The spooler is not connected - Computers & Internet
    Genius:
  • 1,447 Answers
If you are getting an error message that states USER INTERVENTION REQUIRED or USE PRINTER OFFLINE, the printer driver may have become disabled. Please follow the directions below to resolve this issue.
Please note that the printer must be in an online state/Print mode.
WINDOWS 95/98/ME/NT/2000
1. Click on START, SETTINGS, and PRINTERS.
2. Highlight the icon of your printer with a single click.
3. Click on FILE.
4. The only check mark showing should be beside SET AS DEFAULT.
5. Ensure that there is no check mark beside PAUSE PRINTING or USE PRINTER OFFLINE.
6. Simply click on the check marks to remove it.
7. Try printing.
WINDOWS XP
1. (a. Click START select CONTROL PANEL and click on PRINTERS AND FAXES.
NOTE: If you cannot locate PRINTERS AND FAXES, Follow 1(b..
1. (b. Click START select CONTROL PANEL double click PRINTERS AND OTHER HARDWARE, and click on VIEW INSTALLED PRINTERS AND FAXES.
3. Click on FILE.
7. Try printing.
pls rate as fixya if helpful! thanks!
Posted on Jun 18, 2008
Prints the same picture nonstop, I have to shut the printer down to stop it. Now the printer does not react at all, almost like its not connected....??
Remove the power plug before stopping spooler to erase printers memory. and plug back in power when spooler service restarted.
control panel in windows operating system , services, print spooler, Stop the print spooler and restart spooler.
Mar 09, 2016 | Office Equipment & Supplies
When printing from the PC my PC says "the print spooler service is not running"the PC i'm using was communicating with the admin PC. is it possible for me to connect to the printer trough the offi
When you try to install a printer and get an error message "Print Spooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the General tab then select these items - Startup type select Automatic Service status click Start Then click OK
You can also try this WEB site
MICROSOFT PRINT SPOOLER FIXES
http://support.microsoft.com/kb/934885
Apr 02, 2013 | Office Equipment & Supplies
Print spooler subsystem stopped
Start and stop the print spooler Windows XP
To start and stop the print spooleropen Computer Management, click Start,click Control Panel, double-click Administrative Tools,and then double-click Computer Management.In the console tree, click Component Services.
Under Console Root click Services (Local)
In the details pane, double-click Print Spooler.Do one of the following depending on the task you want todo:
Click Stop to stop the service.
Click Start to start the service.When you try to install a printer and get an error message "PrintSpooler is not running" then Print Spooler need to be configured. Open Print Spooler as detailed above and click on the Generaltab then select these items - Startup type select AutomaticService status click StartThen click OK
May 12, 2012 | Office Equipment & Supplies
My printer is not working it tells me the spooler is not connected how do I restart the spooler
- click start and type services
- click services
- scroll down to printer spooler
- start printer spooler
May 23, 2011 | Computers & Internet
Windows could not start the spooler service on local computer when trying to connect hp c309a printer
If you the print spooler isn't working, you can either manually turn it off and on by going into your control panel - Administrative Tools - Services - Print Spooler - Then click the restart button.
The other easy option which usually works is just restarting your computer. This will restart your print spooler as well.
Hope this helps! :)
May 03, 2010 | HP Photosmart Premium C309A All-In-One...
I have a dell 942 printer, when i try to connect it to my dell computer, i get a message saying there's a problem with the printer spooler no working. How can i fix this?
Go to control panel, adminstrative tools, services, or just run - services.msc In services look for print spooler and start the service. If it will not start go to the dependency tab and check the other services that are dependent on the spooler and start them. Then go back and start the spooler
Dec 13, 2009 | Office Equipment & Supplies
Unable to get network connections to come up and printer spooler is not allowing to add printers. I recently purchased a aircard from sprint and the service went down and I was asked to install a smartview...
Hello ladynwaiting,
Try uninstalling the smartview software to see if network connections and the print spooler are working with the aircard. If that doesn't work then remove the aircard and reinstall it. Test the connections and print spooler again. The procedure works to reset the components. Finally, if that works, then install the smartview software and retest the connections and spooler. Hopefully your system will repond favorably to the above procedure.
I thank you for giving a rating to this solution if it has been helpful.
Have a great day,
martyshaw562
Jul 26, 2009 | Acer Extensa 4620 Notebook
Spooler
The spooler can then access configuration and status information from the printer....try log on as a administrator full acccess...if not works you need reinstall/repair your os
Apr 01, 2008 | Lexmark X75 All-In-One InkJet Printer
Computers & Internet Logo
168 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
