Question about Admiral Washing Machines
My admiral washing machine is making a load a clicking noise in spin cycle. almost like a card in the spokes of a bike. (a realy fast bicycle)
SOURCE: Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Posted on Sep 14, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: I have a GE Profile Prodigy top load washing
The gears maybe going out. Sometimes it is able to engage in the other direction which the spin, sometimes not. Washing machine have complex gears that in one way agitator works, and the other the gear locks to turn the whole tub. The clicking noise is probably the locking mechanism in the gears that has caused the whole intermittent problem.
Posted on Jul 01, 2009
  • 714 Answers
SOURCE: will not spin and gives a grinding sound.
could be a problem with the basket drive tube or drive block
Posted on Feb 28, 2010
  • 1937 Answers
SOURCE: Kenmore Elite 11020952992 Washing Machine won't spin or agitate.
LID SWITCH OR COUPLER:
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20952992&pathTaken=partSearch
and you'll see a list of major sub-components with diagrams and parts.
Two possibilities:
The first thing to check is the Lid Switch.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or spinning. The "clicking may be the plastic prongs hitting each other.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Apr 19, 2010
SOURCE: Admiral Washing Machine not spinning
y Admiral washing Machine modle # lnc6760b71 will fill with water and agitate. But when it come time for the spin cycle it wont spin. I can hear the motor making noise. and now stop and it does not work, does not smell to burned What should I do??
Posted on Jan 12, 2011
Amana NTW475OYQ1no lights or sounds. Verified power @circuit board. Someone closed lid on a shirt earlier that preventing lid to I open.verified switch waz working and the wife did a load of laundry.
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following ... Speed Queen, Amana Whirlpool ..... Lid lock lightflases; no spin cycle.
Amana Washing Machine NTW5400TQ1 Troubleshooting ...
www.repairclinic.com/.../Washing-Machine...-/Amana-Washing-Machin...
Amana Washing Machine NTW5400TQ1 Troubleshooting & Repair Help. Amana Washing Machine problems. Washer won't spin ยท Washer is making loud noise ...
Jan 16, 2016 | Amana Washing Machines
I have a admiral washing maching, model LNC6766B71, it is top load. It makes a load noise in spin mode.
if noise is constant maybe bearings? Is the load even? Not totally familiar with item but the I think the two possibilities above are worth considering. Do an spin on empty. NOISE??? I would guess bearings.
Jan 02, 2016 | Admiral Washing Machines
Whirpool front load washer model LHW0050PQ4 makes sputtering sound during spin cycle
Power plug off the wall first. Check out the pump which comes after the filter, something shd be clogging there; it shd move freely.
Remove back of machine to see if anything is touching the wheel belt or pulley.
Pl click helped, if helped.
Apr 09, 2013 | Whirlpool LHW0050PQ Front Load Washer
I have a lg washer Model# wm0642h and yesterday my wife was washing clothes and during the last spin cycle it started making a loud clicking noise kind of like when you put a baseball card in the spokes of...
Sound like something has gone in between the drum and the outertank, usually a bra wire.. unless you can see it poking through a hole in the drum the only other access points for retrieval are through the sump hose at base , or the removal of heating element.. other than that it becomes a strip down job... but usually the 2 access points are sufficient..
Dec 19, 2009 | LG WM0642H Front Load
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Fisher and Paykel clicking sound
it sounds like the bearings are going out as it spins faster the noise quietens down because the bearings are more spread out and as it slows they fall lower leaving an area that it causing "friction" of a kind
Dec 27, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Thanks,
Apr 15, 2008 | Washing Machines
Jan 06, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
