Question about Bose Companion 3 Computer Speakers
Bose Companion 3 series 1 problem
Hi. My Bose companion 3 series 1 speakers stopped working properly today. The LED on the control pod is very dim and a very very low sound comes from them. I hooked them up to my ipod and the same thing happens. I opened up the case, everything looks ok and nothing smells bad. Could the coil mounted inside the case be the problem? Omar
  • Anonymous Jun 23, 2008
    does the system has a fuse somwere?
  • joe2335 Feb 13, 2009
    Exact same issue. Hoping for a solution...
5 Suggested Answers
  • 5 Answers
SOURCE: Bose Control Pod won't work
Try changing the plug on the control pod, those plugs are fairly weak and prone to breakage. Does there appear to be any strain at all on the plug itself? if so then that is where I would start. If you have a series 2 then I can help you, or if you can find out if the 2 control pods are the same, that would be fine too, but I have a series 2 system companion 3 and if needed I will cut my cable to trace the wiring and then replace your plug for you. my cost for this would be $40, that includes return shipping with priority mail.
Posted on Jan 02, 2009
ginko
  • 19396 Answers
SOURCE: where can i buy a
Check ebay or ask Bose:
Bose Companion 3 Handy Control Pod $32.50 - eBay
Bose Companion 3 Control Pod $33.99 - eBay
Posted on May 01, 2009
  • 10 Answers
SOURCE: Where Can I purchase a bose companion 5 control pod?
you have to call customer service at 1-800-367-4008.Run about $35.
For the broken cable, have you tried to fabricate a new cable for it?
Posted on May 25, 2009
fixyathing
  • 341 Answers
SOURCE: Bose Companion 5 Speaker System won't work
check if the volume control needs to be replaced. volume controls gets bad in due time coz of the carbon layer which gets thinner and thinner till it gets cut off
Posted on Aug 12, 2009
SOURCE: Control Pod for Bose Companion 5 speaker system
I had the same problem right out of the gate, the volume dial on my control pod for my Companion 5 wasn't working, however, the touch pad and LED worked. I called Bose customer service and was instructed to:
First, unplug the power directly at the back of the woofer while the unit was on;
Next, I was instructed to unplug the control pod, visually inspect for any damage/defect;
Finally, re-seat the control pod on the back of the woofer and then lastly plug the power cable back into the woofer.
It worked like a charm. I hope this is helpful!
Posted on Jan 26, 2010
Control pod failure on bose companion speakers , the sound stops
check your wiring connections, sounds like you may have intermittent connection somewhere, and this is the most likely culprit. be certain that all connections are solid. multi pin plugs are notorious for having one bad pin.
Mar 06, 2015 | Bose Companion 5 Multimedia Speaker System...
Bose Companion 3 Series 2 Multimedia doesn't work.
Maybe a tranformer burnout, this is the most common cause, refer to a Bose service center
Jun 15, 2014 | Bose Companion 3 Series II Multimedia...
I've had the series 1 companion 3 for almost 4
Hi, This could just be a sign that your Speaker system is wearing out , and done its due...Also have you had any Power Failures or surge's Lately , if so then it could of damaged the Speakers aswell..
Hope you come right bud
Happy new year
Dec 28, 2009 | Bose Companion 3 Computer Speakers
"This device has no output controls" Bose Companion 5 problem!
Metal detectors/ Xray devices have been known to destroy magnet based electronics (speakers). This could be your problem.
Sep 22, 2009 | Bose Companion 3 Computer Speakers
Aug 12, 2009 | Bose Companion 3 Computer Speakers
Bose Companion 3 Series II not working (Mac)
The speakers seem to be muted by default - you'll see that the LED is yellow/amber. Tap the control pod - the LED will turn green and speakers will work. I felt like such an idiot after I spent almost an hour trying to figure this out. (This feature should be more prominent in the manual.)
Dec 20, 2008 | Bose Companion III Computer Speakers
You can purchase it from amazon, click here Amazon com bose control pod and choose, which one fits to you.
I hope I was helpful
enjoy
Nov 25, 2008 | Bose Companion 3 Computer Speakers
Control pod on bose companion 3
try to check the circuit board with an expert
Nov 16, 2008 | Bose Companion 3 Computer Speakers
Oct 03, 2008 | Bose Companion 3 Computer Speakers
Companion 3 problem
It is not the pod that isn't working, a 220v power supply would overload the circuitry in the subwoofer. And since the damage is done, a step down converter would be no help at this point. I would take it to a electronic repair shop and have them take a look at it.
Aug 11, 2008 | Bose Companion 3 Computer Speakers
Bose Companion 3 Computer Speakers Logo
986 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
