Question about Kenmore Elite HE3 Steam 8674 Dryer
It has trouble starting and staying on. - Kenmore Elite HE3 Steam 8674 Dryer
  • Kenmore Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Nov 14, 2010
99 malbabu starts but won't stay running
How long since a tune-up? Check for applicable trouble codes? To check codes, yourself, at the least, you need an obd2 code reader.
If it stalls quickly, check your security system. Is there a security lamp on the dash that stays on or flashes when it stalls?
There are many possibilities, I need something to point us in the right direction, A trouble code or something? Checking fuel pressure is part of a tune-up.
Jul 04, 2017 | Cars & Trucks
Check engine light stays on. changed oxygen sensor, pcv valve, coolant sensor, switched out PROM chip, and cannot get a code to blink. replaced all hoses coming off carb. smog pump and egr valve been...
what you could start with is checking to see what trouble codes are being logged for this vehicle...if the engine light stays on, it means the ecu is registering a fault......by the means of a trouble code...now the trouble code doesnt tell you how to fix it, but it does give you the direction to go down...judst wondering if you have tried to obtain the trouble codes
Aug 26, 2010 | 1981 Chevrolet Corvette
1993 pontiac bonneville fuel pump problem
It could be that you have picked up a batch of dirty fuel that has clogged the gauze input filter that is part ot the fuel pump inside the fuel tank.
Jul 29, 2010 | 1993 Pontiac Bonneville
Trouble starting replaced battery
Too brief. A good battery should be about 12,5 volts. When you crank it over, it should drop to about 10 volts. If a starter is binding or shorted, the voltage will drop to 9 or less. If the started brushes are worn, it will stay around 11 volts. If it stays at 12 or just clicks, then it is the starter solenoid. If it does not even click, then it is probably the neutral safety switch, or the ignition switch itself. When you start it, it should go up to about 13.5 volts when you rev the engine. If it doesn't go over 12.5, then the alternator is bad and you are draining the battery.
Jan 19, 2010 | 2000 Dodge Intrepid
Dell inspiron 530s is giving me major trouble. When ever I turn it on, the power button lights up and the fan turns on but then thats it. There is no activity on the monitor, just the loud noise of the...
my inspiron 530 giving me trouble. Blue light is on, but the computer goes no where. Try to start by shutting down and restarting but the start sound keeps coming fora long time and nothing happens. So to say having trouble starting and sometimes it shuts down but the blue light stays on. Sometimes I cann't even turn off the computer by pressing blue light - trouble trouble trouble
Feb 22, 2009 | Dell Inspiron 530s Desktop Computer...
SHUTDOWN
My Garmin 660 after going thru the initial start up of "loading map" it will just SHUTDOWN. I have tried to clear the data in the diagnostic menu as recomendated by Garmin support to no avail. At the start, the trouble is it will just stay in the loading map stage. Then later it begin to shutdown.
Jul 12, 2008 | Garmin Nuvi 660 GPS Receiver
Kenmore Elite HE3 Steam 8674 Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
