Question about Panasonic Televison & Video
Would like to converge a AE700E projector - Panasonic Televison & Video
  • fivfiv Jun 18, 2008
    Yes, thanks, The AE700E has a bright red line outside the white writing on the right or the writing from on screen as well as red border on the right appears in very sharp images -from experience I would say it requires a color convergence -thanks cheers
    Thanks will try the suggestions
    Genius:
  • 1,011 Answers
Sir,
Procedure:
1) Verify that the projector is positioned the proper distance from the screen by measuring the “C”
or “F” dimension and compare it to the manufacturers specifications. The margin of error allowed in this
measurement is generally 1-2 inches. (In other words, if the installation manual says that the “C” dimension
should be 103” and you place it at 105”, you should still be able to converge the projector.)
2) Verify that the projector is “square” to the screen by measuring the “X” or “Y” dimensions. These should be
within approximately 1” of each other.
3) Make sure that the downward angle of the projector (see the diagrams on the following page) is not too
severe. If your installation is off the charts (pointing down the wall too far) you may have a problem adjusting
the convergence because the controls will run out of range.
"Don't Forget to Rate the Solution"
Posted on Jun 19, 2008
    President:
  • 1,257 Answers
Try this
PICTURE MODE NORMAL
CONTRAST 0
BRIGHT +3
COLOUR -13
TINT ( NTSC ) -1
SHARPNESS -2
COLOUR TEMP 0
DYNAMIC IRIS ON
Posted on Jun 18, 2008
    President:
  • 2,712 Answers
No. Changing the bulb will not help.
You can try a hard rest: Unplug your machine for 30 min and replug. If that doesnt work, it looks like the DAM circuit or some other component on your main board is a problem. I would recommend conatacting the manufacturer for a solution. It would be worth your while :)
    Genius:
  • 1,447 Answers
Hi-
You may need a switch/adapter for this so that you can connect to the projector using a HDMI for HD output-
  • Edgar Allan Pagayona
    Edgar Allan Pagayona Jun 18, 2008
    Buy an HDTV cable for a HD video quality, then a decoder as well, you can buy it from any local computer store/electronic stores. Keep me posted if you have other concerns. Thanks
    Try other possible factors, try reseating the bulb if it will help. try hooking it up to a different source using differnt types of cables.
  • 1,879 Answers
Hi n hello,
In order for us to assist you better, can you give a little more detail with what you want to do ?
WHAT IS THROW RANGE ?
8ft to 40.6 foot throw distance. Screen size is 40-400 inches.
Jul 10, 2014 | Panasonic PT-AE700E Projector Lamp
Where can i get an optical block for a panasonic PT-AE700E and roughly how much am i looking at
USD150 for the Optical block for AE700
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
Sep 04, 2013 | Panasonic PT-AE700E Projector Lamp
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
have a nice day!
May 04, 2013 | Panasonic PT-AE700E Projector Lamp
How to reset panasonic projector ae700
Turn on the projector
MENU-
OPTION-
LAMP RUNTIME-
Press and hold the ENTER button for 3 seconds.
Turn off the power.
have a nice day!
Aug 01, 2012 | Panasonic PT-AE700E Projector Lamp
Is this blue tinge on the left side of the screen a lamp problem or the projector itself. the lamp for this Panasonic PT-AE700E was replaced only about a dozen hours ago. what is an optical block, and does...
Your problem is the optical block failing. This is very common with the AE700s. It actually happened to me once before and I had it fixed. After having it replaced, it was recommended I run my fan on high mode, run the lamp on low mode and change the back lit color to black from blue to help thwart the issue. The optical block fails due to heat stress from the projector. Doing the things above lower the heat and extend the life of the block. I have a perfeclty good optical block if you would be interested as buying them new are extrememly expensive.
May 10, 2010 | Panasonic PT-AE700E Projector Lamp
PT-AE700E projector appears to have gone kaput - not lighting up.
Because of high voltages and heat, there are many safety circuits inside these units. If you have a spare lamp, try replacing the lamp. Initial checks are made before the lamp is fired and sometimes a defective lamp can cause this. Also, can you descruibe what you mean by "noisier than usual"? Is the fan making more noise? Something elase making a noise?
Thanks,
Dan
Oct 15, 2009 | Panasonic PT-AE700U Multimedia Projector
How far to mount projector from screen, screen is a lp morgan rondo
It depends on a lot of factors -- how bright the area is going to be, the size of your screen, etc -- but you'll be roughly 9 to 14 feet from the screen for most settings.
I'm basing this on numbers for a PT-AE700U projector, as I wasn't able to find the AE700E.
Take a look at the ProjectorCentral.com projection calculator if you want to get precise about the distance for your environment.
But be sure to rate my fix as "Helpful" before you click that link! :)
Aug 17, 2009 | Panasonic PT-AE700E Projector Lamp
Panasonic PT-AE700E HD Projector, Has A Colour Problem
the filter on your projector has gone bad the same needs to be replacerd
Nov 04, 2008 | Panasonic PT-AE700U Multimedia Projector
Televison & Video Logo
60 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
