Question about Electrolux Dishwashers
I have a frig/electrolux gallery series dishwasher: model GLD2445RFC0 serial # TH72896159. On the ceiling of the dishwasher is a gray plastic arm that snap onto a round gray disc that screws into the ceiling. It will not stay connected to the disc eventhough I snap it on with a round white plastic doughnut kind of cap. I have replaced the gray arm in the past because the orig. one fell and melted on the heat ring. This one has : 1546496 1546079 CAV 2 >PP+20TF written on it. Please help me. My dishes are NOT getting clean eventhough I wash them before loading and have cleaned the glass trap. thank you. Sherrell Snodgrass
If you go to searspartsdirect.com and type in 154607802 for the part #, I'm pretty sure that's what you are looking for. I broke the exact same part and it's what my husband ordered as a replacement.
Posted on Dec 11, 2010
Frigidaire gallery prof series dishwasher- arms dont work
Hello - I suggest verifying that there is enough water pressure coming into the unit. Do you noticed if the spray arm is cracked or broken? Will it rotate slowly? If so, you might have to remove and replace the spray arm assemblies.
Oct 05, 2012 | Frigidaire Dishwashers
Frigidaire gallery dishwasher top arm fell off
Reva Daniel, I have actually had this happen to my Frigidaire Pro Series d/w. We have put some tall stemware in the upper rack and this was blocking the rotation of the top arm it actually unscrewed the nut that holds it on. So here is how I have fixed it.
1. Locate the 3 pieces (the nut), (the arm) and (the white plastic connecting piece). the white piece is very small it will most likely be on the very bottom of the dishwasher.2. The small white plastic piece sits inside of the nut and protrudes through the nut and snaps into the arm.3. take the 3 assembled pieces and tighten back on to the top of the wash tub. be patient when tightening this ,it is easy to cross thread. That is all there is to it. if some of the parts are damaged go to partselect.com Be sure you have your model # (its on the inside right side just as you open the door.)
Hope this Helps Joe ConnollySealsonetops@gmail.com
Nov 22, 2011 | Frigidaire Dishwashers
I have a frigidaire dishwasher 4000 series aqua surge with speed clean. The small spray arm on the ceiling of the washer came off. I found it sitting on top of some cups in the top basket. There is a...
The top arm snaps into place. Simply unscrew the retaining clip from the ceiling of the washer. Inside of there, you will find a small white plastic clip. Make sure the two prongs are pointed down and poking out through the hole in the bottom of the larger grey clip that you just unscrewed. Then press the prongs on the white clip into the hole on the arm and snap it back together. Then you can screw the assembly back into the ceiling of the washer.
If this problem persists, you will likely need to replace the white plastic clip. (which is where I am at right now with my washer).
Dec 01, 2010 | Frigidaire PLD4555RFC Dishwasher
I'm having a problem with a cloudy film on all of the dishes that come out of my new Electrolux dishwasher. Everything is cloudy, and the plastics have turned from black to an ugly gray.\r\n Note: THIS...
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried in vainto clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if the heating element goesbad then that also can mess things up bad... So I would buy new spray arms, and also check out theheating element to make sure it is working... Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Sep 19, 2010 | Electrolux EWDW6505GS Fully Integrated...
Call a certified repair company as it sounds like the sump is clogged for some reason.
Jan 29, 2010 | Dishwashers
Serial number
there are a few places to look for most frigidaire side by sides the model and serial number are on a tag either on the right hand inside wall of the refrig section or on the ceiling in the refrig section. on some older models though the tag may be behind the crisper drawers at the bottom. hope that helps. peyton
Jan 27, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Trying to locate defrost timer on frigidare model frs24wnfw I hsve the psrt but dont know where to locate where it goes.
on your frigidaire model, look on the front left on the bottom. for some info on your frig, see:
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Anderson/95310918.pdf
page 10 item 23. hope this helps.
On the maytag defrost timer: it's probably beside the cold control in the plastic housing on the ceiling of the FF section.
Jun 08, 2008 | Refrigerators
Dishwashers Logo
641 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
