Question about Toshiba Satellite A205-S4617 Notebook
Toshiba satellite A205-S5847
I have a error code of 10-FC06-000D and error code of 10-FA11-045D
When dealing with this error (10-FC06-000D) message in Toshiba unit is very comment in the L300 series, I don’t know if Toshiba is using cheaper hard drives or what but I see a lot of them with the same problem. If you have a Toshiba unit got to their website to check if your unit is still under manufacture warranty if it is you have some options send it to Toshiba direct they should cover the shipping but I’m not to sure, or take it in to any Best Buy or Future shop stores with your proof of purchase and they will send it out for you. This is a hardware problem that is related to the hard drive, I wiped the hard drive and all it’s boot records still unable to reinstall the OS OK, I finally decided to use a test hard drive to reinstall the OS worked fine so there is something wrong with the hard drive that most likely would need to be replaced
Posted on Feb 19, 2009
Well i had the same error on my toshiba...i spent literally 56 sleppless hours on the problem after giving up on the last 48 hour stint about 3 weeks ago...i installed a freash copy of xp...then used gparted live cd (linux small distro for partitioning hdds)to make a 10 gig partition in ntfs format....then i searched tiny vista and downloaded the torrent....that error is another way of saying you have messed up your bootmgr for vista..and it could have been a ton of things that did ruined it but none the less...after the torrent was downloaded (i know its not a legal copy but i used it just to fix my bootmgr) it has something to do with the way it sets up vista premium on your hard drive that fixes the boot problem.....and befor anyone says theres other ways to do it.....this is for extreme cases were you cannot afford a new hard drive and cannot get your factory install cd's to fix the problem ..... this is worth a shot in any case. .....forgot to mention that i used my windows xp partition to firstly download dvd decrypter and a copy of tiny vista (for you that dont know tiny vista fits on a 700mb cd and is remastered to install on its own with no help from you what so ever...then when i suggest deleting it from your hard drive and installing your own vista copy because after all all you needed to do was fix the boot... again..this is the only thing that worked for me other than buying a new hard drive i tried 30 different things and i garuntee i have heard it all..it was by accident that i found out this would fix the problem with oem instalations
Posted on Jun 23, 2008
Shred all partitions on the HDD with a data erase tool like CW shredder and reinstall from backup disks.
Posted on Jun 19, 2008
2 Suggested Answers
Geekman
  • 32281 Answers
SOURCE: toshiba satellite a205-S5847 cuts off while working
You could have an overheating problem, The CPU shuts down when it overheats and the laptop won't bootup until the CPU has cooled down.
The overheating problems are caused by a faulty fan or the heatsink/fan assembly is clogged with dust which prevents proper cooling.
Check the fan to see it it spins freely, if not (it has a bearing problem) then replace the fan. Also remove and vacuum the dust off the fan and heatsink.
Posted on Aug 19, 2009
How can I connect my Toshiba laptop to apple tv?
Try disabling the firewall temporarily. Also if you have an internet security antivirus then it has a firewall also you should disable.
Oct 20, 2012 | Toshiba Computers & Internet
Drivers toshiba satelite A205-S5847 WINDOWS 7 ULTIMATE
Get onlineand got to www.google.com In the google search box type: "ToshibaSupport" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operatingsystem when requested. Download and install the drivers.
Apr 27, 2012 | Computers & Internet
When restoring toshiba L355D-S7901 what does "error 10-FA11-045D" mean? i get that code when its creating the crc files. how can i fix this?
Read this forum:
http://www.howtogeek.com/forum/topic/recovery-error-on-toshiba-satellite-a205-s5864?replies=21
Jun 20, 2011 | Computers & Internet
It frequently hangs and slows dow but left for 10 min it will recover
Download a utility programme called asc-setup from IObit.com THis is a freeware utility that will repair your registry errors and much more if you purchase the whole system.
When you have run it go to toshiba.com and download the latest drivers.
That will sort your problems out for you.
Feb 10, 2011 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4607 Audio Driver on Windows 7 x86
Instructions to Fix Windows Error Code 0x00000017:
Apr 12, 2017 | Toshiba Satellite A205-S4607 Notebook PC
Toshiba satellite a205-S5847 cuts off while working
Aug 18, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Jul 30, 2009 | Toshiba Satellite A205-S4617 Notebook
Recovery disk wont work because of preinst4.swm
you probably need a functioning Windows Operating system to copy the disk.
If you havent had it for too long, you could try sending it back to have the O/S and other original software reinstalled.
Jun 13, 2009 | Computers & Internet
Finger print sensor not working with vista in toshiba M200
here is the link :
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=2211892&rpn=PSMC4U&modelFilter=M205-SP3018&selCategory=3&selFamily=1073768667&selModel=2211892|PSMC4U
Satellite A200-ST2041, A200-ST2043, A200-ST2042, A205-S4617, A205-S4618, A205-S4639, A205-S4638, A205-S4537, A205-S4557, A205-S5816, A205-S5814, A205-S5813, A205-S5812, A205-S5811, A205-S5810, A205-S5809, A205-S5806, A205-S5805, A205-S5851, A205-S5847, A205-S5843, A205-S5841, A205-S5835, A205-S5831, A205-S5825, A205-S6810, A205-S5823, A205-S5804, A205-S5803, A205-S5801, A205-S5800, A205-S7468, A205-S7466, A205-S7464, A205-S7459, A205-S7458, A205-S7456, A205-S7443, A205-S7442, A205-S4797, A205-S4787, A205-S4777, A205-S4707, A205-S5863, A205-S5859, A205-S5855, A205-S5853, A205-S5852, A205-S6812, A205-S6808, A205-S5821, A205-S5819, A205-SP5822, A205-SP5821, A205-SP5820, A205-SP5818, A205-SP5817, A205-SP5816, A205-S5000, A205-S5866, A205-S5879, A205-S5878, A205-S5872, A205-S5871, A205-S5867, A205-S5880, A205-S5861, A205-S5833, A205-S5864, A205-S4629, A205-S4607, A205-S4597, A205-S4578, A205-S4587, A205-S4577, A205-S4567, A215-S4697, A215-SP5811, A215-SP5810, A215-S48171, A215-S4817, A215-S4807, A215-S4767, A215-S4757, A215-S4747, A215-S4717, A215-S4737, A215-S5839, A215-S5848, A215-S5837, A215-S5829, A215-S5828, A215-S5827, A215-S6820, A215-S6816, A215-S7472, M110-ST1161, M115-S3094, M115-S3104, M115-S3154, M115-S3144, M200-ST2001, M200-ST2002, M205-S3207, M205-S4804, M205-S4805, M205-S4806, M205-S7453, M205-S3217,
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba satellite A205-S5847 booting problem
Check your GraphicCard. Have you tried downgrading to XP and can you tell if you facing same problem?
Jul 26, 2008 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4617 Notebook Logo
3,169 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
