Question about Polaroid FLM-3734B 37 in. LCD HDTV
Polaroid lcd tv
What are caps.
  • m@tT G.
    m@tT G. Jun 23, 2008
    caps are capacitors, little cylinder shaped objects with two wires coming out and are used to store electricity. Wires wont be visible cause they are soldered to the board.
    Sergeant:
    Champion:
  • 362 Answers
Capacitors are batteries in a way they store electricity until the voltage drops then they discharge thier voltage to keep the power flow even. hope this answers your question
Posted on Jul 01, 2008
40 inch polaroid lcd tv
This is a common problem with Polaroid sets. I would check the power supply/inverter board for any capacitors with bulging tops. The typical ones that cause this problem are 10uf 450V caps.
May 07, 2013 | Polaroid TLA-04011C 40 in. LCD TV
Tip
Info on replacing polaroid caps
All Polaroid flat panel
I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After removing the to caps I noticed they were not 10v but 35v. I replaced with the same size and TV works fine! It is not just the FLM-3734B model that has this problem. It is all polaroid flat tv's. I do not believe increasing from a 10v cap to a 25 or 30v cap will increase reliability. I used same size & voltage but increased operating temperture range from 105C - 120C.These high temp caps can be perchased at Newark.com I hope this info helps, any questions send e-mail to prowler21@verizon.net
on Mar 22, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
I'm trying to take the back off of my polaroid tv
You need to remove te stand also, you only do thsi if you want to see EVERYTHING inside.
To get to the power supply and main boards, you just need to remove the center cover.
Service manual: http://www.polaroidsupport.com
http://s807.photobucket.com/albums/yy352/budm/POLAROID/Polaroid%204241-TLXB/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jun 13, 2011 | Polaroid 4241-TLXB 42 in. LCD Television
42 " lcd Polaroid ....only
That is more likely to be failing T-CON board or bad connection on the ribbon cable between the LCD panel and the T-CON board.
Learn more here:
http://www.scribd.com/doc/25276757/E40951307-TCON-Troubleshooting-10-22-09-OPT
PDF download: http://www.mediafire.com/?zzjygannjty
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
May 18, 2011 | Polaroid 4226TLMB 42 in. LCD TV
Our Polaroid 19" LCD TV
sounds like new caps needed on power supply board..................
cheers
Mar 27, 2011 | Televison & Video
POWERS UP BUT NO PICTURE OR SOUND WILL NOT SHUT OFF POLAROID 37" HD LCD TV-2 YEARS OLD
my POlaroid 37" did same thing blue light stayed on no pic or sound was 2 electrolytic caps on power supply board took back off and they were noticably bulged at top radio shack sells these caps at $3 apiece fixed mine works like new saw a video on here how to do it
Dec 07, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
No Power to LCD Tv
Even if caps do not look blow, they still can be. Check diodes and resistors on power board. Easy fix if you have patience and time. make sure you replace with a higher voltage, but same cap, resistance values.
Dec 27, 2008 | Polaroid FLM-323B Television
Polaroid 20"LCD TV
You have blown caps on board should be around 1000uf at 16-35v.
Mar 17, 2008 | Polaroid FLM-2011 Television
Polaroid FLM-3734B 37 in. LCD HDTV Logo
32 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
