Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door wants to continue going up after hitting stop
    President:
  • 3,197 Answers
Close the door and then locate the 'up limit' control on the side of the motor unit. Turn this control 2 full turns in the opposite direction of the arrow printed on the cover. Should do it.
Posted on Nov 15, 2010
Timer counts down. Microwave keeps going
It is a bad door switch, or the keypad control board is the issue.
Apr 11, 2012 | KitchenAid KCMS145J Microwave Oven
Liftmaster Professional 1/2 horse model # 41A5483 installed in 02 Learn light flashes 4 times. When openers are hit in cars (2 Chrysler vans use built in Homelink Systems built into sun visors, one car...
check the settings on the unit itself sometimes if you have it set up to come down too rapidly it will cause it stop and go back up because it thinks its hit something.
Apr 10, 2011 | liftmaster Garage Door 1/2 Hp
Washer goes on and off/ seems to be the door causing the problem
There is a loose contact insde. May be door switch. Try hitting in different place. Open and inspect for ejected crimp plug or loose fitted.
Mar 31, 2010 | Frigidaire Affinity ATF6000F Front Load...
Motor noise from Bosch freezer 'noFrost' unit area sounds like a fan blade striking something on each rotation. Stops when door opened; starts and continues for several minutes when door closed.
Hi, If you say it stops when the door is opened and starts again when you close it, it is the evaporator motor in the freezer its self. The blade/prop is hitting maybe a chunk of ice or may be a part of the casing some where. This motor is 120 volts and the blade is either aluminum or plastic. You can fix this on your own if you are a handy guy, you just need to get back to where the motor is and plug it in to see what it is hitting.The bearings may be going out causing the motor shaft not to be true and hitting. You will be able to see the motor turn and know if it is straight. I don't believe that's the problem, something has moved slightly causing the blade to hit it on start up.I have seen this happen many times.Once you get the cover off, it should be a quick fix for you. Keep me posted. If it turns out to be the bearings as you will see the shaft wabbling, take it out, make sure you unplug it, an get the name Bosch, model, and serial numbers and get one at a appliance parts house. Like I said, I don't think its the bearings or it would stop working or be real noise all the time. The blade is just hitting something small. Keep me posted,
Sincerely,
Shastalaker7
Mar 23, 2010 | Freezers
Garage Door only opens with wall unitq
The unit is in the lock mode, push and hold the lock button in for about two seconds and the green LED should stop flashing. Your remotes should work.
Dec 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Microwave/convection oven problem
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
If you think the problem is on the control panel, which we repair these nationwide for $39.95 postpaid.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 25, 2008 | Microwave Ovens
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
