SAMSUNG MODEL CODE - HLT5676SX/XAA, when turned on, i hear a humming noise for about 1.5 minutes, then it repeats 2 more times ,then 3 lights flash 1 red 2 green and my tv does not come on, no picture.
SOURCE: tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Posted on Mar 24, 2009
IB4G2008
  • 3587 Answers
SOURCE: Black screen, blinking led
actually, unless the control board is identical(which it isn't) that would be a bit of a stretch.. Let's see..can you let me know what is the model number of your set?
Posted on Feb 24, 2008
  • 108 Answers
SOURCE: Samsung HLM507WX/XAA getting hard to turn on
Replace the lamp.
Posted on Jan 08, 2009
welcomejee
  • 10594 Answers
SOURCE: Sony Bravia kdl-46S3000 flashing red lights
Sounds Lamp is weak in this TV.
Please replace lamp and procedure is written in TV user manual.
Posted on Mar 14, 2009
  • 147 Answers
SOURCE: TV won't stay on. Green & Red light timer-lamp (Green) stand by/temp (red) flash.
Most likely needs a new lamp. Easily done yourself.
Posted on Apr 15, 2009
DLP powers down after 1 minute; no sound or audio
REPLACE LAMP IF PERSISTENT REPLACE THE LIGHT ENGINE COS THE COLOR WHEEL IS WORN OUT
Jul 07, 2013 | Televison & Video
I bought a used samsung t.v. and the remote don't work. its got new batteries but don't work it might be a samsung universal remote do i need to but my t.v. code in it. how do i do it and what is...
Hello
Three digit universal remote codes to check with Samsung tV are:
004/ 005/ 009/ 015/ 104/ 105/ 106/ 109/ 133/ 172
Four digit codes are:
0105 0077 0076 0109 0007 0009 0004 0005 0085 0172 0942 0358 0012 0015 0080 0104 0106
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Jul 26, 2011 | Samsung TV Remote Control
Model Number HLT5676SX/XAA 56" Samsung
your question does not help us or you as we do not know your problem .
Jun 09, 2017 | Samsung DLP HL-P5663W 56" TV
Samsung model HLT5676SX wont turn on and has three flashing lights''
Replaced the lamp. This is the most common root cause of the flashing lights. PN: BP96-01795A
Mar 15, 2010 | Samsung Televison & Video
Samsung HLP4663WX/XAA picture went out, started making strange noise, all lights on power button came on.
Sounds likea bad color wheel to me, or possibly a lamp has blown. If the noise is a humming sound--it is the CW--if you hear a "sound like a sizzle, for a few seconds and then normal, and this repeats a few times--the lamp has blown.
Oct 12, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HLP4674W - changed bulb - still no picture - lights flash
If the lamp has been replaced I would think the Lamp ballast would be most likliest followed by the color wheel and then the Digital board. You can get any part needed for your model at www.tvrepairworld.com just leave them a email they respond quickly.
Aug 28, 2009 | Samsung HLP4674W 46" Rear Projection HDTV
Possible bad color wheel? HLN617W
Replace the color wheel and you should be OK.
Feb 19, 2009 | Samsung HLN617W 61" Rear Projection HDTV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
