Question about Nespresso Essenza C100 Espresso Machine/Coffee Maker
WHEN SWITCHED OFF, WATER LEAKS AT THE BASE OF NESPRESSO C100 MACHINE
I opened mine when this did this - it also happened to my second Magimix Nespresso Manual machine. A short pipe carrying pressurized water had burst. I called Nespresso . parts were not available and they offered me a new half-price machine. We are talking a 4 inch piece of plastic tubing here. Shame on you Nespresso for encouraging me to throw what is otherwise a fine machine....
Posted on Mar 02, 2013
Water leaks from the bottom of the nespresso essenza machine, why?
Posted on Nov 19, 2010
  • MP01 Dec 20, 2010
    I have similar problem but it doesnt matter if is switch on or off
Where to buy replacement water tank for Nespresso Essenza C100
I need to find a replacement water tank for my nespresso essenza C100 coffee machine. Mine broke, any ideas where I might be able to find one?
Jan 12, 2013 | Nespresso Essenza C100 Espresso...
How do I get replacement parts for my Nespresso C100 Essenza?
you can find them by searching on amazon. click here Amazon com nespresso replacement parts. Hope this was helpful. cheers
Jun 09, 2012 | Nespresso Essenza C100 Espresso...
Nespresso Essenza - water is not coming out of the spout
Try...Hit the start button then Lift the lever and push back as far as possible and hold for 3 seconds. hit stop button, then close lever. this should restart machine.
Apr 29, 2010 | Nespresso Essenza C100 Espresso...
Water not coming through nozzle of nespresso essenza
I have had this issue. I have removed round silver plastic piece from around coffee spout,(gently -do not crack it) I then removed and washed the black spout, I even used a toothpick once, to remove the stubborn coffee ground, Once it was cleaned - it worked perfect. If you run water from the faucet into spout it should flow smoothly. I warn you though, not sure what this does to any warranty, but don't mess with my morning coffee! I hope this helps.
Jan 09, 2010 | Nespresso Essenza C100 Espresso...
To convert Nespresso C100 coffee machine 110 valt device to 220 valt-
use a travel converter plug
one that converts the voltage, not just an adaptor
have you looked at the label and specifications on the coffee machine?
many things are designed to run on both 110 and 220
if so you could just change the plug or use a $1 adaptor
Jan 02, 2010 | Nespresso Essenza C100 Espresso...
Nespresso essenza problem
It's not supposed to make holes in the capsule until the water comes through. So, basically, when you put the capsule in, it pierces the capsule in three spots, on the top. The aluminum part will not pierce until you press the button and water comes through. If water is not coming through, then you can clear the air bubble by opening the lever on top of the machine, pressing the coffee button, and then closing the lever once the water begins to come through.
Jul 30, 2009 | Nespresso Essenza C100 Espresso...
Our Nespresso Essenza C100 machine doesn't let the water out, but it pours it inside itself. What could be the problem?
When you make several servings of espresso consecutively, the pressure develops inside the brew basket. , be sure to relieve the build-up pressure before you remove the brew basket by turning the unit to "Froth" mode and allowing the steam to exit.
Jul 08, 2009 | Nespresso Essenza C100 Espresso...
Light don't stop blinking .... Nespresso Essenza C100
My guess is that the Essenza is in 'Descaling' state. See section 7 of the essenza manual. To get out of it, hold both the buttons down for 3 secs. The lights will then blink at normal rate for a bit and then turn solid.
Jun 21, 2009 | Nespresso Essenza C100 Espresso...
Nespresso Essenza C100 Espresso Machine/Coffee Maker Logo
4,152 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
