Question about Insignia NS-DV2G MP3 Player
Usb connection my mp3 player says that my usb wire is connected when its not even plugged in. i can't turn it off or do anything! even when i do plug it in the computer says that there is no device detected. i don't know what to do!
    Novelist:
  • 170 Answers
Try taking out the battery and see of that helps.
If not, straighten a paperclip and insert into the RESET hole for 10 seconds (should feel a light click).
Make sure there's no debris in your USB port on the player.
Posted on Jun 25, 2008
Wriggly USB port
Typically this is the beginning of the end for your player. However there are some things to try. You can take a pair of pliers and bend ever so slightly as USB cable so that it places pressure on the bottom part of the connection on your MP3 player. I would try this with a cable you don't care for. I wouldn't suggest doing anything with the player. So many users bring my their blackberries that have the same issue. Most users do not come back to see me for quite a while or until the device is dead. These devices require tight connections, the only other option is pressure and that is what bending the plug does. Lastly, notice the two little notches that come from the wider side of the metal part of the USB connection. Are they protruding up even slightly? That may tell you something is wrong with your USB cables.
May 09, 2014 | Coby MP620 MP3 Player
My zen mp3 player won't turn on. It has been like this for two days. Yesterday I erase my files from the player and every since then, my usb plug won't respond to my computer.
The possible causes of the problem are:
1. Corrupted program.
2. Bad battery.
3. Loose wire connection.
If an mp3 device has a corrupted program, most of the time, it would turn on, but you cannot do anything. But there are times that the player will never turn on.
For defective battery or loose wire connection, the player will never turn on if it's disconnected from the computer. But it will turn on sometimes if it's connected.
For these possible causes, it's better to contact the manufacturer and have them check the player. Upgrading the firmware fix the problem for most of the time.
Thank you!
Feb 17, 2010 | Audio Players & Recorders
Mp3 will not work
disconnect the USB cable and let the battery run down when the screen goes blank you can reconnect the USB cable and the device will rechange and you can do you thing
Jan 04, 2009 | SanDisk Sansa Fuze MP3 Player
RCA M4002 mp3 does not turn on.
Download the latest firmware upgrade from www.rcaopal.com to restore the player. The firmware upgrade file will be on the "Download Upgrades" section of the website.
-Tha Mp3 Doctor
Dec 27, 2008 | RCA OPAL M4001 MP3 Player
Windows vista does not acknowledge Opal M4002a
If the player is not recognize try to connect the mp3 player ona different usb port and check if it will be detected if still not detected better connect this mp3 player to another pc and check if it will be detected on that second pc if not detected there's a possibilty that the mp3 usb functions is not working fine.
Jun 20, 2008 | RCA OPAL M4001 MP3 Player
Help me
reset it by pushing the "menu" button and "a/b" button at the same time for a few seconds then try turning it on...I tried this with mine when it was unresponsive and it worked.
Apr 02, 2008 | Samsung Yepp YP-T9 Digital Media Player
Help me
Have you check the USB wire you use, sometime's the wires are made to be faulty, try to use or change your USB data cable wire.
Mar 18, 2008 | Audio Players & Recorders
Phillips Go Gear 6GB
The Phillips website has a solution for this:
Go to the FAQ for this mp3 player. It'll tell you to install the Device Manger which will repair the problem. I've done this, however, the Device Manager claims my mp3 Player is not connected.
Try this yourself, you might have better luck.
Oct 27, 2007 | Philips HDD1630 MP3 Player
Wont read
There might be a problem with your USB cable, such as a broken wire, and not the MP3 player itself.
Dec 06, 2006 | SanDisk Sansa e140 MP3 Player
Always displays USB Connected
you need to reset your player turn it on and off hten plug it in the computer it will owork.
Jun 20, 2006 | iRiver iFP-795 MP3 Player
Insignia NS-DV2G MP3 Player Logo
20 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
