Question about DeLonghi Heating & Cooling
I have a PACL90model portable air conditioner bought it from a friend. It does not work as well as expected. I have cleaned the filter, made sure the air hoses are vented properly and still not very cool. Do these units need to be recharged? How big of a room should they cool? Thanks for your time. dellyndbushner@yahoo.com
  • dellyn2431 Jun 19, 2008
    Thanks so much. The area we are trying to cool is around 300 sq. ft., but it is not enclosed and there is a hallway. So it is probably doing as well as it can. Thanks again
    Scholar:
  • 104 Answers
A/C's should not need to be recharged unless there is a problem. They do not "use" freon the way a car could "use" a little oil. The best way to check is with a thermometer. Check the air where the unit is sucking in and the check the air where it is blowing out. The air coming out should be around 20-26 degrees colder that what is going in. Your unit is rated at 10,000btu or four fifths of one ton- it should be able to handle a standard, normally insulated area of approximately 300 sq ft.
Posted on Jun 19, 2008
I have ice shooting from my air conditioner, How can I solve this problem?
Good Morning Friend,
I understand you have ice shooting from your Frigidaire air conditioner, model# FAK104R1V, and want to know how to stop this from happening. First, check the air filter to make sure it is clean and there is no frost build-up on the cooling coil. If the coil is frozen, set your air conditioner to "Fan Only" mode, to defrost. Then set the temperature to a higher setting. Secondly, I suggest slightly tilting your air conditioner to the outside, to allow water drainage. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire FAK104R1V 10000 BTU Portable...
E4 Error Message
ok sir! are you sure is the sensor are cleaned? your unit need to general cleaning specially the sensors!
Oct 16, 2007 | Kenwood KW85 Air Conditioner
My portable. Air conditioner. Isn't cooling
Could be a number of things, Is the compressor running? If so, are the filters clean? ( Both the outlet and the inlet filters.) One at the front where the air comes out and one at the back where the air goes in.
Sep 07, 2013 | Portable Air Conditioners Portable Cooling...
I'm thinking of buying a 4 in 1 portable air conditioner. Does anyone know how much I should expect to spend?
As always,prices really vary and you need to shop around online. I've seen them forbetween $300 and $400. I came across this link to a site that has a Toshibamodel on offer http://www.breathingspace.co.uk/toshiba-supercool-portable-air-conditioner
Jul 17, 2012 | Soleus 4 in 1 Portable Air Conditioner
Where is the filter to clean on your air conditioner
Hello, typically the filters are located in the back of the unit.
Jul 15, 2012 | Maytag M6P09S2B Portable Air Conditioner
NewAir AC-14000E not blowing ice cold air
Unfortunately there can be several reasons for your AC-14000E portable air conditioner not cooling well. As with most portable air conditioners the filter grates on the rear of the unit can be removed for cleaning. When those are removed you may be able to clean some portion of condenser coils. There is also the possibility that your portable AC has a refrigerant leak in the system and will not be able to cool effectively without a repair (which usually costs as much as a new portable AC). Portable AC's are not designed to be recharged and operate on a sealed refrigerant line so even finding someone able to repair it may be a challenge. Your best bet is contacting the company you bought it from and talking through some solutions, they most likely have experience with these units and should be able to help you.
Jul 10, 2012 | NewAir Heating & Cooling
Haier Model HPR09XC7 is 2 or 3 years old and no longer cools as well as it once did. How do I fix this?
Try cleaning the filter if you have already done that find the condenser coil where hot air comes out make sure that is clean use a hose to clean the coil. If that doesnt work you probably have a refrigeration leak somewhere and need to scrap unit and buy new one. Portable A/C units are very disposable. If this helps please rate me and do a testimonial.
May 24, 2011 | Haier HPR09XC7 Portable Air Conditioner
I have HAIER HPAC 99ER Portable air conditioner and just quit working. There is a red flashing light blinking.
Make sure your filter & the coils (area under the filter) are clean or that the evaporated water is not overfilled by draining it manually by pulling the plug on the lower rear of the unit (into a bucket of course.) I'm hoping you had gotten an answer sooner...
Jul 19, 2009 | Haier HPAC99ER Air Conditioner
Danby portable air conditioner does not cool properly. what do I do?
what temp range are you working with here? are the filters clean? we need to know what Air on temp is and Air off temp.
Jun 24, 2009 | Danby Portable Air Conditioner
Heating & Cooling Logo
222 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
