Question about RCA HD50LPW165 50" Rear Projection HDTV
Whining noise problem and color flickering
I recently purchased an rca hdtv dlp tlevision. Within 2 months of use, when starting up the tv it would give off a whining, irritating type of noise, and then it would stop, and the lights would blink on and off. So recently, I replaced the lamp, and the television now comes on, but within 30 minutes of watching tv, it would start making that whining noise again and the colors on the tv would change rapidly. What could be this problem, and what would I have to do and how much would it cost?
Thanks,
Rob F.
  • RCA Master
  • 8,617 Answers
Its the color wheel you can get a replacement color wheel for your model and it comes with free instructions on how to index it proprly plus free tech support with on line messageing. heres the link.
http://servicemanuals.vstore.ca/
Posted on Jun 18, 2008
Dlp turns it self off after 5 mins
If whining while turned on, it's bad color wheel.
Apr 01, 2014 | GRY Viore RPT50V24DHD 50" HDTV DLP TV
50 inch rca dlp tv. new bulb. makes a loud
Color Wheel needs to be replaced. Call PartStore.com
1-866-925-7278 For Part number go to Encompass Parts Distribution they will list part number.
Apr 28, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
Whining noise on start up, lamp and TV shutting down
The TV tech isnt too familliar with RCA TVs. The color wheel is the most likely problem no where near 1000. Depending on the model number of your set you can get replacement color wheels at the following link.
Jun 13, 2009 | RCA HD52W59 HDTV Projection Television
Whining Noise and Image Problems
You better to check the color wheel or Lamp ballast.
Normally, the noise comes from color wheel.
Jan 17, 2009 | Samsung HL-R4266W 42" HDTV-Ready...
I have a RCA 50in DLPModel #M50wh74s
Two possibiltes. A bad cooling fan or what is known as a color wheel. is this a whining sound. does the colors flicker. a bad fan could have contribited to the bulb going out too. to identify a technician would have to take back of and examine fans and listen
Dec 15, 2008 | RCA HD52W56 52" Rear Projection HDTV
RCA HD52W59 Screen Flickers
This not a DLP set and does not have a bulb that the customer can replace.
It may need a firmware upgrade if avaiable.
Oct 21, 2008 | RCA HD52W59 HDTV Projection Television
RCA dlp 50"
Buzzing is usually indicating the color wheel is defective. Or it could also be the lamp fan malfunctioning as well. My quess would be the color wheel as thats a fast moving part which is prone for bearing failure.
Aug 03, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Whining Noise - hardrive or fan?
The color wheel is the most common problem when it comes to noise from DLP's. To determine if it is a color wheel or fan: Turn on the set. When the noise starts, turn off the set. If the noise goes away within 5 seconds, then the color wheel is bad. If the noise goes away after one to one and a half minutes after the set was shut off, then one of the fans are making the noise.
Jan 08, 2007 | Samsung HLN467W 46" Rear Projection HDTV
RCA HD50LPW165 50" Rear Projection HDTV Logo
258 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
