Question about Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
The drawer will not close - Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher
I can't close top drawer
Posted on Dec 11, 2010
The CD drawer on a JVC EL-E3 CD Player fails to open/close. The CD fails to play when I physically close the drawer. The drawer does not close completely and needs an extra push to close it.
Sounds like the alignment is off. By physically pushing the drawer.
There is a motor on the side of the drawer that should control the drawer by pushing a piece of plastic back and forth. This piece can shift if pressed to hard. In the back of the drawer are the rods that control the top to drop. These need to be aligned with the side motor.
Jan 07, 2015 | JVC Audio Players & Recorders
Drawer will not stay closed
Hello David, I am JK. I understand that you are having trouble with the drawer staying closed on your pedestal. I would recommend checking to make certain that nothing is caught under the pedestal keeping the drawer from closing properly. If this is not the concern, the strike and/or latch might need to be replaced.
Hope this helps!
Mar 05, 2014 | Electrolux EPWD15IW
Washer is reading ddo. what does that mean?
Hi
Error DDO means dispenser drawer open. This error appears when the washer senses that the dispenser door is not closed. If the dispenser door seems to be closed then it seems to be an issue with the magnet. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch & signals the washer that the drawer is closed. This magnet might have moved from its place and that's why you are getting error DDO. Pull the drawer out and check the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Hope this helps... Please post back if you need more information.
Daniel
Jan 13, 2011 | Frigidaire Washing Machines
My top drawer of my Fisher and Paykel dish washer wont close tight. It seemed to be jammed and not closing unless it was pushed closed hard and then it jumped a bit now wont close tight and has no...
Make sure the unit is level. Remove drawer. On the inside of the cabnet there are the drawer runners on iether side. Behind these there are a pair catches. If one or both of these are latched back when they shouldn't be, ie. when the drawer is open, they will obstruct the drawer from closing fully and fail to hold it closed.
Hope this helps
Dec 13, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
Dvd drawer wont stay closed
take it back to the store or repair shop. Same thing happened to a friend and because it was new, the machine was exchanged.
Jan 25, 2009 | Sony BDP-S300 Blu-Ray Disc Player
Bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Dec 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Cannot close middle front drawer
you have to take off the left side cover and you see 2 gears close to the middle of printer, those have to be turned to release the clutch for the drawer. The drawer should now slide in.
Nov 18, 2008 | HP Color LaserJet 4500n Printer
Canon printer error 073
The transfer drawer connector or the transfer frame drawer connector is not connected as the front door is closed.
Nov 04, 2008 | Canon imageCLASS 1100 Laser Printer
Casio cash register te-4500f
Hi.
E10 means drawer not closed within the given time (in programming). if you have the drawer closed already, make sure all three wires are connected between the drawer and the register (one of them senses the drawer state). Apart from that, you might have a programming, or memory issue. Has anyone played with the programming?
If you are still stuck, let me know.
Mark
Apr 27, 2008 | Casio Parts Cash Register PC Desktop
Fisher and Paykel 23 in. DD603H SS Free-standing Dishwasher Logo
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
