Question about Presto HeatDish® Plus Footlight® Electric Heater
Unit is inoperative- have checked wiring and appears ok, seams to have 120 volts to switch, but not beyound.
  • 12,061 Answers
OK, first use a meter to check that the switch actually closes and allows the current through the switch. If the switch is OK, then usually heaters have a "Thermal Fuse" or an Overheating Switch, if the heater is overheated this device will go permanently "Open Circuit' and stop the flow of current to the element.
The circuit is usually from the phase to the switch, through the switch on to the thermal fuse, possibly then if it has a thermostat through those contacts, and on to the "Hot" side of the element, the "Other" or "Cold" side of the element then is connected to the neutral,or return, thus the circuit is complete.
The element should have a resistance, of between 12 to 18 OHMS.. it shouldn't be Open Circuit.
When closed the switch should be Zero 0 OHMS. (Short Circuit) Same as for a "Good" thermal Fuse.
You should in a good working system have 120 V AT the "Hot" side of the element, (The side closest to the switch)
Posted on Nov 15, 2010
Domestic duo therm gets 20volts everywhere I checked. I have yet to check the switch on top of the compressor. Neither fan nor compressor turn on or make noise. Get 120 at breakers.
If you don't have 120 volts at the power connections at the unit, you have an open fuse or wire someplace between the breaker and the unit.
Jun 24, 2014 | Heating & Cooling
No water is entering the washer
Could be a number of things. First check across the water valve/overfill switch combo to see if it is getting 120 volts when the unit should be filling. They are wired in series so A wire---water valve---B wire---overfill switch---C wire. So you want to measure A wire to C wire. If no power then your problem is elsewhere. If you have power then measure across the overfill switch. If there is 120 volts across it then it is either not being actuated or is toast. If the overfill is 0 volts then measure the valve,. If it is getting 120 volts across it then either it is toast or the filter screen built into it's input side is clogged with gunk. Remove the valve from the unit and clean/check the screen. If it is clean the valve is toast and needs replacing. If clogged clean it. Do not permanently remove it from the valve as it is there to keep crud out of the valve, which could hold the valve popen and cause a flood.
Aug 05, 2012 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
My pool heayer will not light
check wiring they come for 240 volts if connected 120 volts some wiring to be changed or conversion board to be flipped to 120 volts some have you change the wire on the fenwal to 120 volts
Dec 06, 2011 | Jandy Pool & Spa
The generator produce onely 73 volts ac on the 120 volts plug and 146 volts ac on the 220 volts plug . what could be causing this problem
Check all wiring and fuses associated with you voltage regulator if they check ok, find a way to adjust your voltage regulator replace it. Make sure the unit is running at 3600 rpm as well and making 60 hz.
Jul 10, 2011 | Coleman Powermate Premium Plus 6250W...
Kitchenaid KESC307HBT4: Oven burners not working. All three failed together. Checked relay in drawer compartment and have 120 vac to the coil when "Bake/Start" is pushed, relay activates and...
On the control: Check voltage Connector J1-3 (Black wire to # 3) to any L2 red wire you should get 220 v . If not the bi-metal thermostat is probably open. If voltage is ok check with oven on bake between P 11 Red wire to L2 red (at main connection) should read 220 volts. If not the timer is bad if so check DLB relay . Take 1 wire off switch side of relay, activate bake. Coil side should read 120 v switch should read 0 ohms.Relay ok . Check between the wire you took off and the other wire you left on and the reading should be 220 v.
Nov 17, 2010 | KitchenAid KESC307 Electric Kitchen Range
I am only getting 120 volts to my dryer element
did you check your fuse box and the outlet,also check the block where the cord connects to the dryer and make sure your getting 240 there,could be a fuse or the cord, if that's ok L1 connects to the heating element through the timer, a thermal fuse, the operating thermostat, and the hi-limit thermostat. The heating element then connects to L2 through the motor centrifugal switch.you need to read these parts out to see what's bad,hope this helps
Feb 10, 2010 | Dryers
A/C inop
The compressor is brought in by a magnetic clutch, check the voltage at the clutch. If you get 12 volts at the clutch, then the magnetic clutch unit may be bad. Also if it has leaked out the gas, there may be a pressure valve that is designed to prevent the clutch from engaging
May 01, 2009 | Heating & Cooling
Maytag model MDE7057AYW 5600 Watts dryer runs ,but
5600 watts will not operate off 120 volts.
This is a 220/240 volt hookup.
There are 2 legs of 120 volts each that operate the dryer.
The only part requiring 220v is the heater.
Otherwise 120v routes through the various controls and relays.
Mar 12, 2009 | Maytag Dryers
Presto HeatDish® Plus Footlight® Electric Heater Logo
Top Presto Heating & Cooling Experts
Mack Baxter
Starnley Johnwells
Starnley Johnwells
Paul Carew
Are you a Presto Heating and Cooling Expert? Answer questions, earn points and help others
