Question about Goodman Heating & Cooling
I bought house when all the utilities such as gas, water, power were turned off. Every thing is turned on now. For some reason my heat is not working. I have Goodman Heating furnance GMT070-4. The gas volve is turned on. The Gas swtich is on also. This unit should ignite itself according to the instructions on the unit. I hear the fan turning on, then see the ignitor turning red hot. But it turns off in a minute. It keeps turning on and off every minute. Please help.
  • Goodman Master
  • 2,464 Answers
Did you purge the gasline when it was turned back on ? if you have air in the line it will take ages to come through
Posted on Nov 15, 2010
Does low water pressure influence water being heated? The flame does not ignite. Gas bottle(19 kg is more tan half full).
no--- as low pressure is what turns the gas on to heat up
high pressure turns the burner off
call a gas fitter to determine the real reason the flame is not igniting
Apr 09, 2017 | Heating & Cooling
Just bought my house and the water heater will not turn on is there a common problem with these that I can fix my self
Did they turn the power off to the heater before you bought the house?
Check there first. I used to shut the power off to ours when going on vacation. Check curcuit breaker if its hydro and if its gas make sure the the gas is turned on and pilot is lit.
Mar 28, 2015 | Water Water Heaters
Keystone manuals rv
You would need to buy a propane hot water heater. Unfortunately you can not convert an electric hot water hearter to propane.
I didn't want to use either an electric or gas hot water heater so I invested in a solar hot water heater for my home. Best thing that I ever did as far as saving money. Once it is paid off then the benefits are lower utility bills.
Good luck,
Marty
Jul 15, 2014 | Water Heaters
Hot water heater water, went out main line of house that enters house
You did smart thing turning off water and gas.
Play it safe.
Your water heater will NOT explode.
Conduct routine maintenance so water heater lasts longer. If plumber says you need new heater, then post question on fixya and include information showing on tank label on side of tank.
Also include why plumber says to replace.
Get another plumber.
Call city utility company to determine source of noise.
Dec 01, 2012 | Whirlpool Water Heaters
There are 3 houses each have to be be connected to the gas co, the electric co and the water co without the connections crossing paths
It is somewhat confusing with the information provided. So, 3 houses, and you need to have the gas, water and electricity come into the house without these 3 utilities crossing each other. I am an electrician and I can give you this solution from my experience. I rather like to have all the utilities enter a house at the same location. This gives me an area in the house where I have everything including telephone and cable enter and this allows me more space in the house because the utilities are not taking space in other rooms. So, water is usually installed from about 8 feet down in the ground. Electrical can be buried at 3 feet and the gas is the tricky one. The thing with gas and electrical is this. If you cross a propane line with electrical the electrical must be above the propane line by a minimum of 1 foot. Propane is heavier than air and will flow down in to a trench so electrical is above. If crossing natural gas, then the electrical is below the gas. Natural gas rises. Water is not a problem for either. I would check with local regulations for exact measurements and procedures.
Mar 08, 2011 | Garden
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
Is gas turned on with pilot light or electronic?
No pilot. Unplug the power to the unit and it cannot run/ignite. There is a shutoff on the valve behind the front panel if you want to turn off the gas supply without moving the dryer.
Jun 28, 2009 | Kenmore Dryers
No hot water
Aquastar 1600H NG Natural Gas Tankless Water Heater Bosch AquaStar Model 1600H NG Natural Gas Whole house tankless gas water heater, 117,000 Btu input, natural draft with hydro-generated ignition. Provides endless hot water for one major application at a time . Can replace 40-gallon storage tank water heater. Optional Accessory: Model AQ1- Power vent with built-in... More freeze protection when venting horizontally. Capacity: 1 to 2 Bathrooms Dimensions: 8.75D x 18.25 W x 29.75H Weight: 40 Max GPM @ 45F Rise: 4.2 Energy Factor: NG .80 LP .84 Minimum Input: 28,000 Maximum Input: 117,000 Vent Size: 5 Gas Connection: 3/4 Water Connections: 1/2 Warranty: 12-year warranty on heat exchanger, 2-year on parts Features: Endless hot water Can save up to 50% off utility costs annually Perfect for one major application at a time No standing pilot, hydro generated
Mar 01, 2009 | Bosch 1600H-NG Natural Gas AquaStar...
Furnace filter is black and sooty wall seem to be sooty
   By sealed unit you mean that the burner air comes from outside of the house?      You have checked the heat exchanger for cracks by removing the burners and looking with a mirror and flashlight, correct, or had a service tech so?
The furnace burners have enough air and are burning clean (blue) with just a tip of orange at the end? You bought the house new and the fireplace has never been used?  If it has been used to clean smoke for the house for whatwever reason I woudl start by havign the ducts cleaned.   Another possibility I have seen is insolation inside of ductwork breaking down.
Jan 28, 2009 | RTO Home Heating Products 5.5HH240...
Heating & Cooling Logo
82 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
