letters this does not mean your hard drive files are switching. This happens because D: drive is Root of Vista OS and Root of any OS in windows gets the C: drive lettering.
dwwin.exe, drwtsn.exe dll is the "Microsoft Application Error Reporting" tool.
I think the message means that something is crashing during system shutdown. When the crash occurs the OS launches dwwin.exe to report the error, however the windows operating system is shutting down and so the application can't launch make the system lockup or hang.
Your problem isn't with dwwin.exe, you need to find out what is actually crashing at shutdown.
If you can`t find out what it is, try going to Administrative Tools/Services and disable the “Error Reporting Service”. You don`t want that running anyway.
Also right click My Computer/Properties/Advanced/Error Reporting
Put a check at both
Disable Error Reporting
Then, if that was the cause and the message stops, we`ll have to try to identify the cause.
May 05, 2009 | Acer Computers & Internet
Broadcom 440x 10/100 Integrated Controller driver will not load
Your resolution will most likely be a replacement of the motherboard. You can try flashing the BIOS and see if that resolves, but from your details it appears there is a hardware failure of the motherboard. Generally, you can find a motherboard for this model on Ebay for around $100
Jan 10, 2009 | Dell Inspiron 8600 Notebook
Zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
Hi how do I turn of tx and rx reports on faxcentre F110/
The machine can print a transmission (confirmation) report after each transmitted fax. This report indicates whether or not the fax has reached the intended recipient. Four different settings are available for the transmission report:
  • With: a report is printed when the fax transmission was successfully sent or when it is completely abandoned. There is only one report for each fax sent.
  • Without: no transmission report is automatically printed, however, the machine will save all fax transmissions that took place in memory. The faxes sent can be viewed by printing out a transmission log (report).
  • Always: a report is printed after each successful or interrupted transmission.
  • On Error: a report is printed only if the transmission failed or is abandoned.
NOTE: With each transmission report from memory, a reduced version of the first page is automatically reproduced.
To modify the report type setting:
  1. Press the [OK] button directly below the Display Screen. '1 Installation' and '2 Fax' will be displayed.
  2. Press [2], [5] on the numeric keypad. ‘25 >Send Report’ will be displayed.
  3. Press [OK]. The transmission report screen will be displayed.
  4. Press the up or down arrow button directly below the Display Screen to select a transmission report setting, then press [OK]. ‘25 Send Report’ will be displayed.
    NOTE: As the up and down arrow buttons are pressed, the menu will scroll through the available choices and move the greater than symbol (>). Stop when the greater symbol is in front of the appropriate selection.
  5. Press the [Stop] button on the Control Panel. The 'Date / Time' screen will be displayed
Dec 11, 2008 | Xerox FaxCentre F110 Plain Paper Laser
Install more ram
U keep getting error report's just on msn or???
This pics will help you how to desable error reporting in ur pc :
http://img509.imageshack.us/img509/9153/errorreportingxq0.jpg
http://img509.imageshack.us/my.php?image=errorreportingxq0.jpg
Oct 08, 2007 | Intel Motherboard
ASUS P5GD1 Motherboard Logo
57 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
