Question about Dacor 36 in.PGM365 Gas Cooktop
Ignitor won't stop unless electricity off or flame burning
My GE Monogram gas range will not light. The igniter keeps going off but the gas will not light.
Hi, sometimes cooking spills stop the ignitor from working. Clean the cook top thoroughly and try it again. Spills can also make the ignitor go off randomly when you are not operating your cooker. Check if the ignition point where the zap comes from is not turned or bent too far from its original position. If you have a gas shut off make sure it is fully open to supply enough gas. If all else fails buy a cheap hand held ignitor to start your gas stove. If the cause is a spill which sometimes the problem can persist even after cleaning it may take a while for it to work again. If the problem is with all six burners then your ignitor probably needs replacing. When you hear the ignitor zap check to see if the electronic zap appears to jump across to the edge of the burner. If it doesn't it will not light the flame no matter how many times you try. I hope this helps you.
Aug 21, 2012 | General Electric GE Monogram 48""...
Burner will not ignite but electroic spark s are working, sparks will not stop after burner is manualy lit
I have had this same issue with continuous sparking after a burner was lit.
Problem 1. Wet or dirty ignitors/burners. Solution: clean and/or dry (I assume this resolves electrical issues). This has usually solved the problem
Problem 2. Stuck or dirty control switch. Solution: remove knobs and spray electrical-cleaner into switches. AMAZING... no more clicking plus burners now burn hotter when set to HI. I assume this frees-up the movement of the switch to prevent it thinking you are pushing it ON... and thus asking for spark... plus greater range of switch and/or higher flame settings available once lit. A no-cost miracle! ( I used "PureTronics" brand Electrical Contact Cleaner spray can, 1 sec, 2X).
Mike S
Sep 15, 2011 | Viking 37 in. VGSU161 Gas Cooktop
The ignitor keeps sparking and won't stop.Do not
First of all, the model number is under the cooktop bottom, and secondly, this can happen due to the burner switches got wet somehow. Best thing to do is to unplug unit for 6-12 hours, allow to dry, then re-plug unit back in, this should be enough time to dry out the burner switches.
Good luck
Jul 13, 2011 | Bosch Cooktops
My Viking vgsu cooktop has the igniter go on continuously when I try to turn on 4 of the 6 burners
My Viking stove igniter won't stop clicking. Both igniters on one side are clicking over and over
May 21, 2010 | Cooktops
BOILING WATER SPILLED OVER FROM POT INTO COOKTOP AND NOW IGNITOR KEEPS CLICKING
Hi, water is a great conductor of electricity. It is likely nothing to be concerned about in this case though, if you light the burners and allow the water to burn off/evaporate from the ignitors it should be fine. It happens all the time with gas ranges and cooktops. Once the ignitors are dry they will stop conducting/sparking unwanted. Hope that helps calm your concern. Thanks for coming to "fixya" for your solution. Please take a second after reading this to rate the info provided to you. Good luck. Macmarkus :)
May 02, 2010 | GE Monogram ZGU48N4GHSS / ZGU48L4GHSS...
Maytag clothes dryer flame won't stay lit
Usually this is the two gas valve solenoids, though it can also be a bad flame sensor or thermo. The solenoids are easy to change, they are right in front and usually have two screws holding them down. Order new solenoids by model number. Once you have the new ones you will see how they look and where they go on your gas burner. Just make sure you make not of the wire positioning and install the new ones the same way. Usually 3 wires on one side and two wires on the other. Parts are pretty cheap. Before I replace these I put an electrical testor on the solenoids to test if there is 120 volts coming in when the burner stops working. If their is 120 volts and the ignitor is glowing then you definitely have bad solenoids. Good Luck, Appliance Specialists.
Dec 15, 2009 | Cooktops
Gas ignitors continue to spark every 5 seconds in off position
try unplugging the unit over night, itspossible that by you cleaning the tops, the electrodes got wet, falsley sparkin, when the water dries out it should stop, and no not dangerous in any way, only annoying to listen to
Feb 13, 2009 | Amana AKS3040 Gas Cooktop
Stove-top burners
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range RepairBurners Keep on Clicking
heatman101
bvn
Jul 10, 2008 | Belling 27 in. CTC465 Electric Cooktop
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Cooktops Logo
Top Dacor Cooktops Experts
jdthefixer
Lakeland Appliance...
Are you a Dacor Cooktop Expert? Answer questions, earn points and help others
