Question about Acer 91.AB370.001 Network Adapter
Acer5536 laptop will not connect to the internet wireless will connect by ethernet cable why
  • Acer Master
  • 27,725 Answers
you might have a modem with an ethernet connection to connect to the net .
if you have a laptop you can choose a wireless usb broadband modem which can work on a desktop also once you recieve the modem just insert the modem into a usb port and follow the prompts you might need some drivers for the usb broadband modem which can be supplied by the ISP internet provider
hope this helps
Posted on Nov 14, 2010
Can I disable wireless and connect with ethernet cord and modem, for work do not want remove wireless cord, in the day want to be able to use my wireless.
Are you talking about direct-connecting via Ethernet to a cable or DSL modem? You shouldn't have to disable wireless to do that. If the cable modem has an open Ethernet port, you should be able to run a straight-thru Ethernet Cat-5 cable between that port and the Ethernet port on your laptop. The laptop should recognize that it is connected to the modem through the direct connection. Check the manual for the cable modem or information supplied by your ISP for connection details. You may have to do some setup on the modem to get an Internet connection, like having your ISP 'activate' the modem. Just be sure your Ethernet cable is a straight-thru, standard Ethernet cable, and not a 'cross-over' cable such as is used to transfer data between two computers.
Jul 24, 2014 | Dell Inspiron Computers & Internet
How to connect xbox360 to internet with laptop
Hello bernelltaylo,
This is a very simple procedure, but pay close attention.
First, here are the requirements to attempt this procedure.
_____________________
- An Ethernet Cable,
- Wireless Connected Laptop
- Bridged Connection Eligibility
_______________________
1. Get an Ethernet cable, they are commonly blue, or yellow.
2. Plug one end of the Ethernet cable into the back of your Xbox 360 console, and the other end of your Laptop.
3. Log onto your laptop, (assuming you're using Windows), and find the list of your wireless/wired connections.
4. You'll see something like, "Local Area Connection 2", and "Wireless Network Connection 3". Make sure you're already connected to the Wireless Network before continuing to the next step.
5. Highlight both the connections, and right click one of them. Click on, "Add a Bridge".
6. A process will start which will bridge the connections, enabling your laptop to work as a modem for your Xbox 360. This may take as long as anywhere between seconds, to minutes.
7. When it's done, do NOT remove the Ethernet cable, until your desire to disconnect from the internet on your Xbox 360.
______________________________________________________
Hope this helped, see ya' later. :)
Dec 02, 2012 | Microsoft Xbox 360 Console
We have cable internet provided by Virgin. I am accessing the internet by plugging the ethernet cable dirctly into my laptop rather than via my DI524. Have just read a post that says I have to be connected...
If you can connect to the internet using the Ethernet cable on your laptop then the cable modem is configured correctly.
If you want to connect to the Internet using the D-Link wireless router then first you need to configure the D-Link wireless settings and then configure the wireless card in your laptop with the D-Link's wireless settings. Remove the Ethernet from the laptop and connect it to the WAN/Internet port on the D-Link wireless router.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Mar 13, 2011 | D-Link AirPlus DI-524 Wireless Router
I want to connect to a wireless router with my laptopbut dont seem to the wireless drivers.i have tried to connectwith virgin media modem and router .followed all instructions and when i remove ethernet...
Sir, try downloading the wireless driver from your laptop company's website. Or form the drivers cd/dvd they provided you. Then you can connect to any wireless capable modem/router from your laptop.
The ethernet cable provides the internet pulses into your laptop. If you remove it, your internet connection gets disconnected.
Jun 30, 2010 | Advent Netbook
How to hook your xbox360 to laptop to get on xbox live
wel if you have wireles internet you can get a wreles adapter for your xbox and conec it that way
Oct 25, 2009 | Microsoft Xbox 360 Console
Definition of the sound card, internet lan & wireless lan
The definition of the sound card, is a chipset integrated into the main board of your laptop, in order to provide sound to your built-in speakers, or to the headphone jack on your laptop. Internet LAN (or Local Area Network) is a port located either on the side or the rear of your computer, where you would plug in a Cable/DSL High-Speed Internet connection, using an Ethernet cable (also called RJ-45). Wireless LAN is the same idea, only instead of using an ethernet cable to provide you access to the internet, it uses a wireless signal or radio frequency, to connect to a wireless access point (usually provided by a wireless router in the area). More in-depth information can be found at the following links:
Sound Cards: http://en.wikipedia.org/wiki/Sound_card
Internet LAN: http://en.wikipedia.org/wiki/Ethernet
Wireless LAN: http://en.wikipedia.org/wiki/Wireless_LAN
May 06, 2009 | Acer 4220-2346 Notebook
Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
D-link dir-625 still cant acces wirelessly
If your laptop has a wireless capability you should be able to connect to the wireless network of your router, just view the available wireless network select the wireless name of your router and connected to it if it already say connected try to disconnect the ethernet cable from your laptop and access the internet wirelessly..........
Nov 01, 2008 | D-Link DIR-625 (790069292637) Wireless...
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
My router will not connect to the internet
The laptop may not have the correct wireless settings same as the router.
What is the Operating system of your laptop and does it have a builtin card?
May 21, 2008 | NetGear WGR614 Wireless Router
Acer 91.AB370.001 Network Adapter Logo
109 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
