Question about Olympus Cameras
How do I erase the memory card in the camera after I have downloaded all the pictures
  • 6,831 Answers
Hello
Can you please specify as to which model and brand camera you are using?
Let me know, i will gladly help.
Kind regards
Andrea
Posted on Nov 14, 2010
How do I generate erased fotos
I presume you are saying that you have erased photos on your camera's memory card. As long as you have not taken more pictures with your camera and stored them on the same memory card, you should be able to recover all deleted photos.
Download and run the free PhotoRec Digital Picture and File Recovery program from your computer, naturally with your memory card or camera plugged into your computer.
http://www.cgsecurity.org/wiki/PhotoRec
Good luck.
Sep 09, 2014 | Samsung Digimax A7 Digital Camera
How to erase memory card
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
The quickest way to erase the memory card. Go to the camera's Menu and scroll through the settings to Format memory card then format the memory card.
Apr 10, 2013 | Canon PowerShot SX120 IS Digital Camera
After downloading pictures with the "erase after downloading" box checked it starts to erase the pictures as expected, but hangs at pic 37. Is the memory card faulty, or is it a software bug?
I'm not sure what's causing that problem, but it will be much faster each time you download photos to not erase after downloading. Instead, find the option on your camera to format the card, and it will erase everything on the card in one process. It's much faster.
Mar 06, 2011 | Nikon Coolpix S3000 Digital Camera
I HAVE PICS ON MY INTERNAL MEMORY AND NEED TO PRINT. I PLACED A MEMORY CARD IN TO TRY TO COPY TO THE MEMORY CARD. iT KEEPS TELLING ME THERE IS NO MEMORY CARD. tHE MEMORY CARD HAS OTHER PICS ON IT AND IS...
If the "other" pictures have been taken with a differed camera your camera will not read the memory card until it is formatted to your camera. Formatting will erase all pictures on the card. You need to download the pictures to the computer. Format the memory card and then you will be able to transfer pictures from the internal memory to the memory card then to print or to the computer. You should format the memory card after each time you download the pictures to the computer.
Jan 20, 2011 | Kodak Easyshare C182 12MP Digital Camera
Can I take picture with out a memory card if yes how?
Not really. You can take one picture without a memory card, but that picture will be erased when you turn the camera off. If you want to store pictures for later downloading to a computer, you'll need a memory card.
Dec 31, 2010 | Vivitar ViviCam 8025 Digital Camera
I used to be able to take 1000+ pictures on external memory card. Now I'm trying to take pictures and it will only allow me to take 9 pictures but on the camera memory. I have reset the camera to factory...
With no card in the camera, go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your card and do the format thing again (This will erase your card so if there are pictures on it, download them first using a separate card reader).
Jul 02, 2010 | Olympus SP-565 UZ Digital Camera
Erasing the memory card;
All pictures in the internal memory and/or on the memory card can be erased at once. This is accomplished through either formatting or the "all-frame erase" function. I copied the following instructions from the advanced manual, which can be downloaded here: http://www.olympusamerica.com/files/d545zadvman.pdf. Adobe reader should open that file with no problem. If it doesn't, that's another issue altogether.
1. Enter playback mode by pressing the play button.
2. Press the OK MENU button.
3. Press the right arrow button (next to the lightning bolt) to access [MODE MENU]
4. Then, press the down arrow to access the [MEMORY(CARD)] tab.
5. Select the [ALL ERASE] function.
6. Select Yes and press OK MENU.
(You'll need to use the arrow buttons to navigate the menus. Please see pg 16 of the manual for instructions on how to do so.)
Note: when the memory card is in the camera, it will erase the pictures off the card. When the card is removed, the function above will erase the internal memory.
Apr 22, 2009 | Olympus D-545 Zoom Digital Camera
When I try to erase a photo i get a busy message
It could be a many things
Try:-
check the memory card contacts are clean, use a pencil eraser or a cotton bud (Qtip) moistened (not wet) with isopropyl alcohol (tape/stylus cleaning fluid)
Download your pictures then format the memory card or internal memory take some test pictures and try again.
Try a different memory card.
Check the cameras website for a firmware update.
Best of luck
May 25, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Fe170
You can add memory to your camera by purchasing an xd memory card.
Compatible cards
xD-Picture Card (16MB – 1GB)
There are two ways to record the pictures you take with this camera.
Recording pictures to the internal memory
• Pictures are recorded to the internal memory, and when the number of storable still
pictures reaches 0, you must connect the camera to a computer to download the
pictures, and then erase the pictures from the internal memory.
Using an xD-Picture Card (optional)
• Pictures are recorded to the card when inserted in the camera. When the card is
full, you download the pictures to a computer, and then either erase the pictures
from the card or use a new card.
• Pictures are not recorded to the internal memory when a card is inserted in the
camera. Pictures in the internal memory can be copied to the card using the
[BACKUP] function.
g“BACKUP Copying pictures in the internal memory to the card” (P.25)
“The card” (P.60)
Number of storable still pictures and recording length of movies
Still pictures
Movie
• If you use a non-Olympus card or a card used for another application, such as for
a computer, the message [CARD ERROR] is displayed. To use this card with this
camera, use the [FORMAT] function to format the card.
g“MEMORY FORMAT (FORMAT) Formatting the internal memory/card” (P.24)
Additional shooting tips and information
Increasing the number of pictures that can be taken
IMAGE QUALITY Image size
Internal memory Card (128 MB)
SHQ 2816 × 2112 2 25
HQ 2816 × 2112 6 76
SQ1 2048 × 1536 8 108
SQ2 640 × 480 60 726
Remaining recording time
HQ 320 × 240 (15 frames/sec.) 32 sec. 6 min. 37 sec.
SQ 160 × 120 (15 frames/sec.) 2 min. 8 sec. 26 min. 28 sec.
Dec 15, 2007 | Olympus FE-170 Digital Camera
Help
Yes and in several methods as below listed. Since your posting refers to a generic problem for all digital cameras and not only an Olympus FE-230, some of the settings may have a different nomenclature or button name.
1. When you download pictures to you PC, rather than copy, select move; or
2. If you want to erase one picture at a time from the camera - press on the power button, then menu button, once menu is displayed, arrow down/up, you will be asked to erase the picture displayed, select yes/no by up/down, then press OK (menu button); or
3. If you want to erase all contents of the memory card of the camera - press on the power button, then menu button, once menu is displayed, arrow right, down to select card, right to select card setup, right to enter card setup, arrow down to select format or erase all, OK. Erase all just erases the files, format erases all and re-initialize the memory card; or
4. Remove memory card from camera and insert into a memory card reader attached to USB of your PC. The memory from the camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
5. Connect the camera via the supplied cable to any USB port of your PC. The camera will be treated as a removable device and you can view, move, copy, delete/erase, format. This option seems to be most effective in viewing all contents under Windows Explorer with the view setting set to Thumbnail.
Specifically for an Olympus FE-230:
1. Press the < or > buttons to display the picture you want to erase;
2. Press the trash can button (bottom right);
3. Press the UP button to select [YES], press OK;
or
To erase all:
1. Press the MENU button to display the top menu in playback mode;
2. Select [ERASE], [ALL ERASE], and press OK;
3. Select [YES], and press OK
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Nov 08, 2007 | Cameras
Cameras Logo
18 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
