Question about Whirlpool Accubake RF362LXTT Electric Kitchen Range
How do I remove a burnt out oven light bulb...I'm having trouble (I don't want to force it) removing the light...Which way does it turn, left I am assuming...or does it pull out?
Oil Filter Pliers worked for me
Posted on Jul 14, 2013
3 Suggested Answers
SOURCE: oven light exploded and seems fused in socket
I was able to remove the base from the socket by inserting pliers and opening them so that they pressed against the inner sides of the base and then turning while exerting pressure.
Posted on Nov 13, 2008
  • 478 Answers
SOURCE: The light cover over our Whirl pool gas oven will
depending if there is burnt on grease will prevent the cover from coming off if you take and tap lightly in the direction it would come off (counter clockwise) it will start to move
Posted on Dec 12, 2009
Light Bulb in freezer has burnt out and needs replacing. We have tried twisting the bulb to the left (lefty loosey) but the bulb does not budge. How do we remove the bulb?
If this is a regular 40 Watt appliance bulb, it unscrews counterclockwise or to the left looking at the top of the bulb.
Make sure the circuit breaker is off before trying to force the bulb loose. Use a heavy glove and wrap a rag around the bulb and see if it will break loose. If the bulb breaks, use a set of pliers to catch the metal bottom of the bulb and turn left. Make sure the power is off before you start. The bulb may be burned out, but there is still 120 volts on the wires inside the bulb.
May 05, 2015 | KitchenAid KBFS22ECMS Architect II...
How to change light bulb in microwave?
Found this post on another fixya-type site: below is the link..
Here's a repeat of Kai's instructions so you don't have to scroll down. I just replaced mine and it was a snap. Just a few Phillips screws and a few tugs. No need to pull the unit completely out as you can access the bulb after it's about half way. No need to disconnect any wiring harness except pulling the bulb out of its socket. I used the 10w (G4 12V) replacement bulb from Home Depot at $6. The light is a bit brighter but there've been no problems with fuses.
1) Turn off power to the unit
2) Open the lower oven door
3) Remove the side trim screws and pull the trims down and out.
4) Remove 2 screws on the sides of the control panel.
5) Open the Microwave door. Remove the 3 screws on the Air Vent Plastic Cover on top of the microwave. You can then remove the Air Vent Cover by pushing the control panel up and pull out slightly at the bottom.
6) Remove the 4 screws on the Air Vent Plastic Cover on top of the lower oven and remove the Air Vent Cover. (You may have to remove the left under side bracket of the Microwave door temporarily just for the Air Vent Cover to clear the screw of the bracket. Re-secure the side bracket of the Microwave door panel as the front panel may fall)
7) Remove the 2 screws which held the Microwave unit in place behind the Air Vent Cover on step 6.
8) Wiggle the Microwave unit out about half way to expose the light bulb unit on top center
9) Wiring to the Control Panel will prevent you from pulling the Microwave unit out any further. And you don't want to do that as the unit may fall. Space is cramped, but working carefully with pliers you should be able to release the springs which held down the light bulb unit and change the bulb.
http://www.fixed4free.com/answers.php?id=51232
Mar 21, 2012 | KitchenAid Architect Series KEMC308KSS...
How to get light cover off inside oven
Hi Not knowing the type of oven , I can only think it must be a screw type, try turning it to the left of course don't turn it too hard in case it comes out some other way , when yo replace the bulb wipe it off with a clean towel to remove your finger marks on the bulb it will last twice as long by doing this
Dec 07, 2011 | Ovens
How to halogen light bulbson my microwave JVM3670Sk03 I have changed one I know there is another one how do i change it please advice thanks anna
That's covered on pages 35 & 36 of your owner's manual.
If for some reason you don't have yours, you can download it here.
Cooktop Light/Night Light
On models JVM1850, JNM1851, DVM1850 and
EMO4000, replace the burned-out bulb with a 120 volt,
40-watt incandescent bulb (WB36X10003), available
from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and
JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from
your GE supplier.
To replace the bulb(s), first disconnect the
power at the main fuse or circuit breaker panel
or pull the plug.
Remove the screw at the left edge of the light
cover and push on the right edge of the cover
to open.
Be sure the bulb(s) to be replaced are cool
before removing. After breaking the adhesive
seal, remove the bulb by either gently turning
(for models JVM1850, JNM1851, DVM1850 and
EMO4000) or pulling straight out (for models
JVM1870, JVM1871, JVM2050 and JVM3670).
Replace with the same size and type bulb.
Raise the light shield and replace the screw.
Connect electrical power to the oven.
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt
halogen bulb (WB36X10213), available from your GE supplier.
To replace the oven light, first disconnect the
or pull the plug.
Remove the top grille by taking out the screws
on top of the grille that hold it in place and
sliding the grille to the left (opening the door
makes grille removal easier).
Next, remove the light cover.
On some models, the light cover is located
in the center of the top opening. Remove the
screw that secures the light cover and lift the
cover off.
On some models, the light cover is located at the
left of the top opening. Lift the cover off.
Pinch the clips that hold the light socket in
place and lift the socket out.
Remove the bulb from the light socket by
pulling straight out. Replace with the same size
and type bulb, then replace the light socket and
cover.
Replace the grille and screws. Connect electrical
power to the oven.
Jun 08, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
2004 Dodge Durango: Left turn signal blinks fast
Check the bulb socket for a burnt or a shorted condition. Remove bulb and try another bulb, if it does it again then you have a short in the socket or wiring to bulb. Turn on the 4 way flashers and see what it will do. If it continues then look for any burnt wire connector or wireing to bulb. Check the wiring behind the light for any metal that has cut into the wiring insulation. Hope this will help you.
May 23, 2010 | 2004 Dodge Durango
Amana Microwave bulb I cant seems to access, model # AMV5164ACS??
The owner's manual shows you to to access and change them.
Your exact model is not there, but the similar models (like the BCS suffix) should work just fine.
COOKTOP/NIGHT LIGHT REPLACEMENT
CAUTION
To avoid personal injury or property damage, wear gloves when replacing light bulb.
1. Unplug the oven or turn off power at the main power supply.
2. Remove the bulb cover mounting screws.
3. Replace bulb with 40 watt appliance bulb.
4. Replace bulb cover, and mounting screws.
5. Turn the power back on at the main power supply.
OVEN LIGHT REPLACEMENT
1. Unplug oven or turn off power at the main power supply.
2. Open the door.
3. Remove the vent cover mounting screws. (3 middle screws)
4. Slide the grille to the left, then pull straight out.
5. Remove the charcoal filter, if present.
6. Press and hold the center snap while lifting the tab on the left corner. Remove the cover. Remove
the bulb by turning gently.
7. Replace bulb with a 40 watt appliance bulb.
8. Replace the bulb holder.
9. Replace the grille and 3 screws. Turn the power back on at the main
power supply.
Jun 26, 2009 | GE JVM1650 1000 Watts Microwave Oven
Have an installed GE Microwave jvm1870 with a burned out oven bulb. Have replacement bulb but can not see how to get to the old bulb to replace it.
From the owner's manual:
On models JVM1850, JNM1851, DVM1850 and EMO4000, replace the burned-out bulb with a 120 volt, 40-watt incandescent bulb (WB36X10003), available from your GE supplier.
On models JVM1870, JVM1871, JVM2050 and JVM3670, replace the burned-out bulb with a 120 volt,
20-watt halogen bulb (WB36X10213), available from your GE supplier.
To replace the bulb(s), first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the screw at the left edge of the light cover and push on the right edge of the cover to open.
Be sure the bulb(s) to be replaced are cool before removing.
After breaking the adhesive seal, remove the bulb by either gently turning (for models JVM1850, JNM1851, DVM1850 and EMO4000) or pulling straight out (for models JVM1870, JVM1871, JVM2050 and JVM3670).
Oven Light
Replace the burned-out bulb with a 120 volt, 20-watt halogen bulb (WB36X10213), available from your
GE supplier.
To replace the oven light, first disconnect the power at the main fuse or circuit breaker panel or pull the plug.
Remove the top grille by taking out the screws on top of the grille that hold it in place and sliding the grille to the left (opening the door makes grille removal easier).
On some models, the light cover is located in the center of the top opening.
Remove the screw that secures the light cover and lift the cover off.
On some models, the light cover is located at the left of the top opening.
Lift the cover off.
Pinch the clips that hold the light socket in place and lift the socket out.
Remove the bulb from the light socket by pulling straight out.
Replace with the same size and type bulb, then replace the light socket and cover.
Jun 26, 2009 | GE Microwave Ovens
Left rear turn bulb is burnt out
Pull the trunk carpet back behind the lamp assembly. Remove the 3 nuts from the bolts and pull the lamp assembly away from the body. Then disconnect the connector to the bulb then twist the socket cc to remove the socket then pull the bulb out of socket.
Mar 15, 2009 | 2002 Ford Taurus
Light bulb going out
Unplug your unit then you have to remove the cover from the microwave. Just remove the screws that are around and in the back if there are any. once you remove the cover you should have access to your bulb. Befor removing the cover just inspect the inside of the oven to make syre that ther is no access plate in there to remove the bulb. I hope this helps. Don,t forget to rate my answer, thanks.
Feb 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Changing the light bulb in the oven
the light bulb is screw type so turn only. with heat, bulb can jammmed over time so you may have to break it and get a pair of plyers on the cap. turn off power to do this
Apr 21, 2007 | Stoves Premier 720GRa Gas Double Oven
Whirlpool Accubake RF362LXTT Electric Kitchen Range Logo
65 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
