Question about Honda Maxus Pressure Washer MX5222
My honda pressure washer runs put there is no pressure when i pull the trigger. we have checked the oil and everything, the water comes out just no pressure.
  • 26 Answers
Check to see if you have an obstruction in the hose or tip. If clear you have a problem with the unloader valve. This valve sometimes gets stuck and continually recirculates the water not allowing you to build pressure. Sometimes you can remove and clean. If cleaning doesn't work you will need to replace it. Let me know how you make out.
Posted on Jul 21, 2011
Pressure washer was working fine then it shut off. and now I cant pull the string
Whoa! Wait when water pressure is at hose you have to pull the trigger on wand to release pressure so the engine can turn freely. It has so much pressure at wand that it will not let you turn enging over. If not It may have froze up. Check the oil first , no oil then it is locked up. If not you can remove pull rope cage and try to turn it manually.
Oct 01, 2014 | Garden
Honda 160 homelite pressure washer 2700 psi no pressure
Water comes out the nozzle, but low pressure? ( more than when the motor is not running)
I would check the check valves and the unloader.
If the amount of water coming out the nozzle is the same when the motor is running or not running.
Either the key that connects the motor shaft to the pump shaft is sheared, or the pump is trash.
No water comes out the nozzle would indicate a clogged inlet filter or blockage at the gun valve or nozzle.
May 05, 2014 | Homelite Pressure Washer. Honda 2700 psi...
Does anyone have a answer as to why all of a sudden theres no water and presure coming out of my jet washer
If there is no water from you power washer it is because the is no water going in. Check fitting is connected properly. When you pull the trigger and the machine is not running you should get water coming out of the nozzle That shows that water from the tap is passing through the machine. As to no pressure that will be a fault in the regulator valve that is not reacting to the trigger setting and allowing the pump to build up pressure. It is still reading as if you haven't pulled the trigger
Feb 24, 2013 | Honda GCV160 Engine
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
Won't stay running
Pressure washer when you first try to start them that stop underload. We had the same type of problem with 11 hp Honda if you hold the trigger open the motor will be under less load we found by running the motor for about a minute it would work normally. Remember to make sure the water hose is turned on pull the trigger on, until water is coming out of the wand , now try and start the motor but also hold the trigger open, now you will not be building maximum pressure, after about a minute release the trigger and see if it keeps running.
Feb 19, 2011 | Briggs & Stratton 2200 PSI Gas Pressure...
I bought a honda pressure washer power boss 3000. I load the gasoline, start the machine, but pressure water is not coming out from the trigger. i tried so many things , but can t get started.
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Feb 18, 2011 | Honda Pressure Washer PSI 3000
I have a Honda 3500 pressure washer. The motor
You need to start the unit and let it run for few minutes to get worm, make sure the water is fully open and the unit is fully cleaned. Push on the trigger on and off for few times not letting the unit shutdown, then start increasing the fuel mixture ¼ turn and push on the trigger again and see…this could be that the unit need service or the governor springs getting week if you got one on your unit…let me know how that work for you and please do not forget to rate my service so we can improve on it with your help. God bless
Sep 07, 2009 | Honda Pressure Washer PSI 3000
I HAVE A BRAND NEW TROY-BUILT 2600PSI pressure washer. I have used it twice for about 1/2 hour each time. It worked perfectly. I tried to use it today with everything hooked up perfectly. The Honda engine...
Sounds like the governor is stuck. My pressure washer speeds up when it has to pump. Don't know if yours uses vacuum to trigger governor or direct linkage. Good Luck.
Jul 04, 2009 | Psi Blue Max 2200 High Pressure Gas Power...
Mi TM 2700 pressure washer has no pressure.
With the water on, to the washer and the unit running. Does the water come out at the same rate before the trigger as at does after the trigger (run test with spray nozzle removed). Its not impossible for unloader valve to be bad but it usually is a dependable component. Make sure the unit has the air purged from it properly before start-up, make sure there are no obstructions before the trigger, then the nozzle. The unloader valve just puts the pump into by-pass until the trigger is depressed.
Apr 10, 2009 | Mi T M WP-2700-4MHB Pressure Washer
Honda Maxus Pressure Washer MX5222 Logo
315 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
