Question about Husqvarna Garden
Hello I have a husqvarna YTH22V46 riding mower that doesn't want to move. I have changed drive belt in the spring and it worked fine but now mulching leaves the drive has slowed. I have replaced the belt again but it still moves very slow or not at all. Is it possibly a bad pulley or tension spring?? THANKS
Bleed the air out of the transmission. Pull the lever at the rear of the garden tractor and disengage the transmission. Then fire it up and press forward pedal for ten seconds, then reverse for ten seconds. Do this a total of three times, then re-engage the transmission. I had the problem you did, but after reading you had questionable success changing the belt, I read the freaking manual and saw that you should do this when it's brand new. I figured it couldn't hurt, and voila, I could pull inclines again and go much faster.
Posted on May 25, 2013
mowerman1857
  • 389 Answers
SOURCE: Craftsman rotary mower, p/n 917.374821 will not move sometimes.
It is quite possible that one or the other of your pinions (item 55 in parts manual) has gone bad in addition to the wheels. Start the mower, engage the drive and lift the back end just enough to clear the ground and see if both wheels turn. If only one wheel turns, attempt to stop it from turning by setting it on the ground at an angle, if the opposite wheel does not turn, you will need to inspect the pinions.
Posted on Oct 30, 2009
SOURCE: i have a ranch king (purchased at rural king)
Did you Call Rural King? They should have someone there that can tell you. They also will fix it if you want them to for a fee. They have very good customer service.
Posted on Apr 29, 2009
  • 1114 Answers
SOURCE: Can a mulching blade work in a non-mulching mower?
True Mulching mowers have a specific deck design to them, but I would say yes to your question.It's been quite a few years, but I have done this little conversion myself - replace regular blade with a mulching blade. Just make sure the mulch blade does fit your mower. Also, use something substantial in terms of strength to close the discharge opening. There can be a good deal of force placed at the opening from flying debris. You'll also want to make the cover removable, so you can mow damp grass without the cover.
Posted on Jun 23, 2009
moretons
  • 155 Answers
SOURCE: I have a 1988 MTD
try the mtd site
Posted on Jul 25, 2009
  • 28 Answers
SOURCE: gaining access to change a drive belt on mower
the belt cover should have screws with the heads on top of the deck, then there is a guide which keeps the belt in the engine pulley with 2 or 3 bolts you might be able ot get it on the gearbox with just those off and a bit of prying etc.
Posted on Oct 03, 2009
MY HUSQVARNA YTH24K48 MOWER WILL BARELY MOVE FORWARD OR REVERSE. I CHECKED THE FREEWHEELING MECHANISM AND IT WAS WORKING PROPERLY. LOOKING UNDER THE MOWER AS WELL AS I COULD, IT SEEMED FINE.
sounds like the drive belt or belts are worn out. replace both in order for it to work properly .replacing one wont work. replace them as a pair.
Nov 05, 2016 | Husqvarna Garden
I need to route the belt on my Husqvarna YTH22-46 riding mower.
Please follow the link to the owner's manual, the belt routing is shown on page 18 of the pdf file, scroll through the pages at the top to get to page 18.
Husqvarna OWNER YTH22V46 Owner Manual Service And Adjustments
Aug 09, 2016 | Husqvarna Garden
Troy-bilt riding mower won't move in forward or reverse
I had a similar problem with my TroyBilt 50 inch zero turn mower. Was cutting grass when it stopped going either forward or backward even though it would start and the PTO would move the cutting blades. Turned out the tensioner spring for the belt that drives the motors near the rear wheels had gone missing. Searched the yard where I had cut and moved the machine but couldn't find it. A new one cost me about $7.50. Put the new one on and it worked fine.
Apr 19, 2013 | Troy Bilt 175HP Manual 42" Riding Mower
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a Husqvarna Lawn Mower YTH1542XP. when it is in gear to move, i have to use my foot to hold the pedal back for it to go. if i don't hold the pedal back, it barely moves. any suggestions are...
It sounds like the transmission drive belt is slipping. When you pull the pedal back you are increasing the tension on the belt. You may also want to make sure the spring that pulls tension on the idler pulley is in tact. Hope this gets you in the right direction.
Feb 23, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
How do I install a mulching Kit on my Husqvarna riding lawn mower?
having trouble with mulching unit on 22hp tractor.Mulching kit installed by dealer at time of purchase.What is happening is grass is kicking up on the top of the mowing unit,covering the belts and everything else.I need to do a major cleaning every time I use the tractor.Any one got some solution.
Apr 09, 2010 | Husqvarna 22 Hp 46" Deck Yard Tractor
Husqvarna yth2448 riding mower
you probably need to adjust the tension. if you look somwhere near the drive belt then you see a spring. tighten the spring to tighten the belt.
Jun 20, 2009 | Husqvarna Zero Turn Mower Z5426
Garden Logo
1,739 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
