Question about Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher motor is more noisy than it used to be.
Our Dishwasher was fairly quiet when it was in use.
Now it is more noisy.
It still seems to be working okay, but for how long?
It appears that it is the motor that is more noisy than it used to be.
What do you think?
Thanks,
John
  • 725 Answers
There is something is the wash motor dishwasher macerator. you can try to remove it or replace the macerator.
Posted on Aug 08, 2008
Mine does the same thing all kinds of different sounds. This is the 2nd replacement
Posted on Jul 30, 2008
Our LG is only a couple years old and was very quiet at first. It has started making a very loud groaning noise when the water is spraying. Is it a pump going out?
Hi
In Australia I have seen similar problems with some recent models of LG dishwashers. Not sure if the ones sold in the US are any different.
One common problem I have seen with LG wash pumps from dishwashers which were sold 2-4 years ago, is that the motor becomes noisy after some time. The replacement motors which I have ordered is a different one and therefore revised as the predesessor was not reliable. The replacement motor has a different mounting bracket as well.
They are fairly cheap, but to change them is very difficult. Best to get a repairer as the machine needs to be thoroughly dismantled to allow you to get to the wash pump.
Ash
Mar 18, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
Bosch dishwasher noisy vibration
A solution to this problem would be to sell me your dishwasher. The law firm for which I work is looking to acquire an old unrepaired Bosch SHU 33 dishwasher for some ongoing litigation. If you (or anyone else with this model Bosch) could send me some details regarding your dishwasher, you may be able simply to buy a whole new dishwasher. My email is JFraser -at- jshlawmi.com.
Thanks!
Jun 06, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Noisy drain pump on FDB635RF?
Two questions: 1) Are there filters that need to be cleaned on a routine basis with the FDB635RF? and 2) What causes the scum left behind on glasses and utensils? I use a rinse aid, but doesn't seem to be helping. This is a recent problem.
Apr 22, 2010 | Frigidaire 24 in. FDB635RF Built-in...
TOP RACK NOT CLEANING DISHES
Possible that the motor impeller has good particles in it, causing poor water pressure, which would be most evident on the top rack. You would have to remove the spray arm, then the filter, then the torx screws to get at impeller....unfortunately, that model of dishwasher isn't the greatest in the first place for washing, since it only has the one spray arm.
Apr 04, 2010 | Frigidaire 24 in. FDB126RB Built-in...
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
My dishwasher runs fine but has become very noisy. is that a problem? it used to be "whisper quiet" & now it sounds like a drone
usuallly a pump motor asssembly is required.. most had a five year parts warranty and if out of warranty most assembly are 100-300 dollars for the part.
Feb 03, 2010 | KitchenAid 24 in. KUDS01FLBL Built-in...
Very noisy pump
Ya, almost certainly you need to replace the motor/pump assembly.
Here is an example of a place to source it:
http://www.partadvantage.com/store/showpart/11212384
Good Luck!
May 02, 2009 | KitchenAid 24 in. KUDK02CRBS Stainless...
Dishwasher making loud noise during wash cycle
It's noisy If your dishwasher seems noisy, check these:
Water-inlet valve
Motor
Heater fan
Pump
Water-inlet valve An aging water-inlet valve can sometimes fail slowly, rather than all at once. It can shudder on and off rapidly, causing the incoming water lines to shake, rumble, and rattle--sometimes violently. If yours is doing this, replace the inlet valve.
Motor If it's the motor that's noisy, either of these may be the "culprit:"
  • As motor bearings wear out, they can become quite loud when the motor runs. They wear out quickly if they frequently get wet, because the water washes away the motor bearing grease. Bearings can get wet if the spin seal is defective. Then there will also be water leaking onto the floor beneath the dishwasher. Replace the seal if it leaks (read about the main tub seal in the "It leaks" section, later).
  • If, from beneath the dishwasher, you can see a round, plastic disc that's mounted to the top of the motor (a "slinger"), it may have broken free of the motor shaft. If so, it could be rattling around the shaft while the motor is running. If that's the problem, you need to replace the motor.
Heater fan If the heater fan bearings are rusted or worn, they may squeal, or scrape loudly during the drying cycle. If this is the problem, replace the fan motor. Alternatively, the fan blade may be loose. If so, you need to replace it.
Pump Small fruit pits, toothpicks, and fragments of glass sometimes get stuck in the pump. When this happens, open the pump and remove the debris. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher.
To get to the pump, you usually need to remove the lower rack, the spray arms, and the spray arm support from the inside of your dishwasher. A dishwasher pump isn't obvious. Look for an impeller--a round, plastic fan blade-type device that spins around and pushes the water toward the drain. When you can see the drain impeller, you should be able to see the clogging debris.
thanks and accept the solution accordingly
Apr 03, 2009 | Kenmore Dishwashers
Grinding and Uneven washing
Hi
Please do rate this solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Mar 26, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Loud noise during cycle MDB6600AWB Maytag Quiet Series II
look for odjects in the pump cutter ie glass plastic or the cutter is bent or a rushing sound could be motor bearings
Dec 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Whirlpool GU2400XTP Built-in Dishwasher Logo
431 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
