Question about Nikon FE 35mm SLR Camera
My film advance seems to be stuck. I took the film out of the camera and it still will not move. Does this have anything to do with the battery?
  • kakima Nov 14, 2010
    What happens if you press the shutter button? The film advance and the shutter release are linked: you cannot advance the film without firing the shutter, whether there is film loaded or not.
    If the battery is dead, you need to set the shutter speed to the M90 or B setting in order to fire the shutter.
    Scholar:
  • 73 Answers
No, the only thing that the FE uses the battery for is the light meter and shutter. You can operate it completely without the battery using the M90 and BULB shutter speed settings.
Your film advance problem is a mechanical problem - check for any small objects that may be jammed into the film transport mechanism. If nothing is obviously causing a blockage, then the camera will need to be serviced.
Posted on Nov 26, 2010
Film advance lever stuck. Changed batteries but can not move the film advance lever.
Hi fmerlin, If you have film in it you may need to remove the film to free up the advance lever. Go into a closet cover under a blanket etc. Also, Walmart and most drug stores have a big change bag that they could do it for you. With film out it still will not advance it will need to go to Nikon.
Aug 18, 2010 | Nikonos V 35mm Point and Shoot Camera
Cannot take picture, no film advance, new battery
The shutter could be stuck or the mirror could be stuck. (Guessing you have an SLR.)
The film advancing is normal; means it is cocked and ready to go but something is stuck.
Take off the lens and see if anything is keeping the mirrors/shutters from returning.
Oct 23, 2009 | Canon EOS-AE-1 35mm SLR Camera
Is there anything I can do if the inner mechanism is jammed and wont turn/advance the film/allow any pictures to be taken? I took one shot, and then it wouldn't advance- the button on the bottom is stuck...
well i get whats the problem,,, the film is jaming your camera you realy need to pull the film out the only way to do this is to life the center crank handel and turn it and hope it strips the little frame drive holes in the film first before the camera strips?
the problem is caused by the film jamming in the case if you have fully wound it on that is???whate ever that film has got to come out first to get your camera working again ,,,,good luck
Oct 20, 2009 | Mamiya 35mm f/3.5 Lens 645
Film advance lever.
Do you press the shutter button to release the lever for the next photo? That's how you advance the film from the exposure to light, when first insterting the film.
Sep 16, 2008 | Nikon FE 35mm SLR Camera
Film = no light meter
jackson rook,
the speed of the film may be to high if your camera has dx coding contacts in the film chamber. otherwise---- film in camera or not it has no effect on meter operation. move the advance lever to the right slightly and push down on the shutter release button slightly to turn meter on.
Sep 10, 2008 | Vivitar V4000 50MM 35mm SLR Camera
Minolta X370 film loading problem.
Hi, check the camera set in auto /manually in auto function, check battery might drain the current , dis engage camera to lense to release the mirror by pressing button beside lense , turn lense in left or right .
Feb 04, 2008 | Photography
Shutter won't depress, advance lever won't move.
how did you fix this i have the same issue
Oct 30, 2007 | Nikon FM10 35mm SLR Camera
Canon T70 35 MM SLR Camera
It sounds like your camera is having problems advancing your film, which could mean it is jammed inside the camera. The other thing you should check is to see if the battery is weak & doesn't have enough power to advance the film (and thus the beeping). If it is not the battery, then go in a darkroom (completely dark) and take out the film (if you're unable to rewind it inside the camera). Look at the transport rollers (in the back for the camera) and make sure they're clean (sometimes film chips get jammed in there) Let me know if this helps you. Thanks.
Sep 11, 2007 | Canon T70 35mm SLR Camera
Nikon FE 35mm SLR Camera Logo
186 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
