Question about Hoover Vacuums
Little suction - Hoover Vacuums
  • 244 Answers
Most vacuums have an air intake adjustment. If this intake is opened,the suction is affected. It is on the hose usually and is a simple procedure to turn it to closed. If yours is an upright, there may be something lodged in the machine that keeps the air from flowing as it should. And of course, the bag or filter needs to be cleaned, emptied or replaced (depends on the type of vacuum) to assure good suction. Oh, also if you have a hose type vacuum, there might be something lodged in the hose. I usually take a mop or broom handle, remove the hose from the machine, and plunge the handle into both ends of the hose to dislodge the stuck item.
Posted on Nov 14, 2010
My Eurika 4D bagless upright will not pick up anything. The belt is not broke but the roller won't spin and there is verry little to no suction. Still makes all the notice but won't roll as easily
You say the belt is not broken and the roller does not spin. Does the motor that spins the belt turn. If the belt does not spin and the little drive motor spins then you will burn the belt out. Try to turn the roller by hand. Could be plugged up with dirt and the roller seized. The little drive motor could be burnt out. Take all hoses and areas out that any dirt could be in. No suction means something is plugged. Even your main suction hose could be plugged.
Mar 15, 2017 | Vacuums
Plenty of suction with hose off, little suction with hose and head on. No clogs in hose or head.
if it works without the hose attached but not with it on , then there has to be a blockage keep looking for it .
May 10, 2016 | Miele Vacuums
No suction
CHECK THIS CHECKLIST OUT!
http://www.quickanddirtytips.com/house-home/diy/how-to-fix-a-vacuum-that-lost-suction?page=1
Jul 13, 2014 | Electrolux Guardian Bagged Canister Vacuum
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
May 18, 2014 | Riccar Vacuums
No suction
Very little suction at the source, inlets, or at he hose?
Your answer will vary depending where the power loss is felt; most likely something clogged in the hose or one of the inlet pipes.
Help me out with more info and i'll do my best to lead you to a quick resolution.
Nov 09, 2013 | Broan-NuTone CV352 Performance Central...
The suction for carpet cleaning is great but there is very little suction through the hose. I have cleaned out the hose but there is still very little suction. What else can I do?
Have you tried cleaning the hose from the vacuum end, the end that feeds the sweepings into the cannister/bag? Might be something close to that end of the hose. Also, one reason for a hose not to work is the possibility of a cut or broken hose or a loose connection. The closer an opening like this might be to the vacuum end of the hose, the less suction the unit will have through the hose as it will pull air through the hole/break easier than through the full length of the hose.
Sep 19, 2010 | Eureka 5849A Boss Bagless Upright Cyclonic...
I have little suction when using the hose attachment
Check the hose for a blockage. If you remove the hose, if there is suction at the point where the hose hooks to the back of the vac, then the hose is clogged. If no suction there, check filters, make sure they are clean.
May 31, 2008 | Hoover Company Wind Tunnel U53019 Upright...
Wet dry vac suction not woking
The wet and dry vaccuums should normally have the dust filter removed when used for wet work. If the filter was left in, it will certainly be clogged and useless. I would suggest trying the unit with no filter, just to check there is good suction. If there is, a replacement filter is required. If there is still little or no suction, then it is possible that there is a blockage within the impeller area somewhere. Wet dust/dirt tends to stick really well to the impeller blades, reducing their efficiency to point of almost no suction. I'm not sure if you can get that far into your unit, if you can, it would be worth using a stiff brush to remove and adhered debris.
Dec 17, 2007 | Vacuums
Vacuums Logo
42 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
