Question about HP Officejet Pro L7580 All-In-One InkJet Printer
I installed recently HP officejet Pro L7480, but hP solution center failed to detect any device and closed. the officejet also failed to scan - error message: No scan option
    Scholar:
  • 73 Answers
Hi There, This is a known issue with this device. Please follow the below steps to fix this issue : Try to do a complete uninstall
*first step*
-run installation media (CD / Download) software
-select uninstall and on the process, select uninstall all hp softwares associated the with the device
-after uninstall , select restart later to reboot the computer later
-go to start > control panel > add/remove programs (XP) programs (Vista)
-uninstall any existing HP softwares (note: for hp computers, skip this process)
-restart later
*2nd step*
-open contents of the installation media
-if you're using the installation CD. go to my computer, select the drive which has your cd in (eg. E:/ , D:/ ) right click on the icon and select open / explore.
-if you're using a downloaded software, click on start and click on run (XP) startsearch (vista), on that box, type in the command ( %temp% ) and press enter. it will open up temporary files folder.
-locate the file that starts with 7z (eg. 7z001cs1) and open it and now you are in the contents of the installer
-on the contents of the installer, locate UTIL folder and open it then locate CCC and open it as well
(note: check your operating system if it is running on a 32-bit or 64-bit . you can check it going to start>control panel>system)
-on CCC folder , locate uninstall L1 (for 32-bit) uninstall L1 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
-on CCC folder , locate uninstall L2 (for 32-bit) uninstall L2 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later
on CCC folder , locate uninstall L3 (for 32-bit) uninstall L3 64 (for 64 bit) and run it. (note: there will be a command prompt box that will launch, press enter to continue) restart later (repeat uninstall L3 steps for 3 times)
**********important**********
(do not run uninstall L4)
contiunued in the next post ..............................
Posted on Nov 14, 2010
  • Anonymous Nov 14, 2010
    *3rd step*
    -go to my computer , open op drive C or ( c:/ )
    -open up program files and locate the folder named HP
    -open the folder and delete the folder named Digital Imaging (for any errors: select skip or ignore. if the folder will not be deleted, continue to the next step)
    -access configuration utility
    -click on start> run (XP) start> startsearch (vista) and type in the command (msconfig) and press on enter
    -you will be able to see a new window named configuration utility
    -on that window, by default , you will be under "General" which has the option Normal Start up/ Diagnostic Start up/Selective Start up. click on the tab named "Services"
    -on the services tab, put a check mark on (hide all microsoft services) then click on the button named disable all (note: make sure that the hide all microsoft services will have a check mark before you click on disable all)
    -click on apply and click on close
    -it will prompt you to restart your computer
    -restart the computer
    *4th step*
    -if you have a high speed internet, it would be best to download the latest software and driver online from HP's site by going to http://h10025.www1.hp.com/ewfrf/wc/softw...
    -if not, run the installation using the CD
    -after the installation, (DO NOT TEST THE FUNCTIONS YET)
    -select Normal Startup
    -click on apply and then close
    -reboot computer
    -when computer is up, locate the icon on the system tray (lower right portion of your desktop where your clock is located) named Digital Imaging Monitor
    -make sure that it has a check mark which designates that it is ready
    -right click on it and select launch/view solution center
    *test functionality*
    -close solution center and reopen it using the regular icon on the desktop
    *3rd step*
    *4th step*
    -if you have a high speed internet, it would be best to download the latest software and driver online from HP's site by going to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=2512008&lc=en&cc=us&dlc=en&lang=en&cc=us&submit=Go%20%BB
    -reboot computer
Hp Officejet L7480 false paper jam message. Resetting the printer has no effect.
Hp paper jam error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
May 20, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
Scanner error in HP officejet Pro L7590
These instructions will fix the majority of scanner problems and networking problems using ethernet:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01849855&lc=en&dlc=ro&cc=ro&product=3643612&rule=4124&lang=ro
The key is to assign a static ip address for the printer. The install problems of trying to get the HP printer to be found will go away. You can then use the scanner. Also...it is crucial that when connecting other laptop's and PC's on the same network that you use the hp printer'rs host name to find the printer on the network. I find that the IP address can and usually fails to find the hp on the network. Mostly likely you cannot search the network for a hp printer until you go the route of find the hp network printer with the host name of the printer. You will also need your install disk when installing on other networl laptop's and PC's since windows xp and Vista machines don't have the drivers in the list. You will need to point the add printer gui driver to the disk and look for autorun.inf
file. After selecting that file...you can then see your drivers.
May 14, 2010 | HP Officejet Pro L7590 All-in-One InkJet...
Hp L7480 Keeps printing an alignment test page everytime it is turned on. I now there is a key, something like # something that stops this from happening, I read it somewhere and fixed it the last time it...
I suggest that you uninstall the device and unplug it from your computer, then, use the installation disk and re-install the drivers, then plug er right back in.
You shouldnt have to have the print test page at bootup or startup every time...
Apr 05, 2010 | HP Officejet Pro L7480 All-in-One...
My Officejet Pro 8500 won't scan, says "no scan options"
Kindly install the scanner software for printer the driver software cd just re install it will install the scanner software and make sure in device manger there is not other usb device listed if it is there just remove it. And refresh it in will automatically install the driver.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 23, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
When I go to scan it tells me 'no scan options'. Have I bought a very large printer only?
According to the model specification the HP Officejet Pro L7480 is a scanner and a printer http://h10010.www1.hp.com/wwpc/uk/en/sm/WF06b/18972-18972-238444-3328086-3328086-3446481-3446611.html plese check this link and confirm the model etc. Also do check if you have installed all the drivers and softwares required properly.
Jul 05, 2009 | HP Officejet Pro L7480 All-in-One...
HP OFFICE JET PRO L7500/L7600/L7700
my hp office jet pro l7500 indicates the ink has expired in all cartages but the cartgages are new because they were just put in . Before the same error code came up and so bought new cartages. Also the door to the cartages will not stay closed without tape.
Nov 29, 2008 | HP Officejet Pro L7480 All-in-One...
Getting error when trying to fax or scan
The L7580 is not meant to be set up as a scanning device on a network. This unit can only function properly as a USB connected device to have all the features work. Also, for the software to install with out problems, all other All in One software fro previous HP printers need to be removed. Once we did that and did clean install using USB only then did it work.
Mar 03, 2008 | HP OfficeJet Pro L7580 Color All-in-One...
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
1,125 people viewed this question
Seeker5211
Seeker5211
