Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Intelliclean lights won't go from red to green
Flashing red light on Morphy Richards 732000 Supervac
If it is supposed to go green then the battery is not being fully charged. Unit is under warranty and now is the time to have matter addressed.
Aug 20, 2015 | Vacuums
Won't charge. Red light come on for about 5mins then flashs red when i pull the trigger the red light comes on does not turn to green nothing works
Hi Peter,
I'm sorry to hear you're having difficulties with your DC16. From what you've described, it sounds as if the filter may not be correctly fitted - please follow the steps shown in our online support guide to resolve this:
http://www.dyson.co.uk/support/help.asp?article=1519&product=DC16-SY-STD
If you're still having issues after trying this, it's probably best if you get in touch with us directly, so one of our Helpline experts can run through some troubleshooting over the phone. You can call free on 0800 298 0298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 01, 2011 | Dyson DC16 Root 6 Bagless Handheld...
I have a hunter with 3 wires black white green how do I wire it to a three wire cable black red white ground the fan also has a light and remote but remote is Brocken want to use it with no remote model...
Black to Black - White to White, Green to Green (copper). Put a wire nut on the red wire.
The Black is suppose to run the light (or the fan) while the Red is suppse to run the fan (or light). The White is common and the ground is ... well the ground.
If you have a light kit on the fan, you can control the light and the fan separately ... or you can run them together.
Let me know how this comes out ...
Thanks for your question @ FixYa.com
Jun 29, 2011 | Vacuums
We understand that your problem is: I currently own and use on a regular basis the Kenmore Progressive upright bagged vacuum. Model number 116.35923500. The headlight flickers and the intelliclean light...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Kenmore Progressive 35922 Bagged Upright...
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
Status light is red, why? I have a Roomba Discovery.
Hi.
If the red light is solid, that means that the Roomba is near to full discharge. If the light is flashing red, then the Roomba is completely out of charge.
If the Roomba is fully charged, then there may be a fault.
Here full list of light codes:
Pulsing Amber - Charging
Green - Fully Charged
Amber - Partially Discharged
Red - Almost Fully Discharged
Flashing Red - Fully Discharged"
Here manual
See also
Roomba DISCOVERY MODELS' DIAGNOSTIC TESTS
May 24, 2010 | Vacuums
The Intelliclean function isn't working properly. The indicators illuminate when I switch Intelliclean off, then on again, but the indicators are not changing (nor the power level) when I vacuum dirty...
I was having the same problem with my Intelliclean and I read somewhere on the internet that I should undo the bag, clean in the area where the bag attached to vacuum. When I took bag off, something was stuck there and after I removed it, everything worked fine. I think you need to clean the sensor and check your bag.
Dec 16, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
73 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
