Question about Canon PowerShot A70 Digital Camera
Canon SD600 Elph
Hello, my camera is posting the following error at startup each time: Lens error, restart camera. The lens is functioning fine, retracting and extending. Do you know how to resolve this? Thank you. Beth
  • Canon Master
  • 19,396 Answers
When the lens will not retract and camera is not functional (no picture on display, and does not shoot) , and you already tried replacing batteries with a new fresh set (ensure please) , and then restarting camera with no memory card inside, then camera is faulty.
Try an easy fix by pushing gently the lens (do not force them, just help them) while you turn off camera at same time. Try also switching the mode selector.
If still no luck , then the camera must be disassembled to fix the problem.
Possible reasons are :
  • Faulty lens mechanism or jammed lens (camera usually turns off by itself in this case)
  • Main board faulty.
  • Ribbon cable to main board broken or connector defective.
  • If there is no power at all it is the connector from batteries to main board, this is also a ribbon cable.
If the camera is less than one year old will be replaced by manufacturer.
If your warranty is expired you can get an estimate for repair from manufacturer, or from a third party like Advance Camera here :Advance Camera Repair you can book the repair online.
Posted on Apr 10, 2009
Lens error; restart camera
Try one of these two fixes, if they dont work for you follow the link below for further troubleshooting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: If the camera's batteries ran down completely while the its lens was still open, the camera may show a lens error or not start properly when new batteries are installed. Remove the memory card and keep it removed, then install the new batteries. When you turn the camera on with the card removed it may come back to life, as this triggers a reset in some cameras. Error E30 (for older Canon's) means that you don't have a memory card installed, so turn it off, slip in the SD card and turn it on one last time
Jun 15, 2010 | Canon PowerShot SD600 Digital Camera
My camera says lens error and to restart it? I don't know how to do that. It is a canon elph SD600
You can try turning it off and back on a few times, maybe even remove the battery for awhile. If the lens is physically damaged or dirty inside the assembly / gears, it would actually need servicing to fix this. You'll likely need to look for a repair shop, a great one and probably the most popular for these Canon Powershot cameras is camerasandparts.com as they only work on the powershots. They tend to be the place if you need help with a canon powershot camera. They don't charge much at all and they do all of the service on the camera too. Go to that site and you'll see they have your specific lens error problem posted right there for your SD600. Good luck taking care of it, that's a very nice Canon camera model.
Oct 21, 2009 | Cameras
Sir,
The problem seems that miniscule dust/sand particles jam the gears which moves the lens.
It is possible to turn the lens motor by hand bit by bit and remove particles stuck in the gear.
Also try restoring the factory settings and resetting the camera and seeing if that makes the error to go away. To do that, hold down the Menu button for five seconds. This should reset everything and (hopefully) make the error stop. If it doesn't, then you've got a separate problem-- come back and let us know if the error is still there. Also, if you have photos stored on the camera's internal memory, resetting the camera will delete those so make sure to download them first.
Thanks
Aug 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Powershot SD600 (elph) won't start. Error code "lens error, restart camera". Restart does not clear message. Removal battery does not help. Lens cover can be openned manually. Is there...
Hi
What you are seeing is a generic stuck lens error message:
Your lens needs to be cleaned, repaired or replaced. There are online places that will do it for a decent price and there are others that overcharge by way too much.
I know, because I own one that charges a reasonable price to do the repair! (Google 'darntoothysam')
Just let us know if we can help!
Good luck from
Darntoothysam com
Thomas
Oct 12, 2008 | Cameras
Canon powershot SD600
Looks like the lens is "out of alignment". Canon charges heftily for this repair. However if the lens is not broken then many people have got it working through systematic bashing. Click here to view the thread
Jul 16, 2008 | Canon PowerShot SD630 Digital ELPH / IXUS...
Canon Power Shot SD600 - Lens Error
http://photography-on-the.net/forum/showthread.php?p=5844033
Jul 09, 2008 | Canon PowerShot SD600 Digital Camera
Digital camera lens makes noise when extruding
Manually rotating sensor rotor inside camera and cleaning gear fixed the Canon "lens error" for me.
I placed instructions with photo's here: http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/
Dec 18, 2007 | Canon PowerShot SD600 Digital Camera
Canon SD600 lens jam
I followed the directions contained in http://www.avh.dds.nl/Fix-Canon-SD600-Lens-Error/ and by disassembling the camera and turning the rotor just a little bit (page 4 of the instructions), it freed up the lens and it is now working perfectly! The camera had been put down on the lens as the lens was retracting and I assume that jammed the retract mechanism. While the camera was open, I blew out whatever dust/dirt was there (didn't see much). The fix took me probably 20-30 minutes, and I am very pleased with myself!
Oct 24, 2007 | Canon PowerShot SD600 Digital Camera
Your Camera is full of sand and you can try blowing it out and banging it out. But I'd say it's time for a new camera. Regards Thestreeker
Sep 18, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Lens error
Lens mechanism has failed and a repair/replacement is the only solution-
Sep 01, 2007 | Canon PowerShot SD600 Digital Camera
Canon PowerShot A70 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
