Question about Kenneth Cole Strap KC1405 4 Watch for Men
How does one change or set the date on the kenneth cole KC1405 watch?
5 Suggested Answers
SOURCE: Kenneth Cole Reaction watch date set problem
I just dug my watch out after not wearing for a few years and had the same problem. There is an easy way to adust this watch's time and alarm, basically one way to enter both.
1) With the watch in the regular time display mode (doesn't matter if 12 hour or military time), depress and hold the lower left hand button (mode button). After a few seconds the watch appears to shift to alarm mode and it is blinking. This puts you into the mode for adjusting the alarm.
2) If you want to adjust time, date, etc rather than alarm time, after you have done step one, simply press that same lower left button again, and then it will put you into the time mode, but this time the time mode is blinking and you can adjust the various components (seconds, minutes, hours). You can only move minutes, hours, etc forward, no way to move backward. You will start off with the second display blinking, probably skip that unless you need to adjust seconds. Depress the upper right button to shift to the next option (minutes) and you will see the minute display blinking. Adjust the minutes by depressing the lower right button. When finished depress upper right button to move to next option (hours) depress the lower right button to move the minutes/hours/month/date forward as necessary, when you finish just press the lower left button again and it pulls you out of adjust mode and you are back in regular time viewing.
I had to post this because I've had this problem in the past and it killed me. Its kind of intuititve after you get into the adjusting mode by pressing the lower left button- remember, initially it will put you into adjust alarm mode, but press again and you will get into adjust time mode.
Posted on Nov 12, 2008
escapement
  • 2334 Answers
SOURCE: Kenneth Cole Wrist Watch unable to remove link
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and start to unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet,make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
Hope it'll help.
Regards
Arthur
Posted on Dec 17, 2008
  • 93 Answers
SOURCE: Setting a Kenneth Cole Digital RK1202 watch
you can find an exper in the local shop where you buy the product and they will give you specific service for your questions about your product.
In addition, and i like to play world of warcraft. there is a reliable website for
all players to buy world of warcraft gold with the lowest price wihit in 10 minutes' fast delivery and you also can enjoy first class service when your login.
Posted on Jan 07, 2010
  • 906 Answers
SOURCE: how to set date in kenneth cole watches kc1345
Good day Sir, The winder has two click points ...
1.pull out to the 1st click point to set the date.
2.Pull out to the 2nd click point to set the time.
have a nice day.
Posted on Jul 28, 2010
How do I set the time and date on Kenneth Cole women digital watch with 1 knob. Model KC2698. Thank you
most watches with one knob have a duel action on that knob
the first click is the date section , pull it out a bit further to a second click and that is the hands movement
when set to right date and time push the knob all the way back in
Mar 11, 2016 | Kenneth Cole Watches
Unlisted Kenneth cole ul 1069 all other functions work except hands they stopped when trying to set date. what do I do to get hands working again?
your watch has two battery.
one battery for Digital
other one for Analogue
perhaps battery for analogue died
you need to change one battery
Sep 24, 2014 | Kenneth Cole Unlisted Ana-Digi watch
How i set the date in a kenneth cole kc9225?
there two position to pull crown out
position 1 -- to change date
position 2 -- to change time
bring crown to position 1 and turn counterclockwise to set date on your watch. 9k=
Jun 10, 2014 | Kenneth Cole Swiss Chronograph Dial KS3018...
How to set date in kenneth cole watches kc1345
have a nice day.
Dec 02, 2009 | Kenneth Cole Reaction KC1345 Watch
Setting day/date on kenneth cole dual time watch I have a Kenneth COle KC1336 watch with analog hands, 2 digital displays, and it is also a stopwatch. Can't figure out how to change the day/date.
first, unscrew the stem lock. Then you can pull it out to the first "click". That is the "manual wind mode" if for some reason the auto-wind is not working due it has run all the way down. Pull it out again. That is the time set mode. The next "click" (pulling it out again) is the date set mode. Once you have them set, push the stem back in (past all clicks) and then re-screw the stem back to the lock position.
Aug 21, 2009 | Watches
Need help with Kenneth Cole Reaction Watch - setting date/time.
for a watch face that has a day of week, date, and moon calendar: There are two click points on the set-pin. pull out 1 click to access date/moon calendar; spin clockwise to set the moon calendar. spin counterclockwise to set date.
pull out pin 2 clicks to set time, just like any other watch
Mar 06, 2008 | Watches
Kenneth Cole Strap KC1405 4 Watch for Men Logo
327 people viewed this question
Top Kenneth Cole Watches Experts
Jimmy Accardi
Ansel Alberto
Ansel Alberto
Are you a Kenneth Cole Watch Expert? Answer questions, earn points and help others
