Question about E-Machines Computers & Internet
I have a emachine EL1300G-02W cpu which was taken apart & the connection wire between the motherboard & the power on button is missing, where can i get a replacement
map9966
  • 2351 Answers
SOURCE: wiring hookup instructions for ecs 945 gct -m mATX motherboard
Hi joe, if you're question refers to ECS 945GCT-M motherboard, than goto page 12 in the manual. You'll see this
77d37bb.jpg Please read all of pg.12.
It's my guess you bought this board from powerspec. For now forget the two red wires & just hook up the case's wires for all LED's & on/off. Everything should be just fine.
Good Luck!
Mike
Posted on Jul 02, 2008
SOURCE: Motherboard taken out by eMachines Bestec power supply
To "test' the power supply; remove the 4-Pin power connector, and the 20-Pin ATX power connector. Jumper the Green Wire (power supply enable) to a Black Ground Wire (there are several to choose from, just pick one). The fan on the power supply should spin up, and you should be able to test the voltage outputs at that point.
Posted on Jul 04, 2008
SOURCE: wiring info
Lay out is screened on the Motherboard above the Battery
HD Led pinss 1-3
Pwr Led pins 2-4
Reset pins 5-7
Power On pins 6-8
Posted on Sep 09, 2008
  • 357 Answers
SOURCE: powerbutton connection wires were disconnected from motherboard
Look in the manual there is a diagram and pin connections for each wire.
Posted on Feb 06, 2009
SOURCE: power supply replacement for emachine et1641-02w
i just bought a emachines as well and i noticed when purchasing a new video card that it required a 450 watt power supply, so i went to check and see how much the one i had just purchased had and of course it was 250! that is soooo low, anywho, what i am sayin is if you think that you are going to add any drives or a after market vid card then yes you need to replace the powersupply in ur emachines with at least a 500 watt, they are like 50 to 100 dollars at tigerdirect
Posted on Feb 26, 2009
What is my product key? (25 character number)
Dear User...
Microsoft Product Key:-
72HHJ-8YR4B-2XT62-TJGMV-JBP68
Thanks..
Feb 08, 2013 | eMachines EL1300G-02w - 24167
I've got an emachines eT1641-02w that won't boot up . No way to enter BIOS screen, No eMachines screen or anything at all I've already tried these solution but they didn't help at all: -Changing the...
Usually replacing the coin cell battery fixes the no boot problem. Look on the motherboard around the processor socket. Electrolytic capacitors can overheat. If you see any of them that are bulging (top is domed instead of flat), they are bad. Trying to replace all the bad ones is tedious and expensive. May be cheaper to replace the motherboard.
Apr 16, 2017 | eMachines ET1641-02w (PT.NA60X.001) PC...
I have emachine ET 1641-02w check the power supply and its check out ok but computer wont turn on
I will assume that you have not messed with anything and it just stopped working. So try these steps:
1) Check the power plug, make sure it is plugged into the wall and also into the back of the computer.
2) Check to see that the switch is "On" on the back of the power supply if there is one.
3) Take the case off and look at the power button, try to press it without the case on, perhaps the power button is broken. If that doesnt work try and see if the little wires on the back of the power button are connect and bot pushed off.
4) Check the cables to the power supply, ensure they are connected to the motherboard and not disconnnected.
5) If all of the above do not work, take a power supply from another system and plug it in to *********** board, see if the computer boots normaly then. If that works you can assume the power supply is shot.
Let me know if there is anything else.
-Paul
Jul 12, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
PC power down after 3 seconds power on. Power
pull out the cpu chip and see if it comes on or beeps,
If it dont its the mobo.
Sometimes the mobo and the cpu go bad at the same time, a bad cpu can kill the mobo
Apr 15, 2010 | eMachines ET1641-02w (PT.NA60X.001) PC...
How do i get case off emachine el1300g to install memory? the exact model # is: EL1300G-02W
There is usually just 2 screws to take out on the side with the fan vent. Once you remove these, you just slide the side panel towards you and lift
Feb 08, 2010 | E-Machines eMachines Desktop PC
Need to replace power supply in new eMachine EL1300G-02w. model# if oiwer syookt 220UB-2B Rev. 00F
Unplug the wires, replace with new power supply. You can get one from amazon.com or newegg.com
Nov 13, 2009 | Cameras
Computers & Internet Logo
106 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
