Question about Samsung SL420 Digital Camera
My camera says card locked when I try to take a picture.HELP
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Nov 14, 2010
  • Amy_Calubaqu Nov 27, 2010
    hello,,how are you,,,,,thank you so much for helping me for my camera,,,,,,god bless you always,,,,,thanks a lot...........its me amy,,
  • Ruby Nakka
    Ruby Nakka Apr 05, 2014
    Thanks a ton. It worked.
SOURCE: "the card is locked"
try seeing if there is a button on the side of the card that moves up and down... sometimes it gets switched and locks the card...
Posted on Feb 11, 2007
SOURCE: Card Locked ! Error
Remove SD card, then whilst card is removed, delete all pictures that may still be stored in cameras 'internal' memory (usually just a few) then replace SD card. Should be unlocked now?.
Posted on Dec 03, 2008
RPFinney
  • 385 Answers
SOURCE: my camera wont take pictures says card locked
There is a lock on the SD card
Check this is good.
Regards
Richard.
Posted on Apr 21, 2009
SOURCE: when i try to take pictures my camera says card locked.
It's the memory card or SD card you have in the camera. (it sounds like)
Try taking the SD card out and if you look at it closely there is a little switch/ thing you can slide. Slide it to the other side, put it back in your camera and try again. Hope that helps
Posted on Jun 24, 2009
nirmaljose
  • 128 Answers
SOURCE: My samsung camera L313, Keep saying card Locked
  • connect it to the computer
  • look weather threis any hidden or zipped file or folder
  • if any unzip it or unhidden it
Posted on Nov 04, 2009
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
When we try to take a picture on our Vivatar Camera it says,card locked. Please help us with this problem.
Most likely your sd card is locked. Try removing the sd card and moving the small white tab on the side of the sd card from locked to unlocked and give it a try.
Lewis
May 15, 2011 | Vivitar ViviCam 5024 Digital Camera
Every time i try to take a picture "card locked
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Jan 03, 2011 | Samsung Digimax S500 Digital Camera
When i try to take pictures my camera says card locked.
Jun 02, 2009 | Samsung S860 Digital Cameras. 8-megapixel...
Casio Exilim EX-S880 how to unlock card
hello, check your card for a clip and see if its in lock position. set it to unlock.
also check if your card is compatible for you cam.
Mar 24, 2009 | Casio Exilim EX-S880 Digital Camera
When you try to take pictures it says card locked
on most memory cards, there's a switch that prevents writing to the card. It's on the left edge. Make sure it's "up" (toward the connectors) and not down.
if that doesn't help, try a different memory card. If it still happens, then we know the problem exists with the camera and not the card.
Dec 31, 2008 | Polaroid i531 Digital Camera
Memory Card Locked.... how do I un-lock it?
there should be a little swith on the side of the card. switch to the opposite and then try
Dec 20, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Card Locked ! Error
Nov 10, 2008 | Samsung Digimax L830 Digital Camera
Card Locked , HELP PLZ !
Hi, I have a soloution I have literally just done it, for some reason the cards arn't going in camera far enough, get a little bit of card from a box and put it on memory card before you close the door, when u close the door it pushes the card further into the camera you can then format it and take pictures. it does work as i have just done it regards kev
Feb 12, 2008 | Samsung Digimax 4010 Digital Camera
Feb 11, 2007 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Samsung SL420 Digital Camera Logo
179 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
