Question about LG 37LG30 37 in. LCD HDTV
I installed a tv in my bedroom but I can't get the same channels as my tv in the livingroom. I only have an antenna. What could be the problem. It says that some channels are not available.
  • 391 Answers
You do not state what type of antenna you are useing ,i would suggest you run seperate coax run from the antenna to your tv in the bedroom you can use a slitter box at the antenna and run it to your tv if this doesnt work ,try a booster at the antenna
Posted on Nov 14, 2010
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
I have one receiver in my living room. The living room tv is on the #1 channel and the kitchen, guest bedroom and master bedroom tv's are on channel #2. All remotes were working just fine and suddenly...
Hello! On the back of your receiver box you'll see a silver UHF antennae make sure its pointing straight up. If that fails try the steps in this link
http://www.dishnetwork.com/SupportSection/remote-setup
Daniel Busa
DISH Network Customer Service
Jan 04, 2011 | Universal Remote Control DISH Network...
I live in a two bedroom apartment. My wireless router is located in the living room and my main computer is located on the far side of the apartment in the far bedroom. I'm only getting about a 20 percent...
Can you rotate the computer, so that the antenna in your computer is physically closest to the router?
If your router has a single-pole antenna, make sure that it is vertical -- the signal goes "sideways" from the antenna.
If your router has more than one antenna, follow the manufacturer's directions for pointing each antenna (typically a 'V' for twin antennas).
Access the router's built-in web-interface, and confirm that the router is transmitting at 100% power.
Oct 29, 2010 | Computers & Internet
How do i get freeview reception on my 19' LG TV/MONITER its not picking up any channels in bedroom...recommend best antenna to fix please
Get a Digital antena,any name brands.Make sure it put some where high,will get all the free air tv channels.
Apr 12, 2010 | LG M1910A 19 in. LCD Television
I share a TV antenna with my neighbour. there are three splitters in the line - one to give an output to a next door bedroom TV, a second gives a signal to their lounge TV with th other leg continuing to...
I suspect there is a Mast Head Amplifier to supply enough signal to split so many ways and the power supply is powered from the power socket supplying the neighbours TV. Switch it off and no/poor signal.
Mar 21, 2017 | Televison & Video
Hitachi projection tv digital channel problem
yes i have same tv it has no digital tuner >( you must get a converter box
Jan 30, 2009 | Hitachi 57F500 57" Rear Projection...
DTV converter box
Buy a hdtv antenna to autoscan program channels which should bring in a lot more then reconnect with the older antenna afterwards and if you're still not getting all the channels then each source needs a strong hdtv antenna that can be adjusted manually.
Oct 18, 2008 | Insignia Digital-to-Analog Converter for...
Setup for coby tv-dvd 1350
I need to download the instruction/manual. Can someone direct me?
Thanks
Sep 25, 2007 | Televison & Video
LG 37LG30 37 in. LCD HDTV Logo
285 people viewed this question
Computer Repairing
Computer Repairing
