Question about Theater Research TR-502 5.1 Surround Sound System Shelf System
Need a reemote for a model TR-501 - Theater Research TR-502 5.1 Surround Sound System Shelf System
Model tr-501. Why does it hum but produces no sound?
Is this something bought out of the back of a van? Toss it.
Nov 30, 2015 | Audio Players & Recorders
Tv reemote doesn,t work coby tv model 1926/is there a code I need ???
Surely. There will be setup code for this remote to your TV. Find it and enter it according to the synchronising procedure.
Apr 20, 2012 | Televison & Video
I need to know what ton is this
Please specify your unit model. with model even you can find out the tonnage.... e.g;;;;;; Model No....CIAN18TH.. It's 1.5 TR. 12,000 BTU is 1 Tr.......Shortly it mentioned as 12.......... like this...
Dec 08, 2010 | Heating & Cooling
Same Machine
In the 1990s SaniServ manufactured soft serve ice cream makers for slush puppy Corporation and call it freeze bee model A 501 which is the same machine as SaniServ model 501...........
if you go to www.saniserv.com or call their phone number at 317-831-7030 and give them your serial number they will give you all the information you need, when inquiring ask for technical help.
I have one and I really like it, does a great job, you need to fine the saniserv dealer closest to you for parts and supplys, they have everything you need.
Bob aviator state of Maine
Aug 31, 2009 | SaniServ 501 Twist 22 Quart Ice Cream...
Need software for my web cam pc 501
Hello samir, its quite simple to find drivers these days and softwares too. You just need to know the model name and number. Type the same and number in google and after that either type driver or software, I.e for example ur webcam name is pc 501, type pc 501 webcam driver or pc 501 webcam software and u should be able to download it over the net free of charge.
Jul 07, 2009 | Micro Innovations MCNIC50C Webcam
Steering column in a 1999 ford explore
you need to adjust the shift linkage and neutral - park safety switch.
Cable Adjustment —Shift Indicator
  1. Remove the upper instrument panel steering column cover (04459); refer to Section 501-12 .
  1. Place the gearshift lever in the (D) position.
    • Rotate the gearshift lever clockwise until it bottoms out (first gear), then rotate two detents counterclockwise ((D) position).
  1. Hang a 3.6 kg (8 lb) weight on the gearshift lever.
  1. Center the pointer in the middle of the (D) position.
    • Rotate the thumbwheel located on the bottom of the steering column to adjust the pointer.
  1. Remove the 3.6 kg (8 lb) weight.
  1. Carefully move the gearshift lever from detent to detent and compare with the transmission settings.
    • Readjust if necessary.
  1. Install the upper instrument panel steering column cover; refer to Section 501-12 .
Digital Transmission Range Sensor
The digital transmission range (TR) sensor is located on the outside of the transmission at the manual lever. The digital TR sensor completes the start circuit in Park and Neutral, the back-up lamp circuit in Reverse and the neutral sense circuit (4x4 only) in Neutral. The digital TR sensor also opens and closes a set of four switches that are monitored by the PCM to determine the position of the manual lever (P, R, N, D, 2, 1).
Jun 02, 2009 | 2006 Ford Focus
139 people viewed this question
Top Theater Research Audio Players & Recorders Experts
David Payne
David Payne
 Grubhead
Grubhead
Tom Chichester
Are you a Theater Research Audio Player and Recorder Expert? Answer questions, earn points and help others
