Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Error code e 13 - Bosch Nexxt Premium WFMC6400UC Front Load Washer
  • Bosch Master
  • 2,605 Answers
Welcome to FixYa.
The E13 error code on the WFMC series Bosch washer`s refer to a drainage problem, as you may or may not already know. ( or in Bosch terms "pump time exceeded" )
Anyway, here`s the most likely way to remedy a E13 code.
**Unplug the washer from the wall or turn off the breaker before attempting any repairs**
Get some towels and if possible a wet/dry vac. If the machine drained, it won't be too bad. If your machine is stuck full of water, that sucks...hopefully you won't get too wet. ( maybe you`re lucky enough to be close to a floor drain )
  1. Locate the round door on the front of the machine (about 6" in diameter, lower right corner) error code e 13 - macmarkus_26.jpg
  2. Find a drill bit or small screwdriver that fits in the hole in the round door.
3. Insert the bit into the hole in the door. It will push in a tab, it doesn't take much force. Rotate the hole (clockwise) to 6'oclock and it should come free. (the edges are very sharp so be careful).
4. Once the door is out of the way you'll be greeted by a 3-4" plastic cap with wings so you can unscrew it by hand. ( you should also see a red ring with a string attached, if you pull this the door should unlatch, but getting the water out first is usually a good plan )
There is a small collector lip at the bottom of the cap, that is where you can hold the wet/dry vac to catch the water. Unscrew slowly so you don't get flooded, until it is unscrewed all the way out
5. Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.macmarkus_28.jpg
6. After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
7. Run a load and watch for leaks. Leave the pump access door off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "FixYa" and good luck.
Regards,
Macmarkus :)
Posted on Nov 14, 2010
21.2:13 error code HPT770
21:2.13 error- service station fail- these can be ordered but need fitting by an approved engineer
part number CH538-67040
Dec 30, 2013 | HP DESIGNJET T770 Printer
What does error code 13 mean?
1) Copy following links for Rheem tankless error codes
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Tankless-Error-code-13.pdf
2) Maintain water heater as shown in product manual to avoid common error codes.
Dec 28, 2012 | Rheem EcoSense by 7.4 GPM Tankless Water...
I am getting a 13 error code . jim B.
Before calling service technician, open following links for troubleshooting resources including Rheem chat and typical manuals:
http://waterheatertimer.org/pdf/Error-code-13.pdf
All gas water heaters require periodic maintenance.
Tankless recommend yearly maintenance.
Typical maintenance would cover most the causes for error 13, plus causes for most other common error codes.
Jul 19, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
Code c4-13
Before calling service technician, open following link for Rheem troubleshoot resources including error codes, Rheem chat, and possible manual:
Error codes are considered start-point for troubleshooting.
Error code C4 13 is bad oxygen sensor, inadequate incoming air supply, or bad venting. Also bad PC board, or internal wiring, or temperature set too high, damaged burner parts.
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Tankless require yearly maintenance to combustion chamber and burner parts.
Prescribed maintenance can correct some of the issues in error code 13.
Jun 25, 2011 | Rheem EcoSense by 4.2 GPM Tankless Water...
My Samsung SMH7178STD just started showing error code E-13
Hi, please click on this LINK then select 'Display Panel', then 'Microwave Is Displaying An Error Code' for instructions on what to do in the event of an error code, such as 'E-13'
Oct 31, 2010 | Samsung SMH7178STD Microwave Oven
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
Error code 0 13
1:Error Code 0 13 could be telling you that your "Air Filter" needs Cleaned.
2: If that does not work Call "Sharp" at 1-800-237-4277, follow the Prompts for "Air Conditioners".
3: When you reach a person give them Reference # 5263448. that is for your current problem, I have already spoke to them about.
Hope I Helped
George
Apr 28, 2009 | Sharp Heating & Cooling
AR-5132 Error code E7 13
CCD calibration error. Make sure the optics are clean in the machine in the scanner and free of dust.
Nov 03, 2008 | Sharp AR-5316 Advanced Digital Imager...
Vrcd400-sdu error code 13
CD will not go in dis slot
Jan 02, 2008 | Car Audio & Video
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
664 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
