Question about Frigidaire FFBC46F5LS
I have a Frigidaire Beverage Center Model FFBC46F5LS It was installed on Friday and worked fine until today (Sunday) where it has started to beep constantly. If I press the light button at the bottom of the unit beneath the door it stops for a few minutes then begins again. The door is closed so I can't determine why it needs to beep. Of course the manual says nothing about it making a beeping noise. HELP!
I recently purchased a Frigidaire Beverage Center and had the same constant beeping issue as strivieri. I found my problem to be the door sensor. The door sensor is located on the lower bottom right of the unit and there is a metal plate mounted on the swinging door that is suppose to push that sensor in when the door is closed. However, this was poorly designed as it fails to do its task. I had a few adhesive floor protectors laying around that I used to stick to that metal plate that gave it the extra thickness needed to push in the door sensor when closing the door.
I hope this helps anyone else there having the same issue.
Posted on Jun 05, 2011
Danby DWC2121BLS dual commpartment wine cooler is cooling normally but after 2 days aprox the temperature increase and beeping and flashing hi
If evaporator starts to freeze up the ice accumulated serves as an insulator and the temps go up. If you turn it off and let ice buildup melt the unit will work fine again until it refreezes.
Check if unit has a device to prevent ice build up. If so, it is not working. If warm moist air is entering the area of evaporator coil, that could also be causing the buildup.
Sep 26, 2016 | Danby Silhouette Dual Zone DWBC14BLS 13.90...
Frigidaire ac unit model number fra065at7 keeps resetting
I'm willing to bet the unit is not draining properly. Be sure it is level or pitched outside and the water is draining. Good luck.
Mar 26, 2017 | Heating & Cooling
Frigidaire Side-By-Side not dispensing water and possibly ice
It is possible the water line inside the refer is frozen, you will be able to see a resevoire or loop behind the bottom drawers that is where it could be frozen
Mar 24, 2014 | Frigidaire FRS6HR35K Side by Side...
Frigidaire ffbc46fsls beverage center refrigerator does not resume "on" condition after power glitch. If the unit is unplugged while running, then plugged back in, it resumes normal function,...
Wow if you have lost that much because the memory dumps during a power failure then we are going to need do something serious about that! May take me a while to come up with a solution but being the case I think you have a serious point to make. Acording to The
Frigidaire FFBC46F5LS Beverage Center User Manual
and on page 7 of the PDF
The default temperature for the beverage cooler is 41°F (5°C). The temperature after power failure will be the temperature set before the power failure. So something is wrong with the control board part=> Pc board,input ,display I believe I would call USA 1-800-944-9044 and ask why that may be happening. Below is a parts list.
Frigidaire FFBC46F5LS Beverage Center Parts
Hope this helps, Thanks, Sea Breeze
Sep 03, 2011 | Frigidaire FFBC46F5LS
I just bought a brand new Frigidaire 4.6 cu beverage center FFBC46F5LS, brought it home and plugged it in. Ran it overnight and still at room temperature. I can hear the motor is on, light is on. not...
Being it is brand new you should contact Frigidaire about getting it repaired or replaced under warranty.
Frigidaire 1 (800) 374-4432
Monday - Sunday
8:00 am - 8:00 pm (EST)
Aug 03, 2011 | Frigidaire PLKU1267DS Stainless Steel...
RE: Intermatic model T8845PV used for a sprinkler system. The system works fine on manuel but does not come on on the days selected when on automatic. Day pin is pulled out and aligned with 12 0r 14...
1) Check that yellow timer dial is rotating and keeping correct time > if not, then buy new clock motor
2) Check that silver tripper pin is installed at 12 midnight. This tripper advances day-skipper wheel each day at midnight. Check that tripper is advancing the skipper wheel.
3) Rotate skipper counter-clockwise until current day lines up with 14 arrow.
4) Check gold tripper pins are pushed in place.
Open following links for parts list
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
http://waterheatertimer.org/pdf/Setting-Intermatic-sprinkler-timer.pdf
Apr 03, 2011 | Intermatic Hardware & Accessories
Hi, my weather widget won't update, it worked fine until last week. The widget shows on the screen with a message saying touch here to update, when I do it takes forever then it loads last Monday's...
mine has been doing the same thing since Friday, and my wife's phone started doing this on Sunday. I called T-Mobile and all they can say is that they are looking into it.
Jan 24, 2011 | Cell Phones
I want to know where is the HTC servive center in kolkata
Kolkata Cell-O-Service P -17 Mission Row Extension, Kolkata - 700 013
Monday to Friday :
10:00a.m. to 6:00 p.m.
Saturday :
10:00a.m. to 4:00 p.m.
Sunday and Public Holiday - Closed
Service center:
Cell-O-Service
Prefered time to visit:
Monday to Friday :
Saturday :
Nov 28, 2010 | Computers & Internet
The remote for my garage door only works on weekends.
Monday through Friday look at the LED on the rear of the motor unit. If it is flashing rapidly you have radio interference. See if you can locate the source. It will be something electrical - maybe a military base if nearby.
Jun 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
We were installing a panasonic strada cn-nvd905u it was working fine untill we disconnected the battery to install amps after we disconnected the battery it reseted the panasonic unit now its asking for a...
1-800-211-PANA (7262),
Monday-Friday 9 am-9 pm; Saturday-Sunday 10 am-7 pm, EST.
If you forgot the code, the unit is ussless without it and can only be changed if you know the code. Try the number above for more assistance.
Jan 25, 2010 | Panasonic Strada CN-NVD905U GPS Receiver
Open Questions:
Frigidaire FFBC46F5LS Logo
1,249 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
