Question about Famous Trails FT950 Monocular
When I turn the power switch on the red LED does not stay on and am not sure if the unit is on or off. It's a new FT950 and the instructions are not clear and it's all new to me. Thanks Rich
Why dose my red led light stay but tv will not turn on?
You either have a faulty main board or faulty power supply or power supply capacitors. If you are considering taking the set to a shop, I would advise against doing so. With the price of 32" dropping like a rock, it would be cost effective to purchase new. You could recycle the set or toss it on your local Craigslist as a parts unit and someone will buy it for sure.
Jun 08, 2014 | Samsung LN32C540 32 in. LCD TV
Mitsibushi WD-60638 , just replaced the lamp now tv flickers and shuts off with a solid red led light , can anyone help me fix this ?
not sure but check internal fan is functioning correctly...I had same problem with a hitachi
Feb 23, 2013 | Televison & Video
I have a Graco baby monitor, it started making a noise for the last 2 days, could it be a battery problem (even with power connected)? The monitor is about 1.5 years old.
Annoying! happens to us too frequently, but this works. We ended up buying a new one and returning our broken one after owning for three months From Manual:) 5. Turn on the Nursery Unit using the On/Off switch on the side. The green power light should come on. 6. Within a few seconds, the Parent Unit will lock on to the Nursery Unit and the top four (4) green LEDs will shut off. A second later, you will hear a series of beeps and the connection LED should change from red to green. Your monitor is now ready for use. 7. If the top four (4) LEDs do not shut off, power off the Parent Unit and the Nursery Unit and repeat steps 4 and 5 above. 8. If the connection LED on the Parent Unit does not change from red to green and the unit begins to beep, press the channel "ch" button on the Nursery Unit. Within a few seconds, the Parent Unit should lock in on the Nursery Unit and the connection LED should change from red to green. You may hear an audible beep during this process. 9. If the Parent Unit is still unable to lock in on the Nursery Unit (connection LED will be red and the unit will beep), power down both the Parent Unit and the Nursery Unit. Wait for 10 seconds then hold the volume down button on the Parent Unit while pressing the On/Off switch. When the unit powers up, you will hear a single beep and all of the soundlights will illuminate. Release the volume down switch and within 2 seconds you will hear two beeps and all of the Sound Light LEDs will stay lit and the bottom LED will be red. 10. Repeat steps 5
Oct 12, 2010 | Graco Baby Care
Put new batteries in exit signs but the status light wont stay on green...it will switch back to a constant red meaning charging. What would be bringing the power of a new battery down all the time?
is the unit battery only or battery backup? if battery backup, the system is draining the batteries as it has no source of power.. if battery only there may be a connection problem or a faulty unit.
May 13, 2010 | Universal Battery Exit Sign Red Led ...
Cannot connect to my verizon env2 phone
Try this:
1) Charge the headset (plug it in until the LED light turns off. Didn't take very long for me) and unplug it...
2) Make sure the unit is ON (It blinks quickly when powering on and off, and blinks consistently while on, so it shouldn't be hard to tell) [the power switch is very slim and on the outer edge of the unit, labeled by a circle with a line in the middle]
3) Hold down the big silver button on the large outer flat surface of the unit until the LED light *STAYS ON* ***While that LED light remains solid, the unit is in Bluetooth "Discoverable" mode*** After you have put the hands free unit into this mode, then *promptly* follow your own cell phone's blue tooth pairing instructions, usually found in the "tools" or "settings" menu.
Apr 14, 2009 | Lands Phones
Dell 1110 Laser Printer Solid red warning light
Hi in this case the paper jam made some sensor through the paper road they are not in normal position or still tigger on by piece of something or error stander. you may try:
1) check paper input sensor near paper tray roller\
2) check margin sensor inside paper way before drum unit
3) check fuser sensor near fuser unit
4) check paper output sensor near output tray roller
sometime need sensor adjustment back to normal position
Dec 22, 2008 | Dell 1110 Laser Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Famous Trails FT950 Monocular Logo
71 people viewed this question
Top Famous Trails Optics Experts
Andrew Gaitan
Level 1 Expert
Shawn Hudson
Shawn Hudson
Jennifer Green
Jennifer Green
Are you a Famous Trails Optic Expert? Answer questions, earn points and help others
