Question about Bosch Nexxt 500 WFMC3301 Front Load Washer
My 500 series is not filling up with water . No water is coming out at all and I checked all the connections and hoses. Everything is on. Help!!!
  • 144 Answers
I would make sure the machine has not got blocked inlet filters. Many machines have a little mesh filter inside at the hose connections ,I hould check the hoses are clear too by puting the ends in a bucket and very gently ease the water back on too check for blockage.
hope this helps
pete
Posted on Nov 14, 2010
My Bosch vision 300/500 DLX series washing machine continually dispenses hot water no matter what cycle I have dialed in. What can I do?
if it's hot and cold fill machine , have you got the hoses connected correctly hot to hot supply , cold hose to cold mains supply
if its cold supply only to machine , make sure it's not connected to hot water supply, this could be worth checking.
Oct 28, 2016 | Bosch Washing Machines
How do I figure out why my Kenmore 500 series washer wont fill with water-just hums.
check if water supply is on dont take for accont that it is i have seen it all frozen and closed I assure you then check that filter in hoses and water valve isnt filled with debris is all is good change the water inlet valves
Feb 21, 2015 | Kenmore Washing Machines
Whirlpool - hot inlet hose shaking badly when filling water
check to see if the screen is clogged were water hooks up to back of michine
May 11, 2012 | Whirlpool Washing Machines
I have a Kenmore 500 series washing machine. The cold water just trickles out but the hot is fine. I have replaced the fill valve, but the problems persists. Any help would be appreciated.
Having replaced the valve i would suspect the cold water for what ever reason is not getting to the valve from the faucet..if you have not already done so remove cold water hose and see how much water is coming from it when its not connected to the washer. If your using the "aqua flow-flood stop" hoses thats going to be the problem..the internal stopper in the hose has failed and hardly no water coming through the hose.
GENE
Aug 28, 2011 | Kenmore 24422 Top Load Washer
Bosch machine is filling with water when not on! is this a valve or water intake part problem?
Not alwys fill valve fault.. make sure not draining back from sink back into mach,,if yes put drain hose higher to cure...
Sep 08, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
My kenmore 500 series washer fills up part of the way then drains
You may have a condition known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple matter of drain hose placement, or lack of air gap. Before assuming you have a bad component, its always a good idea to double check your installation. If you check everything and still have problems, please let me know. I hope you find this information helpful.
Aug 22, 2009 | Washing Machines
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Washing machine won't heat water
it sounds like the hot water supply hose on the back inlet water valve is not opening up,to check it switch the hoses,cold on hot,and hot on cold,put the washer on fill cold,if hot water comes out you know it's the water valve-mike
Mar 21, 2009 | Kenmore 80754 Top Load Stacked Washer /...
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Bosch Nexxt 500 WFMC3301 Front Load Washer Logo
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
