Question about Saeco Odea Giro Plus Coffee Maker
Frothing Milk: It seems whenever the panarello sounds like a high screaming jet, it doesn't froth properly. When it's quiet, it does a great job. I froth EVERY morning. I've had this machine since JAN 2010. I HAD to descale a few weeks ago. Seems as if it started to do this shortly afterwards. I usually put the steamer to the bottom of my stainless steel frothing cup.
It seems it is partially obstructed by backflowing dried milk protein. Use appropriate cleaning fluid
Posted on Dec 31, 2010
  • stavropn Dec 31, 2010
    It seems that it is partially obstructed by backflowing dried milk. Use appropriate cleaning preparation. Descaling is something different
  • MLB1973 May 24, 2011
    I am having this exacct same issue - just got the Saeco Odea Giro Plus last month - have only used it a handful of times. I always remove and clean the Frother components after use. What would the appropriate cleaning fluid be for this issue? Would I use a different cleaning fluid and follow the descaling instructions, or clean by another method not specified in the manual? Thanks so much for your help!!
Hi, the steam from the wand is not frothing the milk like it used to, hardly any froth at all.
If the frother is warming the milk, but is not frothing, then you want to make sure the panarello is clean.
Slide the cover off the frother and check the pin hold on the top edge of the cover. If this hole is blocked the milk will not froth. Rinza is great clean to help prevent these issues. http://www.cerinicoffee.com/rinza_urnex.asp
Also recommend frothing water instead of milk to clean the frother well.
For more information visit: http://www.cerinicoffee.com/Coffee_cleaning_supplies.asp
Jun 07, 2011 | Gaggia Brera Coffee Maker
Milk frothing is very poor. I have had the machine for 7months and at the moment the frothing has stopped and milk is warm not hot. I have tried to adjust the frothing with the white wheel bu it doesnt...
Hi. Have you removed the white wheel and tried to clean it? Check the O-rings on the frothing part for damages.
Sometimes cleaning it hasnt helped at all, The solution for it that might sound crazy =) that fixed it for me at that time was to block the 2 holes with you fingers(be carefull its hot) where the milk comes out from when you make coffee, you get a little backpressure in the milk circuit when doing it. Try 2 or more times. It helpt me.
Oct 18, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
The steam wand is bubbling the milk, not frothing
THere is a little black tube inside - make sure its pushed out enough - about 1/16 an inch from the bottom. And you may have to clean it out. Happens to us too and after I do the above it works
Feb 13, 2010 | Gaggia Titanium Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
My machine will not froth milk
Nov 01, 2009 | Saeco Starbucks Sirena Espresso Machine
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
Frother doesn't froth
Does not seem normal! You should get plenty of steam for the frothing. Since the unit is new you should take it back and get a replacement. The unit needs to increase the temperature for steam, route the steam away from the espresso group to the steam unit and the pump needs to activate to create the high pressure. Any failure in this areas will create your condition. It also possible that your steamer is blocked but this is a new machine so this is unlikely but you should make sure that it is not blocked.
Sep 12, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Steam not frothing milk
Have you decalcify the machine, the boiler does not heat up if there is calcium in it.
Jul 11, 2008 | Saeco Incanto Classic Espresso Machine
Too much froth
Does this happen after you make several froths or the first time you start the machine? Try removing the panarello and froth milk that way then see if this is happening too without the panarello. I found that panarellos are great as a "quick learning to froth?- but they do have the tendency to froth milk too much without heating it up ( to the temperature that you like).
Jun 09, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Odea Giro Plus Coffee Maker Logo
416 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
