Question about Refrigerators
The unit quit working but all the lights still worked. We checked the compressor with an ohm meter and got a good reading. We found the switch connected to the compressor rattled and I was told it was bad. I had a jump start unit installed and the unit came on, but then went off after a short time (minutes). Now the lights don't even work, but we still get a good reading when we check it with an ohm meter
    President:
  • 1,891 Answers
I agree with the rattle test . it was i belive bad . so are you sure the jump start unit is a good one . and what kind of unit was used .. you need a 1/3 hp start kit and if it uses a cap to run it must be wired properly to do this . it's best to use factory part if you can . if it ran when you installed jumpp kit i think comp is maybe ok and start kit may be problem . mm hope this helps , feed back pls .
Posted on Nov 15, 2010
Front panel has no lights working, inside main light still works and turns on, top temperature control is off. Whats wrong?
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts.
MAY HAVE A BAD START RELAY OR CAPACITOR ON THE COMPRESSOR , CAN BUY A INEXSPENSIVE 3 IN 1 HARDSTART KIT AND BY PASS THEM , NOT THAT HARD TO DO, COMES WITH INSTRUCTIONS> BY THE WAY DO U HEAR ANY CLICKING SOUNDS FROM COMPRESSOR? BUT U MAY ALSO WANT TO CHECK UR COLD CONTROL THERMOSTAT IF IT GOES BAD U MAY GET A NON START ALSO HAVE IT CHECKED FOR PROPER VOLTAGE AND OHMS RESISTANCE WHEN IN THE ON POSITION
A BAD DEFROST TIMER though seldom CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
to check the defrost timer, u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
AT TIMES YOU MAY HEAR THE COMPRESSOR CLICK OFF AND ON OVER AND OVER. Signs of a bad start relay or capacitor. Check with an OHMS meter for continuity (ohms) and voltage, capacitor can be checked for Microfares. ( if in series with the windings)
To check ur compressor with multi meter:
Disconnect and remove the relay and capacitor from compressor, sometimes located next to compressor in a casing.
You wills see 3 prongs coming out of compressor. 1 goes to ur start winding, 1 goes to ur run winding and the center goes to ur ground or COM
Place ur meter connector or prong on the start prong and the other on the ground (center prong) take note of the reading in OHMS for example 5 ohms.
Next place meter prong on run prong and the center ground prong agin. Take note of the reading in OHMS. Example 4 ohms
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms, u have a short in ur compressor. It should show infinity
God is so good: so this is why I give free advice so please thank him not me.
TO REPLACE RELAY AND CAPACITOR WITH A HARDSTART KIT YOU CAN USE
A 3 in 1 start kit for compressors sizes 1/4 through 1/3 HP. And a 5 in 1 for higher H.P. (BE SURE TO MATCH WITH UR COMPRESSOR MODEL NUMBER AND TYPE) The kit includes relay, capacitor, and overload device, pre-wired. The kit will replace all 3 electrical components on capillary refrigeration systems. For newer systems with a run capacitor use proper kit. For smaller horsepower compressors useTJ90RCO810.
The wire set up is as follows the red wire goes to the right side of compressor prong, the white wire to the left side prong, the black wire to the center prong, and the 2 other black wires go to the power and the ground connection
Dec 24, 2015 | GE Profile PSS29NHS Side by Side...
Stopped working ,has inside light ,control panel no display,unplugged and repluged still not working ,removed back panel cleaned out dust ,and repluged still not working
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts. I think God os good that's why I give free advice?
A BAD DEFROST TIMER CAN SHUT DOWN COMPRESSOR HAVE IT CHECKED WITH MULTI METER.
Disconnect and remove the relay and capacitor from compressor, somes located next to compressor in a casing.
Next place meter prong on the start prong and the other on the run prong, now take note of the reading example 9 ohms. Now match the total of this ohms test with the total of ur two separate test. 9 ohms, if they match ur ok give or take 5 percent plus or minus. One more test to make to test of there is a short in compressor attach meter prong to ground prong and rub the other end of meter prong to metal ( scrape the metal clean of paint and test on metal surface not painted surface. If it shows continuity or ohms , u have a short in ur compressor. It should show infinity
May 17, 2015 | GE Refrigerators
ROPER REFRIGERATOR WILL QUIT WORKING. I UNPLUG IT FOR A COUPLE DAYS AND WHEN I PLUG IT BACK IN IT WORKS FOR A COUPLE WEEKS. THEN IT QUITS AGAIN. WHAT WOULD CAUSE THIS?
You wills see 3 prongs coming out of compressor. 1 goes to ur srtart winding, 1 goes to ur run winding and the center goes to ur ground.
Apr 08, 2015 | Roper Refrigerators
Why wont my Candy Fridge and freezer turn back on after 3 months off?
Mar 25, 2015 | Candy Refrigerators
I have a Kenmore Cold Spot Ref Model # 106.56722600 Serial # ST3331304 that has quite working , I have checked the power to the Ref and it is on but the light nor the Ref or Frezzer is working
Feb 25, 2015 | Kenmore Refrigerators
Hy Water dispenser is not working, temperature control not working,turbo cool and express chile are not working.
Fridge not starting? CLICKING? FIRST ALWAYSCHECK FORpower at the outlet,checkfor 120 volts. I think God is good that's why I give free advice?
Aug 04, 2014 | GE GSS25LGM Side by Side Refrigerator
Have a 3 slide door refrig-freezer. Quit working, threw the breaker switch. I pulled the electrical box cover and capacitor was blown. Replaced capacitor, started up again and within 3 minutes quit working...
We need to find out if the compressor has had a burn out first. If you have an ohm meter and a few minutes we will know. Let me know, I hope not, but let me know if you want me to tell you how to test it, Sea Breeze
Jul 18, 2009 | Beverage-Air Refrigerators
Model # PYE4500AYV Serial # 11168132AV. The dryer just quit
are getting power to section switch, any internal fuses. also check the safety switch on the door.
Jun 24, 2009 | Dryers
Cruise will not light up or work on 95 Riviera
Check the switch to make sure that it works first. Remove the wire harness from the switch and use a self-powered test light or an ohms meter to see if you have continuity (the light lights or the meter reads 0 ohms) if the light lightsa sporadically, or not at all, or the meter reads high, or infinity, replace the switch. This has been an issue on my car as of late. Also check the fuse holder to make sure there is power there as well. No power means there is a wiring problem.
Dec 25, 2008 | Buick Century Cars & Trucks
The left front radiant heating unit does not heat. All other are working fine
Check the heating unit with an OHM meter.
This is not rocket science. An OHM meter will check for continuity (a break inside the heating unit). Any appliance parts place will have a meter, even Wal-Mart. The meter can be set for AC/DC/ OHM's, Volts, etc.
Set the meter on OHM and touch the two leads on the meter together and the meter arm should move. Now, take the heating unit out of the range and touch one lead to one end of the heating unit and the other lead to the other end. If you get a reading then the unit is good and the switch must be replaced.
No reading, replace the heating unit.
Some parts require knowing how many OHM's but in this case any kind of reading will show there is no break inside the unit (continuity).
You can check extensions cords this way or set it on volts and check batteries. Everyone should have one.
Dec 17, 2008 | GE Profile JSP47 Electric Single Oven
Refrigerators Logo
29 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
