Question about Jensen Televison & Video
Locked television well... it looks like there are several with the same problem and there seems to be no solution - at least not posted... is there a solution? my grandchild sat on the remote and it locked the television... what is the solution to unlocking it, please? seems this is a tech support problem...
    Genius:
  • Jensen Master
  • 1,689 Answers
On many models of sets, press and hold the menu button for more than 10 seconds to unlock. If this does not do the trick, you should contact the service rep for the solution.
Jerry G.
Posted on Jun 19, 2008
Where is the trunk release fuze on the Ford Focus5
Look for a fuse related to power locks. But if your locks operate by remote or switch, then that isn't it. Would have to look for a fuse in the fuse box that could be related. I read several posts of people having to fix wiring issues in the trunk or replacing a faulty switch.
Apr 14, 2017 | Ford Cars & Trucks
My Parental Lock has spontaneously activated on only one channel (4). No reset method seems to work, partly because I only have a satellite remote, not the original TV, and numbers don't input.
If you wish to get some details; check the site linked here. Pull up older posts.
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Jul 22, 2016 | RCA TruFlat 27F520T 27" TV
I have a blank blue screen with a small red lock on the upper left side. There is the number 7 on the lock.
your parental lock is active. Check the manual, but if you hold down the display button on the remote for 10-15 seconds you can put in 0000 as the default pw. If you have no display key on the remote, then post the tv full model number
Feb 04, 2015 | Televison & Video
The system doesn't seem strong enough to turn my deadbolt. I checked and double checked my installation....
I hope that you have been able to get your lock working properly since I sent the "Ask for clarification" post several days ago, which included several suggestions for your problem. I'm considering this fixed, since you haven't re-posted.
Jul 14, 2011 | Weiser Lock POWERBOLT ELEC DEADBOLT
No remote and tv locked on parental lock
Check out this website http://www.remotes4u.co.uk/
you can get original or alternative remotes for just about anything.
Hope this helps, please rate my posts.
Oct 11, 2009 | Televison & Video
Door and Boot Locks
the problem lies in the drivers side operating switch for the central locking .this would involve removing the drivers side door handle and checking the switch mechanism thats built into the lock,havent done one o n this model only a opel astra ---but they are different from the opel although the car looks the same ,well similar pull it off have a go ,the key barrel must turn something so look for an internal switching or external switching and see if the spring is ok that returns the switch
May 02, 2009 | 2001 Daewoo Lanos
Convergence issues
Is the symptom the same on ac format? If so you may have to do an alignment. Also when the convergnce seems off if you go back to the convergence adjustmen is it off there aswell? If so you may just need to reflow thesolder on the convergence Ics.
Jan 02, 2009 | Mitsubishi WT-46805 46" Rear Projection...
Pltv-4250 post
YOU NEED TO INSERT A FLAT BLADE SCREW DRIVER BETWEEN THE PIECES AT THE TOP OR BOTTOM EDGES. THERE IS A LITTLE EDGE ON THE INSIDE OF ONE PIECE AND A SLOT ON THE OTHER PIECE THAT LOCK THE 2 PIECES TOGETHER. EVERY 4 TO 5 INCHES THERE IS ANOTHER LITTLE LOCK PIECE.
Dec 07, 2008 | Protron PLTV-4250 42 in. LCD Television
Please help
Try, to look for a cold solder joint.
Aug 27, 2008 | RCA 27V520T 27" TV
Televison & Video Logo
Top Jensen Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
