Question about McCulloch Chain Saw Sprocket Fits Mcculloch Mc443a7n 1660
How do you get the spocket off? - McCulloch Chain Saw Sprocket Fits Mcculloch Mc443a7n 1660
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 78 Answers
There should be a retaining washer on the sprocket. You will have to spread it apart and slide it off. Once the washer/pin is off the sprocket should come off.
Posted on Nov 15, 2010
Dura Ace di2 front derailleur 10 speed (7970) not shifting correctly. Moving back and forth with clicking sound. How do we fix?
First, is cable tight, it may be that the cable has loosened or stretched. In this case, Put chain on inside spocket, loosen hex head bolt, pull tight, retighten hex head.
It also could be the limit screws have vibrated loose. There are two of them on the top of the derailleur. Make small adjustments in one screw, check to see if it improves shifting or makes it worse. You didn't say whether it was the small or larger spocket. The limit screws control how far in or out the derailleur moves. Read more on Shelton brown .com under derailleur heading
Sep 16, 2014 | Shimano Dura-Ace Di2 7970 Front Derailleur...
Yard king snowblower, drive chain keeps coming off gear
one of 2 things.if your spockets are worn the travel distance has shortened and where the master link connects replace the link that connects it with a half link.also is there chain tighteners on it?if so and they are on both sides of a spocket or just 1?if there are 2 they must be tightened together in unison and not 1 side or the other as that will throw the correct alignment on the chain and it will jump the spocket.also check the spocket alignment to make sure that is correct.
Jan 28, 2013 | Garden
To resent the timing on a 1997 3.0L Chysler engine, can you take the timimg belt off and turn the camshaft spockets to 12 degrees BTDC
ignition timing control by pcm.if you try adjusting timing by turning cam shaft you going to damage engine valves and pistons you are going to throw off valve timing when you turn camshaft.
Nov 20, 2011 | 1997 Dodge Grand Caravan
Camshaft sensor
camshaft sensor
DOHC between the cam spocket throw valve cover
Sep 26, 2009 | 2002 Daewoo Lanos
Cbr 929 noise from front spocket
Take the cover off do an inspection,....check for worn curved or a loose fit...it might not be to late to install a new one...you do know that if your back spocket isnt alinged in a pefectly striaght angle head on that it could be chunking at an angle to it slightly and wearing out the teeth. good luck a friend of mine has a 929 and he said he cant get his bike into second gire but all the rest work fine.
Sep 05, 2009 | 2000 Honda CBR 929 RR Fireblade
Motor runs,chain doesn`t turn,is this fixable?
It sounds like the spocket or the spocket gear. This is a very easy fix. Call Master Parts, they have the parts available. You can contact them toll free at 800-466-1466 or find them online at www.masterparts.net. I hope this helps...
Jul 08, 2009 | Remington Polesaw Wizard
Noise coming from the front of my primary, slight knocking and slapping noise during low speed or shifting
Primary chain to loose you are only allowed 3/4 inch of play. or you have a bad compinsating spocket
Mar 22, 2009 | 2003 Harley Davidson FXDL Dyna Low Rider
Clutch spocket assy replacement
the clutch is held on by reverse threads.
Mar 02, 2009 | Poulan Pro Chain Saw 46cc 20"
McCulloch Chain Saw Sprocket Fits Mcculloch Mc443a7n 1660 Logo
116 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
