Question about Ovens
I have a 1957 ge wall oven model JC12. It has been working fine till yesterday. Lights come on, oven temp light lights, oven set light is dim and oven does not heat up. Is this a thermostat problem and can this part be found to be replaced? thank you, Cristopher Ramos
  • casachristop Nov 26, 2010
    thank you for the advise, the wiring to the oven selector was corroded and has been replaced. oven good for another 50years. thank you!
    thank you for the advice.wiring to oven selector was corroded and has been replaced.good for another 50 years.
    President:
  • 1,891 Answers
It may be a thermostat but first ck the bake element and the wiring to it . if found ok then go for the thermo.. but at its age it very well gould be a thermo. mm feed back pls . and also ck the power to the oven making sure the two lines 220 ar ok .. mm
Posted on Nov 15, 2010
  • dennis dodge Nov 26, 2010
    good going .. ya did good and good luck on the next 50 yrs ..mm and thanks for the feed back .
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Lights showing oven temp are too dim to read -- difficult to set oven temp. model feb756cetf self cleaning wall oven
Good Morning Friend,
I understand the control panel is dim and hard to read, on your Frigidaire oven, model# FEB756CETF. Please try resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and set the clock. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 07, 2014 | Frigidaire Ovens
Oven lights and works fine till it reaches set temp then panel goes blank and oven shuts off
Check the cooling fan inside of your control panel. Most likely the computer board overheats and shuts itself down.
Oven repair in Santa Ana, CA
Appliance repair in Santa Ana, CA
Jan 25, 2011 | GE JGRS14 Gas Single Oven
Oven never gets to set temp.
This is the sign of a weak ignitor, even though it is glowing it has gotten weak and not letting enough current get to the valve to open.
You will need to have the ignitor replaced.
May 13, 2010 | Ovens
My oven will not heat up ge jtp4850f1ss
check elements. if good replace the main clock board
Feb 06, 2010 | GE JTP48SFSS Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Oven digital lighted display is dim
mY 27" WALL jENN air blows cold air out the vents when on cleaning cycle. The red buttons aren't lighted. The door locks, otherwise it bakes fine. I wonder if it is really cleaning?
Feb 16, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Lighted clock and controls intermittently not working. Oven still heats
HI thanks for the question. its a common problem with the clocks. first it goes a little dimmer. then a little more till it goes so dim you cant even see the temperature that you have in the oven. the clock has to be replaced. or. buy a cheap oven thermometer. and hang on the middle rack, and adjust the temp setting to match the oven temp . save a lot of money this way. thanks. please rate my answer. thanks
Oct 09, 2008 | Jenn-Air Ovens
GE Profile -Installed wall oven - won't heat
brand new??? under a year old??? if so you have a warr call for service, but it sounds like an ignitor isssue, brand new , perhapsgot damaged in shipping 1-800-ge-cares
Mar 29, 2008 | GE Profile JTP56 Electric Double Oven
Light for the temp. & time very hard to see can it be made brighter?
then you will have to replace the eoc the electronic oven control as long as it was working id use it till it wasnt then replace it
Jan 19, 2008 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
132 people viewed this question
Top Ovens Experts
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
