Question about Optics
Hi, I have a problem with setting up wireless connection on My webcam, I bought this webcam a China Vision CVLM-133 IP WiFi cam,and followed instructions I enabled it for wireless on the settings page of camera administrator page, following log on, anyway the image and everything is fine,fine that is until I pull the cable connection from the router to the camera, as soon as this cable is removed the camera link disappears from the log on page, therefore I can't log on, However as soon as I plug the cable back in the the rear of the camera from the router the camera link reappears and I can log on, to the camera page, I need to be able to remove this cable while maintaining a wireless link (it is not wireless because of this cable having to be plugged in), Because I did not buy this camera from China Vision they refuse to help, also the seller will not/cannot help me either. Please note that there is wireless link from router to PC, but not from router to camera (because of this cable connection having to be maintained),I therefore would be very pleased if someone can help me with this problem that I have, thanks, John
  • 33 Answers
Hi! i got cvlm-133 also and it works just fine.
Check the cameras wireless settings if it can find your wireless network. If not you have to check your router settings just remember cvlm-133 not work in N series wireless network
Posted on May 26, 2011
Why doesn't my netgear extender ask for name and password when I try to use it to connect to internet. It tells me that there is an authentication problem
Hi there! smile.gif Please note that the Tenda 150mbps Wireless Range Extender A3 uses a default IP address of 192.168.0.254 - you must set your IP address to the 192.168.0.* range (* = any number between 2 and 253) to login.
The default access username / password (if required) are admin and admin.
Once you've logged in, you can configure the access point to route through your existing wireless router as the default gateway (eg. if your wifi router is 192.168.1.1, then you would route through that, and set your Repeater (Extender) IP to 192.168.1.2 so that you can connect to it and then "relay" your connection through the repeater. It doesn't mirror the connection details for the existing wifi router, it simply creates an "additional" access point to connect through to your existing wifi router - creating a bridge, essentially.
The extender can be linked to the existing wifi router via LAN cable or WDS. For WDS, you will need to set the IP's 1 digit apart in the last segment (see above IP difference), and switch them both in the Wireless menu to ""Wireless Networking Mode: Network Bridge (WDS), but the SSID must remain the same (eg. "Tenda1") for both of them (it doesn't cause a network loopback), and any wireless security authentication must be identical (password / pass phrase / key + encryption algorithm) on both devices. Again, as with the above point, remember to set the gateway of the extender / repeater to that of the primary WiFi router.
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-...
Oct 26, 2014 | NetGear N300 Essentials Edition Wi-Fi...
I cant access the 192,168,2,1
For extra information and disambiguation (if required), see the following page, and scroll down: http://www.enjoypad.com/wireless-access-point/96-tenda-... Hope i helped you.. great day to you.
Jan 30, 2013 | TENDA A3 150Mbps Wireless Range Extender
How can I connect WiFi router to office network?
On your computer wireless card configuration, try changing the fixed IP address to the following -.
In the TCP/IP Protocol set Obtain an IP address automatically and set Obtain DNS server address automatically.
Jun 25, 2012 | D-Link DIR655 WiFi Router 4port switch...
I have a wireless router in a room next to mine which the internet runs to which works well. But i have the belkin n1 vision running off the computer in the room next door but i can not find the internet? ...
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi . Let me know if you need further assistance. Thanks for using FixYa.
Oct 08, 2010 | Belkin N1 Vision Wireless Router
How to lock wireless router?
You need to enable WEP security in router follow below procedure to secure your wireless network.Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on wireless settings then wireless security then enable WEP security and enter WEP key it is your password to connect wifi.Then save settings and restart router . Then when anybody try to connect your wifi it ask for that password. Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
I cant connect to the internet on my laptop i do have the wireless but cant connect to the internet
Press Fn +F5 key then turn on wifi. Also make sure wireless switch is turned on.Then check if sitll not connected then uninstall wireless network driver from add remove programs in control panel then reinstall. Then if you are able to connect wifi then still not access internet then follow below to configure wifi router. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN setting and set as your internet service provider settings.Click on wireless and enable it if it is disable then save settings and restart router. Then check. . Let me know if you need further assistance. Thanks for using FixYa.
Aug 11, 2010 | Westell Wirespeed ProLine 6100 Router...
When i try to connect to the internet by wifi it will not do it
First make sure wifi switch on laptop is turned on press Fn key +F5 then turn on wifi power . Make sure wireless network driver installed and enable in network settings. Check wireless led on router it should be on. Access your router with below method . If all settings of wifi router are fine then RESET it to defaults. For that press RESET button for 10 seconds it is in back side of router. Then configure it again with below method. Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN settings and set as your internet service provider settings enable wireless .If you want secure wifi then enable WEP security in wireless security then enter code it is your password for connect wifi. Let me know if you need further assistance. Thanks for using FixYa.
Aug 04, 2010 | Computers & Internet
CANNOT CONNECT TO WI-FI
First turn on the wifi in laptop then make sure your wifi network adapter tcp ip property that it get ip from router.
Aslo make sure router settings are perfect.
http://192.168.0.1
or
http://192.168.1.1
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Click on wireless settings enable wireless then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Jun 02, 2010 | Computers & Internet
My laptop will not conect to wireless unless it is wired to the router? is there a fix for this?
A couple of things to check.
Is the wireless router using WIFI? (Obvious question I know)
- If not, connect to 192.168.1.1
- Login = admin, password
- Activate wifi
If your router has it's wfi turned on, try the following;
- Start, Control Panel, Administrative Tools, Services and make sure WLAN Autoconfig is set to Automatic and started.
- Also make sure the following services are set to Automatic and started:
- Windows Connect Now
- TCP/IP Netbios Helper
- Simple TCP/IP Services
- Network Connections
Good Luck
Mar 09, 2010 | Belkin N Wireless Modem-Router F5D8633au4A
I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
Laptop normally have single chip WiFi or Wireless Cards...
These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the WIreless...ie, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
Setup laptop to Ad-Hoc
1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
2) Click-Wireless Networks Tab
3) Click-Add
4) Provide SSID Name, name to identify you rnetwork
5)Security -Net Auth: Open
6)Make -Data Encryption: Disabled
7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
TCP/IP on Laptop
-IP: 10.0.0.1
-Subnet: 255.255.255.0
TCP/IP on iPhone
-Static IP
-IP: 10.0.0.2
Now try searching for Wireless through your phone, you should able to connect..
Please leave me comment, if you need further assistance
Rnj VINODKUMAR
Nov 01, 2009 | Computers & Internet
Optics Logo
500 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
