Question about Broan-NuTone CV350 Central Vacuum
How do you remove the dust filter on a cv30-d broan central vac
How do I clean out nutone cv556 filter bag?
There are 3 options: 1) Use another vacuum like a shop vac to clean the filter bag while in place. 2) Wrap a trash bag around the bottom of the canister with the dirt can removed. Tighten the trash bag around the metal can and smack or shake the filter bag. This will prevent dust from escaping into the air and on you. 3) Grab the filter bag towards the top where it locks into the can. Pull the filter bag towards the center of the can to fold it into a C-shape. This can be hard to do, so do not be afraid to pull. Once folded into the C-shape, the bag should come out easily. Take the bag outside to shake off any debris. To put back in place, use the C-shape method again, and fold out to form a full circle. DO NOT wash the bags out with water.
Please visit our website if you need a replacement part or if you have more questions. Or give us a call at 1-800-533-3249
Don't forget to like and visit our Facebook page.
https://www.facebook.com/QualityHomeSystems/
Central Vacuum Intercom and Whole House Audio Systems
May 22, 2014 | Broan-NuTone CV556 Cyclonic Bagless...
Tornado cv30 1
will shut down if the motor over heats check for blocked filters
Oct 16, 2013 | Broan-NuTone Vacuums
I have a broan central vac 24 yrs old ,vac works if you turn sw on cannister,not by plugging hose att,is this a major problem,thanks
Broan 450 air-watt and 8.5 amp power unit. Covers 3,000 sq. one 30-ft. crush-proof hose with on/off switch, one 10-in. wide hard floor brush features swivel neck for easy maneuverability around furniture. My new home is just under 2000sf. Will this new unit have enough suction?? Just buy or don't??
Jan 22, 2013 | Broan-NuTone CV350 Central Vacuum
My central vaccum just stop working last night. It does not turn on at all.
I've gone through 3 vx475 vac in the past 7 yrs. Last one was sent to me in Apr 2010. Just yesterday, once again, my vac just quit. Green power light is on but no other sign of anything. Had a burning smell when vac quit, like motor just fried. Called Nutone again and they can't imagine whats going on but will send out another vac free and was told to throw out old one. They said dust may get into the motor and cause it to quit. These vacs aren't cheap, can't imagine that its so simple to just call up and have a brand new one sent to me. I've asked if they are rebuilt units and was told no. So my advise to you, if you haven't already, is to simply call them up w/model and serial # and they shouldn't give you any prob. good luck.
Sep 03, 2010 | Broan-NuTone VX475 Bagged Central System...
No suction
Use the guide at builtinvacuum.com/flowchrt.html to find the issue and solution. Most likely you need to test it without any filter and be sure the bottom of the unit is attached :) To get access to the motors you need to unbolt the very top sides.
Jul 28, 2010 | Broan-NuTone CV350 Performance Bagged...
Central vac will not turn off
You have a defective internal relay on the vac. Check for warranty coverage as this is a common occurrence on these big box store units.
If beyond warranty the relay should be a straight forward unit, miniature circuit board type plug in device. Find a Broan Nutone service center or take to vac pro shop for parts.
Nov 01, 2009 | Broan-NuTone VX475 Bagged Central System...
I have the same central vac and the same problem
I don't see a problem. here. Post details and I'l be glad to help ASAP
Oct 04, 2009 | Broan-NuTone VX475 Bagged Central System...
Is their maintenance I need to do on my H702 central Vacumn?
H702 appears to be a Honeywell heavier duty for mid to large floor areas.I have not seen them but internally most Central vacs are VERY similar.
Most central vacs have an exposed filter which should be inspected periodically for damage or cleaning and replacement. A hanging cloth filter is normally fine for 7- 10 years with periodic inspection by the homeowner. Look for tears, never pick up wet stuff. very simple. You can clean a cloth filter prior to inspecting with the round brush from another vac or a soft paint brush.
I found internet reference to an H702 bag but it may be an option for your vac.
Some cv's have an additional or optional paper bag for allergy sufferers or removable cartridge filter which would be visible when removing the dust pail. regardless, the filter protects the motor from damage, periodically inspect when emptying. If dust gets through a damged filter it can leak into and blow a motor. As an cv ages a small degree of fine dust gets in no matter the brand, but most are fine for 10-12 years with no service.
If you see dust in the air exhausting or puffing from the vac, have the unit checked as this indicates dust which has run completely through the motor. If you see a small amount of black dust exhausting along your wall, it is normal from internal brush wear. Turn the vac on and off and listen to the motor as it winds down. If it growls or sounds scratchy or is squealing, that is an indication it needs to be serviced. Clean and inspect you pwer head every 4-6 months and change a smooth drive belt twice a year, broken or not as it will be stretched.
o
If this helps please post a response
Sep 25, 2009 | Vacuums
Hayden SuperVac central vacuum making an unbelievably loud noise.
Stop using the vac. Remove the filter and clean thoroughly, inspecting for damage. If the vac is spiting out bits off fuzz or lint it may need the motor cleaned and serviced as dirt has leaked past the filter. If it is spewing black, not gray this is carbon dust from the motor brushes. If the noise is scratchy or growling this is a sign of a motor problem as well.
The muffler unless it is a hepa filter/muffler combination is NOT designed to catch dust.
Exhaust dust is a sign of dust leaking through the motor which indicates future moor problems.
HINT, if the guy who installed the muffler didn't secure it right he is probably not a good choice as a service tech either. The muffler is normally clamped or secured in place with a small screw so it can be removed in the event of service.
Jun 14, 2009 | Hayden Industries SuperVac 3600 Central...
I have a broan central vac system need belt for cv315-b vac head cant seem to find one any idea where i can get 1 thanks
I believe that the Broan replacement part number for the belt for the CV-315 power head is a 9967-0585. available through a Broan/Nutone dealer.
May 11, 2008 | Vacuums
Vacuums Logo
373 people viewed this question
Top Broan-NuTone Vacuums Experts
Gerry Harvey
Gerry Harvey
JoeVacs
rdjagger
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
