Question about Compaq Presario CQ60-220US PC Laptop
Compaq laptop running vista suddenly lost ability for headphone output to override the internal speaker output
    Genius:
  • 1,542 Answers
Hi
If this problem is new and wasnt like it a while ago i would try a system restore back to when it was running ok
If you go to the start button bottom left of laptop then type into the search box system restore it should take you there then restore back to the date you think it was ok
good luck
Posted on Nov 14, 2010
Macbook pro headphone audio
Go in to the "applications>utilities" folder. Run the "Audio/MIDI Setup" program. Insure the audio out is actually going to the headphone out.
Mar 21, 2013 | Apple Computers & Internet
Sir my delln5010 laptop internal speakers are not functioning , yesterday when i was listening to music it suddenly stops and after it was not functioning
Hi sir,
How can you say that it is the internal speaker that is defective? Have you tried another sound output, like headset or external speakers? If you have, and it works then the problem is definitely the speakers. You will need to have it serviced/replaced. If even the external speakers do not dork, then the problem is the sound card which is embedded on the motherboard. That means you will need to have the motherboard replaced.
But before anything else, try to check the sound playback if it is properly set to default. Sometimes we may have installed an application or clicked on something that changes the default output of our speakers. Check it first and hopefully it fixes it. Make sure that you have the right default sound output.
Jul 20, 2011 | Computers & Internet
My compaq sound is not coming from internal speaker but it is coming from headphones,
its a pure Hareware issue.
get this fixed.
avoid doing it by tourself .
it has got tiny parts and crisp cables.
Sep 16, 2010 | Compaq Presario 700 470024-192 Notebook
Aspire 3680 headphone jack recognizes any headphone plugged in but no sound from the headphone jack, the internal speakers work but not the headphone, running vista
check first you headphone jack speaker. if its working well, then the line from phone jack male to speaker continuity.
Apr 02, 2010 | Acer Aspire 3680 Laptop
Sir ihave c795tu laptap in this system only support vista but iam using windows xp.all fuctions are perfectly worked but headphones are connect the output of actual speakers are also coming
Double right click on the speaker icon in the taskbar tray. Then turn the speaker volume all the way down and adjust the headphone volume to the level you would like it. That way you will get sound coming rom the headphones only and not the speakers.
Nov 11, 2009 | Compaq Presario 700 470024-192 Notebook
Built in speakers not working
Are you using external speakers? or internal?
EXTERNAL SPEAKERS: If your are plugging speakers into your headphone jack and they dont play, but you plug headphones into the same port and they work fine.. then it is the external speakers.
INTERNAL SPEAKERS: But if you are using the speakers in the laptop, then your speakers are probably bad. Try some software settings, but probly just bad speakers. Could also be that the speaker cord inside the laptop came unplugged from the motherboard. In which case you would have to take the laptop apart and plug it back into the motherboard.
Good Luck.
Sep 08, 2009 | HP Compaq nx6115 Notebook
My laptops speakers stopped working
Have you tried a pair of headphones to see if they work?
Is the sound ouput muted? (a lot of laptops have a physical button to
do this...
check to see if the laptop is muted. Also, check the
volume control to see if everything is up where it should be, including
Speaker Out.
If I've got this all straight, the only thing that it can be is an
issue with the plug on the speakers and the jack on the laptop.
Obviously the computer is putting out sound to the headphone jack as
evidenced by your ability to listen through headphones. The speakers
work on another computer. So, it has to be something specific about
the Speakers on this laptop. Plug/Jack problem is the only thing that
comes to mind.
Jun 24, 2009 | HP Compaq Presario 2500LA Notebook
HP Compaq 6720s Sound problems!!!!
pls. check the internal speaker audio cable is ok or not. and also check the audio cable is connected on the audio section of motherboard.
Feb 16, 2009 | HP Compaq 6720s Notebook
Sound Coming From BOTH SPEAKErs and headphones
Sound emanating from both the internal speakers and headphone/earphone while the later is engaged could mean a factory defect in your speaker device. Upgrading your OS from XP to Vista may not solve your problem. However, since the service center technician will probably insist on his diagnosis and recommendation, you may need to upgrade your OS just to prove your point.
Jan 25, 2009 | Broadcom BCM94306MP - IEEE 802.11b/g...
Compaq C740TU speaker does not deactivates if external speakers are connetced
The internal speakers should automatically be disconnected by inserting a 3.5mm jack plug in the audio out socket. It may be that your headphones or external speakers are using a 2.5mm jack which is too small to operate the switches in the audio out socket. Purchase a 3.5mm jack plug [cheap] and plug this in if it disconnects the laptops internal speakers then you need to connect accesories with the correct size plug.
Mar 14, 2008 | Compaq Presario 700US Notebook
Compaq Presario CQ60-220US PC Laptop Logo
53 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
