Question about Whirlpool Microwave Ovens
I need a part - Whirlpool Microwave Ovens
  • Richard Perkins
    Richard Perkins May 11, 2010
    Hi there!
    Can you be a little more specific please?
    Please give Model and part that is defective.
    Thank you.
  • Whirlpool Master
  • 9,086 Answers
Please reply back with your brand and model number and the problem you're having so we can help you.
Posted on Jun 23, 2008
I need the specs for GE Spacemaker XL JVM1339BW002 and need to know since I am replacing this unit w/another GE what type of venting do I need, and will I need to purchase a new trim kit?
The GE Answer Center can answer those questions. 800.626.2000
Give them your full model number.
I regularly repair these.
Feel free to contact me via my site with your full model number and FCC ID number as shown on the tag in or on the oven for more free help.
Nov 26, 2016 | GE Microwave Ovens
Fuse Specifications
Suresh,
Most of the time you will need either a 15 amp or 20 amp fuse for your microwave. You will want a ceramic fuse and if you still have your old one, the amp rating and all info you need will be stamped on one of the silver collars at each end of the fuse. Hope this helps!
Jul 09, 2015 | Microwave Ovens
KBHC109 magnetron needs replacing
So what is your question... do you need a meg tube, need to know how to replace, you need some one to replace.
Mar 27, 2012 | KitchenAid KBMC140HSS Convection/Microwave...
I need to replace the light bulb under my advantium 120 but my wife threw the lighbulb away I need to find out what size lightbulb I would need
I would think that you can find that info either in the owners manual or right in the area where the light resides. Usually there is a sticker there with the info you need. Best wishes!
Jul 29, 2009 | GE Advantium 120 Convection/Microwave Oven
Proline M-2020 microwave manual needed
Do you still want this - I have a paper copy which I no longer need
Mar 27, 2009 | Microwave Ovens
Reattaching rubber pieces inside microwave
I might need clarification, but household cement or even caulk should work as long as it's allowed to dry fully.
Dec 03, 2008 | Microwave Ovens
What is needed to install the Sharp R1880LS? Is a bracket needed? Thank you, Jill
If you don't have your installation instructions, you can download them here. You will need the free Adobe Reader to view or print this document.
It will tell you what parts are needed. The best place to order Sharp parts is Tritronics.
Jul 29, 2008 | Sharp Microwave Ovens
Door
The door part# is 4359542 if you need the part number. If you need to know how to replace the door check up by the upper hinge on the inside of the door should be a plastic piece that you can remove so if you lift the door off of its hinges. You may or may not need to remove the grill above the door to raise the door high enough
Oct 31, 2007 | Whirlpool MH7135XE Microwave Oven
Lost middle part of rotating plate
Find your model # on the sticker inside the microwave and go to http://www3.sears.com/ or http://www.appliancepartspros.com/partsearch/.  Should be able to view diagrams and find what you need here.  I could help you look it up but I would need the model # and the parts you need.  Would appreciate a solved rating for the advice unless you have further questions.
Oct 26, 2007 | Danby DMW902 Microwave Oven
Need to operate the microwave at 230 volts
You will need a step-down transformer of the appropriate power (wattage) and the proper adapter plug for the country you'll be in. You need to look on the back of the microwave and see how many watts it CONSUMES, not how many watts of cooking power it produces. Usually the power consumption requirement should be in the ballpark of twice the power output. For a 700W (cooking power) oven, I would suspect it has about a 1400W power consumption requirement, so your step-down transformer must be rated at least 1500W. That may be cutting it close, so for lower heat and longer transformer life, I would choose a 2000 watt model. You need to be sure it comes with an adapter plug that's made for receptacles in the country you'll go to. One site I found has them for about $60. but I would read up on the subject to see if you need one of an EVEN HIGHER rating since microwave ovens do surge when they start cooking. You may need to use one rated at 3000W or more. More info: http://www.dvdoverseas.com/store/index.html?loadfile=itemthg2000.html
Oct 11, 2006 | GE JES735WJ Microwave Oven
Microwave Ovens Logo
21 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
